Isopropyl Alcohol as a Fuel
Russell Eberhardt21/07/2017 10:28:37
2785 forum posts
87 photos
Methyl alcohol (methanol) was used as a fuel for racing cars in the 1930s. It is not too expensive in small quantities, about €6 a litre here. It allowed cars to run at high compression ratios.
Yes, it's poisonous but only if you drink it or inhale a lot of the vapour. It's main danger when used for racing was that it burns with an invisible flame. When I used to marshal at VSCC race meetings cars running on methanol were clearly marked to warn marshals to be on the lookout for blistering paint as a sign of fire!
Russell
Brian Oldford21/07/2017 11:04:18
686 forum posts
18 photos
Posted by Russell Eberhardt on 21/07/2017 10:28:37:
Methyl alcohol (methanol) was used as a fuel. . . . . .
Russell
Of course methanol remains the principle ingredient of the fuel used in model glow engines; in which the other ingredients of circa 30% Nitro-Methane plus Lubricating Oil etc. are dissolved.
Edited By Brian Oldford on 21/07/2017 11:04:42
V8Eng21/07/2017 11:20:07
1826 forum posts
1 photos
Posted by SillyOldDuffer on 21/07/2017 10:28:14:
Posted by V8Eng on 20/07/2017 22:55:37:
...When I went to get parts from a dealer he seemed to think it might have been partly due to Ethanol additive in modern fuel.
Edited By V8Eng on 20/07/2017 22:57:00
Maybe for an indirect reason. Digging into meths as a fuel I came across a reference to ethanol being used to control water in petrol. Apparently new petrol is often contaminated with water in storage and transport. An additional source of water in your mower's fuel might be the tank breathing damp air as it warmed and cooled during the day and through the seasons.
As water doesn't mix with petrol, it causes problems in tanks, pipe work and engines where ever it collects. Adding ethanol causes any water present in the petrol to dissolve in it, and the resulting mix is completely soluble in petrol. In this distributed form water in petrol does no damage.
So far so good but petrol goes off in storage. Ethanol would tend to evaporate with the other light fractions leaving any water in the fuel to separate out behind. Oh dear...
Thanks Dave.
That seems like a good explanation, particularly as the machine had not been used for some time, (my own mower seems to be in almost constant use).
The Carb cleaned up well with a small wire brush in the Dremel plus some elbow grease and new gaskets, so all is well (for now).
Edited By V8Eng on 21/07/2017 11:21:30
JasonB21/07/2017 12:07:09
25215 forum posts
3105 photos
1 articles
Methanol is also still used in "top fuel" dragsters
Perko721/07/2017 12:59:27
452 forum posts
35 photos
My dad used to muck around with outboard motors a bit and would always say that if a motor would not start he would whip out the plug and look at it. If there appeared to be something like water condensation on the plug he would dip it in metho and put it back in and nine times out of ten the engine would start on the next pull of the cord.
A mate of mine also used to put a 1litre bottle of metho in the fuel tank of his car every time he filled up, as the metho would absorb any water in the tank and it would pass through the engine as the fuel was used up.
In Australia there is strong support push for use of fuel containing a percentage of ethanol as an alternative to straight unleaded fuel, as the added ethanol (usually 10%) raises the Octane rating of the fuel, so providing better combustion and prevention of pre-ignition.
Samsaranda21/07/2017 14:09:11
1688 forum posts
16 photos
The more I read about the problems with Ethanol I begin to wonder if the headlong rush to put more of it into our road fuel ( the EU want us to up the amount from 5 percent to 10 percent ) , I fear we will be suffering more and more problems, it already dissolves certain polymers used in older vehicles.
Edited By JasonB on 21/07/2017 18:20:02
Brian Oldford21/07/2017 17:50:20
686 forum posts
18 photos
Posted by 12 Bore on 21/07/2017 14:09:11:
. . . . . . . .. Notwithstanding the political problems the sooner our "Divorce" from the EU becomes absolute we will be better off!!!
I'm not sure this is the correct forum to express your point of view on that subject. Many might jump to disagree with you. Whether or not I agree with you I respect youe opinion but must ask you to keep it to other more appropriate fora.
Edited By Brian Oldford on 21/07/2017 17:51:26
Neil Wyatt21/07/2017 18:10:39
19226 forum posts
749 photos
86 articles
Indeed, no politics please.
Samsaranda21/07/2017 20:14:18
1688 forum posts
16 photos
My apologies to Brian Oldford and to Neil Wyatt I shouldn't have made a political comment on this website, I will ensure that in future I only discuss model engineering and relevant issues, No Politics !!! Apologies to anyone else who I may have offended I should keep my views on other issues to myself.
A suitably humbled Dave.
Robin Graham22/07/2017 19:12:57
1089 forum posts
345 photos
Another thank-you to Adrian for the pointer to Aspen, which I'd not heard of but sounds ideal for my chainsaw which gets only intermittent and unpredictable use.
I'm not sure if it's relevant to the OP, but as meths has been discussed, it may be useful to know that Industrial Denatured Alcohol (as HMRC call it) is readily available at reasonable prices (eg £22 / 5 litres from Astor and Windsor) should it be wanted. This is 99% ethanol 1% methanol v/v. It does require a licence from HMRC, but that is not difficult to obtain. When I applied I was interested in fomulating home-brew wood dyes and finishes, and they accepted that as sufficient reason for a 10 litre/year licence without question. Of course pure ethanol is hygroscopic and will eventually dilute itself to around 96% if left exposed to air.
This discussion also reminded of a common chemistry lab solvent known as petroleum ether, which is available in various bp ranges, the most volatile being 40-60. I believe this to be a refined mix of alkanes, but I have no idea as to the proportion of straight-chain to branched isomers, which would presumably influence it's usefulness as an IC fuel. Might be worth an experiment for those in the IC world tho?
Rob.
Levent Suberk13/08/2017 17:39:46
14 forum posts
1 photos
I tried to run a Cox model engine with IPA but not successful. Two stroke model engines require methanil based fuel.
