John Smith 47 | 24/01/2022 21:19:56 |
393 forum posts 12 photos | Hello Is it possible to buy a spatula made for Teflon (or something similar that is totally non-stick) for spreading glue? Thanks
Robert Butler | 24/01/2022 21:49:25 |
511 forum posts 6 photos | No, glue is very sticky. Robert Butler |
John Smith 47 | 24/01/2022 22:16:42 |
393 forum posts 12 photos | Posted by Robert Butler on 24/01/2022 21:49:25:
No, glue is very sticky. Robert Butler I have a plastic Plastic Spatula Set from Pinflair. https://www.pinflair.co.uk/pinflair-plastic-spatula-set J Edited By John Smith 47 on 24/01/2022 22:28:00 |
Grindstone Cowboy | 24/01/2022 22:25:17 |
1160 forum posts 73 photos | You can buy packs of thirty or so plastic spreaders from various vendors very cheaply, use once then throw away? No good for the environment, of course. Rob |
John Smith 47 | 24/01/2022 22:26:56 |
393 forum posts 12 photos | Posted by Grindstone Cowboy on 24/01/2022 22:25:17:
You can buy packs of thirty or so plastic spreaders from various vendors very cheaply, use once then throw away? No good for the environment, of course. Rob > No good for the environment, of course.
Andrew Steward | 24/01/2022 22:28:45 |
18 forum posts | I make glue…
wooden splints, cheap as chips and not as bad as plastic, just throw them away.
as someone else said, glue is sticky. when dry / cured you may be able to peel it from the Teflon but no just don’t do it. |
Robert Butler | 24/01/2022 22:43:02 |
511 forum posts 6 photos | I have a plastic Plastic Spatula Set from Pinflair. Give them a try then or do as suggested earlier! Robert Butler |
peak4 | 24/01/2022 22:43:13 |
![]() 2207 forum posts 210 photos | I've never seen them in the UK, at a justifiable price, though ebay shows US laboratory suppliers with them, so that might be somewhere to start. https://www.coleparmer.co.uk/i/ptfe-coated-lab-spatula-w-1-5-flat-taper-x-1-25-flat-round-ends-1-pk/0636911 Edited By peak4 on 24/01/2022 22:45:29 |
Nick Wheeler | 24/01/2022 23:06:32 |
1227 forum posts 101 photos | Posted by John Smith 47 on 24/01/2022 22:26:56:
When using complex chemical mixes for critical applications - any 2 pack glue/paint/filler/rubber/etc - using one use disposable mixing cups, stirring sticks, gloves, applicators is better than buggering up the cure and effect by reusing old ones. Shop rags are the same, you don't know what it was soaked in before you tried wiping down your expensive new paint job. Edited By Nicholas Wheeler 1 on 24/01/2022 23:32:02 |
John Smith 47 | 25/01/2022 00:32:23 |
393 forum posts 12 photos | To get clear, my understanding is that absolutely nothing will stick not a nice smooth surface of PTFT (Teflon) or FEP (its transparent close cousin). J
Edited By John Smith 47 on 25/01/2022 00:41:03 |
John Smith 47 | 25/01/2022 00:36:47 |
393 forum posts 12 photos | Posted by peak4 on 24/01/2022 22:43:13:
I've never seen them in the UK, at a justifiable price, though ebay shows US laboratory suppliers with them, so that might be somewhere to start. https://www.coleparmer.co.uk/i/ptfe-coated-lab-spatula-w-1-5-flat-taper-x-1-25-flat-round-ends-1-pk/0636911 Re buying sheet solid PTFE, I rather tempted. But it's not cheap stuff. What thickness do you think would suffice? 2mm? 3mm? I have no idea how flexible and/or physically strong the stuff is. Although the Ergo Square doesn't have a handle it it might have had merit in boing thinner & much more flexible... but either way, being PTFE I guess they would be dead-easy to wipe clean. Might work (??) J Edited By John Smith 47 on 25/01/2022 01:11:30 |
John Smith 47 | 25/01/2022 01:45:26 |
393 forum posts 12 photos | Btw, what are the pros & cons of using a notched adhesive spreader? Have you ever used them? |
Pete. | 25/01/2022 01:58:26 |
![]() 910 forum posts 303 photos | Posted by John Smith 47 on 25/01/2022 00:36:47:
