Cornish Jack | 29/06/2019 16:16:07 |
1228 forum posts 172 photos | Couple of pics below of some imported components for a drill spindle. Looks to be well made and needs to be assembled. Thereby lies the problem - the tolerances are 'marginal', in that one of the bearings slotted into place with finger pressure., the other is very much an interference fit. The spindle, as is, won't accept either bearing. Not sure what the fit discrepancy is but I've had the spindle in the freezer for a week or so and still not a finger pressure fit in the bearings. I can foresee jamming problems so would greatly appreciate adfvice on best practice assembly routine for spindle to second bearing and then to housing or second bearing to housing THEN spindle through both at the same time.??? Plus any action to the remaining bearing - heating (and how). Ideas very welcome! rgds Bill |
Martin of Wick | 29/06/2019 16:41:27 |
258 forum posts 11 photos | You had better luck than I did. In my case the bearings rattled around in the block recess with about .8mm clearance - completely useless. Had I been fortunate enough to obtain one with a decently tight fit, I would have lubricated thoroughly, pressed the shaft to front bearings then to the block, then tapped the back bearing with tube down over some blocks with something large and heavy (or resorted to the trusty 12 tonne press if all else failed). Other methods would probably work just as well, such as place bearing in block then press shaft in. If you are of a sensitive disposition, pre fitting, you could polish the spindle up a bit with fine silcarb paper on't lathe to a tight sliding fit , but go easy as easy to overdo. |
Martin Hamilton 1 | 29/06/2019 16:53:51 |
188 forum posts | Have a look on Youtube as Steve Jordan done a review recently in these, including assembly. His bearings were both on the tight side & used the vice with a plate to push the bearings in one at a time, his spindle was also tight & sanded/polished it in the lathe. If you have a loose bearing use some Loctite 641 bearing fit. |
Tim Stevens | 29/06/2019 16:55:11 |
![]() 1779 forum posts 1 photos | I think you are both victims of a process which seems to be relied on by some (many?) e-bay suppliers. My guess is that decent makers of quality stuff have a rejects section, which accumulates parts which fall outside the standard spec. The firms are (another guess) run by accountants, like many UK firms, and so they see the scrap as a source of income. Along comes an e-bay supplier, and buys up a heap of the scrap, going on to sell it as though it is good to use. And we buy it. Effective quality control is an expensive process, but not having one is more expensive still. Regards, Tim |
Hollowpoint | 29/06/2019 17:56:29 |
550 forum posts 77 photos | Buying from a reputable dealer is no guarantee of quality I'm afraid. You should see the state of the quick change tool holder I bought recently from one of the very well known suppliers. |
Cornish Jack | 29/06/2019 18:41:28 |
1228 forum posts 172 photos | Martin X 2 - many thanks - helpful (and reassuring) It would seem that my overly tight fit is the better bet. Tim - I quite understand the point you make but for the price paid (including delivery from China,) I could have bought half of the materials (if I was lucky) and then produced an object no more accurate than this. I could well have paid more for the super little chuck than the whole package, so no moans from me on that score. Hollowpoint - indeed - as noted from time to time in these threads. rgds Bill |
Neil Wyatt | 29/06/2019 19:02:42 |
![]() 19226 forum posts 749 photos 86 articles | Perhaps the layer of ice on the spindle is making it oversize Neil |
Phil super7 | 29/06/2019 20:21:52 |
24 forum posts | That looks like a linear bearing |
old mart | 30/06/2019 14:24:31 |
4655 forum posts 304 photos | Even liquid nitrogen will not shrink a small diameter by much, a domestic freezer has little chance of working if the interference is more than 0.0001". You could try heating the bearings to 140C, the lowest most modern fan ovens will go to, which will not damage them. Measuring the bearing bores can be difficult, a set of rocker gauges would be the most economical and quite accurate with care. |
