4 Jaw Work
An accuracy exercise
Hacksaw03/10/2014 17:35:36
474 forum posts
202 photos
Strewth , i never realised they were so easy to understand yes
Ady103/10/2014 17:41:11
6137 forum posts
893 photos
At sea It's called an eductor and works on the venturi effect
The motive fluid fires into the tapered nozzle at high speed and sooks fluid and anything else from the inlet, gas liquid or other bit
Great for sooking crap out of cargo holds full of bits which would gum up or damage a pump
Edited By Ady1 on 03/10/2014 17:42:28
Ady103/10/2014 17:46:10
6137 forum posts
893 photos
They make shower heads which use the same principle
You can feel the air being sooked into the hole at the bottom of the handle if you put your thumb on it
A sandblaster which uses high pressure water uses the same principle to sook the sand up the pipe and into the nozzle
Edited By Ady1 on 03/10/2014 17:52:28
Gray6203/10/2014 19:51:36
1058 forum posts
16 photos
If you want the full lowdown on how these 'mysterious' devices work and how to make them, get a copy of Miniature injectors inside and out by D.A.G Brown. Fascinating read.
Edited By CoalBurner on 03/10/2014 19:54:32
Jack Foreman 103/10/2014 20:02:02
99 forum posts
17 photos
To all those people still struggling to understand the scientific principles, I apologise, unreservedly for starting this thread with photos of work which had no connection whatsoever with injectors.
Blame Neil. It's all his fault really.
Ian S C04/10/2014 12:12:35
7468 forum posts
230 photos
Jack, no one's to blame, this is just an ordinary conversation as you might have with a few blokes in your workshop, or at the pub, and even if it's not how it started, we all learn something.
Ian S C
Jack Foreman 107/10/2014 21:42:54
99 forum posts
17 photos
Just my implausible attempt at humour, that's all Ian. emotion
I've looked at Gary's link, and examples of injectors - I've made a sketch [I'll apply some rational dimensions to it] I've found a billet of aluminium which will be suitable, and I intend to have a go at making one. It may never work, for no other reason than that I don't have an application for it - but I would like to have a go at it anyway.
I'll post the results, in due course.
Bazyle07/10/2014 22:31:23
6956 forum posts
229 photos
The eductor is more like a loco blower and petticoat pipe, or a traction engine water lifter, or a compressed air vacuum cleaner, or a school chemistry lab water powered desicator vacuum exhauster.
If you think the high pressure injector is clever bear in mind that there are also injectors using the low pressure exhaust steam, way below boiler pressure, that still manage to get that water into the boiler against the internal pressure.
Harold Hall 107/10/2014 22:44:33
418 forum posts
4 photos
I see Jack that you mentioned an "internal depth stop" which you intend to make from one of my books. I think perhaps you are referring to what is normally called a "Back Stop". If so, then you may be interested in the improved version, complete with drawings, etc., which can be found on my web site here. **LINK** The pages also detail the reason for the update to the design.
Harold
Jack Foreman 108/10/2014 00:00:52
99 forum posts
17 photos
Thank you Harold. I shall look at that in a lot more detail tomorrow, and create a link into your website.
A backstop is precisely what I meant when I referred to an internal depth stop.
I am going to be busy during the coming months. emotion
Your advice and **LINK** is much appreciated
Edited By Jack Foreman 1 on 08/10/2014 00:01:20
John McNamara08/10/2014 12:28:58
1377 forum posts
133 photos
Bernoulli's principle also applies to subsonic aeroplane wings
jason udall08/10/2014 14:23:33
2032 forum posts
41 photos
Or should that be euler s law?
jason udall08/10/2014 14:26:07
2032 forum posts
41 photos
Btw injectors appear from the above description to be anti entropic...fascinating
Neil Wyatt08/10/2014 17:19:20
19226 forum posts
749 photos
86 articles
They don't break any physical laws. the do radiate heat so they are not 100% efficient. IF they were placed inside teh boiler to prevent this, the feedwater would get too hot and they wouldn't work. Nature has its ways!
Cornish Jack08/10/2014 18:55:10
1228 forum posts
172 photos
Similar functioning items in aircraft fuel tanks known as jet-pumps or scavenge pumps - slow but non-mechanical method of getting the last drops out of the tanks. Old technology to new technology!thumbs up
Rgds
Bill
Howard Lewis09/10/2014 22:49:27
7227 forum posts
21 photos
For an explanation of how Monsieur Giffard's injector works, and the pitfalls involved in making them, contact D A G Brown He is often to be seen at UK M.E. Shows on the SMEE stand.
I am sure that he has written a book on the subject.
As said, it is about converting the pressure energy of the steam into kinetic energy and so on. But talk to DAG, he will make it clear, so that even I can almost grasp what happens, not that I could make one so that correct and good operation could be taken for granted.
Jack Foreman 124/10/2014 13:06:40
99 forum posts
17 photos
Posted by Jack Foreman 1 on 07/10/2014 21:42:54:
I've started on making an injector ~ again, out of a billet of aluminium, for no other reason than this is what I have a stock of, in appropriate sizes. I started by doing a sketch from the *LINK* information which several of you kindly provided; to ensure that I had a steam inlet, a water inlet, an overflow & a safety valve which incorporates the outlet to the boiler. That done I put some dimensions to it, which would enable me to access all of the internal parts to fit the pressure cone. (one cone will do for the purpose of the exercise)
So - the body is machined ~ I don't yet have a mill, so some of the drilling was done in the pillar drill and some done on the lathe in the 4 jaw chuck. All of the openings line up and are where I anticipated they would be [internally] and I have bored out the two ends to take the cover caps which I have also made. These will bolt onto two BA studs each. (I do appreciate that the real injector would have more than two fixings, but two on each end is sufficient for this exercise purpose)
My next task is to machine the four spigots for steam in, water in, overflow and high pressurized steam out. I intend to make the cone and the external connections with brass and use 1/4" copper pipework.
Can you please advise on the thread type and pitch for gland and connection nuts ?
Jack
Howard Lewis25/10/2014 14:49:14
7227 forum posts
21 photos
D.A.G.Brown will explain in detail HOW an Injector works for steam, and how to make them.
He has now written a book on Injectors.
The Steam Injector was invented by Henri Giffard
(I say Steam Injector, to differentiate from the Injectors (Sprayers or Atomisers) used in Compression Ignition engines)