I've never seen them in the UK, at a justifiable price, though ebay shows US laboratory suppliers with them, so that might be somewhere to start. https://www.coleparmer.co.uk/i/ptfe-coated-lab-spatula-w-1-5-flat-taper-x-1-25-flat-round-ends-1-pk/0636911 Re buying sheet solid PTFE, I rather tempted. But it's not cheap stuff. What thickness do you think would suffice? 2mm? 3mm? I have no idea how flexible and/or physically strong the stuff is. Although the Ergo Square doesn't have a handle it it might have had merit in boing thinner & much more flexible... but either way, being PTFE I guess they would be dead-easy to wipe clean. Might work (??) J Edited By John Smith 47 on 25/01/2022 01:11:30 Wrap a small bit of clingfilm around the spatula, spread your glue, remove clingfilm and replace. |
Alan Charleston | 25/01/2022 05:07:46 |
157 forum posts 26 photos | Hi, It is possible to powder coat teflon onto a metal base. If you got a stainless steel spatula with the dimensions and flexibility you required a powder coating firm should be able to put a teflon coat on it for you. I use a piece of scrap teflon sheet to mix epoxy glue on. The wet glue sticks to it but easily peels off when it has cured. If you want the glue to not adhere to the spatula when you are smoothing it out, your best bet is to coat the spatula with a liquid which the glue won't stick to. For example, the packet my silicone sealant came in recommended dipping the tools your using in water with a bit of detergent in it. Just be careful the liquid you use doesn't interfere with the adhesion properties of the glue - silicone oil would be a definite NO I would guess. Regards, Alan C. |
pgk pgk | 25/01/2022 06:30:17 |
2661 forum posts 294 photos | Perhaps the answer is to go back to biodegradable glues - hide or pine resins or bluebell mucilage or egg proteins spread with wood or cardboard spatulas and then composted. pgk Edited By pgk pgk on 25/01/2022 06:37:01 |
JasonB | 25/01/2022 07:18:09 |
![]() 25215 forum posts 3105 photos 1 articles | Why not use some scraps of ABS or rubber, it seems none of your glues will stick to that, allow to set and peel it off any residual glue so you can use again. Just cut a strip from a Poly Prop bottle or container and put it back in the recycling after use. Notched or comb spreaders give a more measured and constant film thickness. If you use a flat spreader it is hard to tell if you have the same amount of adhesive over the whole surface. A notched one will leave a constant height bead and remove the rest of the adhesive between notches so when you put the parts together those beads spread to an even thickness. I used notched spreaders a lot for work. These days Vegans may not approve of some of the old adhesives PGK suggests
Edited By JasonB on 25/01/2022 07:51:56 |
Danny M2Z | 25/01/2022 08:27:06 |
![]() 963 forum posts 2 photos | Posted by John Smith 47 on 24/01/2022 21:19:56:
Hello Is it possible to buy a spatula made for Teflon (or something similar that is totally non-stick) for spreading glue? Thanks Actually, you might want to consider what the English Ashes team use to coat their gloves with as nothing sticks to that. I heard that Novac J is being considered as a batting coach for the English cricket team as it took almost two weeks to get him out. For spreading epoxy, nothing beats an old credit card.
Martin Kyte | 25/01/2022 08:44:20 |
![]() 3445 forum posts 62 photos | The main requirements are that the spatula should be flexible and very smooth. The peel strength of most glue is fairly low so with a flexible spatula the spatula can be peeled off the glue. regards Martin |
pgk pgk | 25/01/2022 08:45:44 |
2661 forum posts 294 photos | Posted by JasonB on 25/01/2022 07:18:09:
These days Vegans may not approve of some of the old adhesives PGK suggests Forget the hide glues and eggs then - how about human donated mucilage? Finally a benefit from collecting Covid snot ( could also save all the norovirus product from cruise ships and bring back biosolid housing)
Edited By pgk pgk on 25/01/2022 08:46:04 |
Michael Cox 1 | 25/01/2022 09:36:13 |
555 forum posts 27 photos | I save the wooden stirrers from Costa coffee for mixing epoxy adhesives. The small tubs of milk supplied with a cup of tea in some cafes I also take home and wash. These make excellent pots for mixing small quantities of Epoxy adhesive. Mike |
