a rogue method?
brian jones 11 | 19/08/2021 12:05:43 | ||
347 forum posts 62 photos | I have seen vids of using diving head for use with a milling form tool for cutting a spur gear say 3" dia, 1/4" thick with say 80 teeth OMG what a painfully slow process as you mill each one Yes there are powered head linked to spindle to cut these also - v expensive attachment Now I was looking at some large bsw plugs taps i have and wondered if these might work Then I saw a vid on making worm gears using this method, where the blank is mounted freely rotating on a mandrel. The rotating tap held in a lathe chuck and the blank is brought crossways to meet the tap. The action of the tap screws the blank around as it cuts and you end up with a worm gear which can be operated by a bolt https://www.youtube.com/watch?v=XIzlg_uObwQ Now I can see the FES going nuclear on this Yet I have not found a vid on using this technique for a spur gear Consider a 3/4" bsw x 10 tap on a 3" x 1/4" thick blank gives ca 100 teeth So the tap is mounted in the spindle and the blank on a horizontal mandrel First pass will get the thread depth, then the bed will be slid across on the x axis to get a flat bottom for the tooth form (I think) Primitive but very quick and only suitable for light load low speed apps and probably noisy put them in a gearbox with heavy oil and used nylons or sawdust Anyone ever tried this Seems too good to be true
speelwerk | 19/08/2021 12:20:30 | ||
464 forum posts 2 photos | Why spending time on making if you can buy them for little money, plenty of suppliers, see **LINK** Niko. | ||
brian jones 11 | 19/08/2021 12:37:45 | ||
347 forum posts 62 photos | followed up on Madler website, very comprehensive, BUT I cannot see how to buy anything, no on line shopping cart or any hint of a sales facility I am lost here pls advise
John Haine | 19/08/2021 12:37:57 | ||
5563 forum posts 322 photos | See **LINK** Also several threads on this site about variations of the process including what you describe, also known as free hobbing. | ||
John P | 19/08/2021 12:51:52 | ||
451 forum posts 268 photos | Posted by brian jones 11 19/08/2021 12:05:43
That's probably because it is ,the way forward is for you to give it a try Most good engineering requires some commitment in time and inevitably | ||
speelwerk | 19/08/2021 12:52:46 | ||
464 forum posts 2 photos | Posted by brian jones 11 on 19/08/2021 12:37:45:
You select Branche Offices at the top of the page, find the UK distributor and contact them. Niko.
Andrew Johnston | 19/08/2021 14:44:11 | ||
![]() 7061 forum posts 719 photos | Posted by brian jones 11 on 19/08/2021 12:05:43:
Seems too good to be true The method mentioned works fine for cutting worm wheels, although spiral flute taps are helpful: Getting the correct number of teeth is a bit hit and miss. One can free hob a worm wheel, but it needs to be pre-gashed: For spur gears it's a useless method. First, the work would need to be swivelled to the helix angle of the tap in order to get straight teeth on the gear. Second, the work would need to be rotated at the appropriate rate, same as when using a hob. Third, the tooth form would be non-standard, and the gear would only work with other gears made by the same tap. It doesn't take that long to cut spur gears by conventional methods, provide one gets on with it rather than pontificating on forums, two gears at a time in this case: If I want a quick gear, and don't have the appropriate cutter, I simply design it in 3D CAD and let the 4-axis CNC mill get on with it. As was the pinion: For mating with this internal gear: Andrew | ||
John Haine | 19/08/2021 15:40:43 | ||
5563 forum posts 322 photos | Posted by Andrew Johnston on 19/08/2021 14:44:11:
Seems too good to be true ........ For spur gears it's a useless method. First, the work would need to be swivelled to the helix angle of the tap in order to get straight teeth on the gear. Second, the work would need to be rotated at the appropriate rate, same as when using a hob. Third, the tooth form would be non-standard, and the gear would only work with other gears made by the same tap.
Andrew For larger tooth counts the tooth form will surely be involute as the tap is in effect a rack form cutter? But indeed the pitches will not mesh with other "standard" gears. A 10 tpi tap as the OP suggested would cut teeth of ~31.15 DP which isn't any kind of standard, and pressure angle 27.5*. | ||
brian jones 11 | 19/08/2021 16:07:14 | ||
347 forum posts 62 photos | Posted by speelwerk on 19/08/2021 12:52:46:
I did this already but it just takes me back to the inert Madler website try the link yourself
JasonB | 19/08/2021 16:28:21 | ||
![]() 25215 forum posts 3105 photos 1 articles | I feel like giving up sometimes, why not just got to the web address for Huco that is in Speelworks posted image, then go to products and then gears which give you this. Do you need more help getting to a specific type of gear? Personally I find the ones from Belting online very reasonable, MOD are cheaper than DP. | ||
brian jones 11 | 19/08/2021 16:37:38 | ||
347 forum posts 62 photos | Well I shall try out this free hobbing method I agree the gears will only mesh with others produced by the same tap but it will be interesting to see how two such gears perform together and if they would suffice for light duty dont you think and BTW I belong to the school of thinking first and asking around before making chips, unlike the suck it and see brigade. quote It doesn't take that long to cut spur gears by conventional methods, provide one gets on with it rather than pontificating on forums as per AJ with his superior minded 4 axis CNC machine Obviously forgotten how long it does take to cut spur gear - the point of my original post = as they used to say "read the question carefully first, dont give an answer you would like to be asked." I was just thinking out of the box | ||
brian jones 11 | 19/08/2021 17:42:10 | ||
347 forum posts 62 photos | Posted by JasonB on 19/08/2021 16:28:21:
I feel like giving up sometimes, why not just got to the web address for Huco that is in Speelworks posted image, then go to products and then gears which give you this. Do you need more help getting to a specific type of gear? Personally I find the ones from Belting online very reasonable, MOD are cheaper than DP. Its not helpful to throw a hissy fit, I did this already this is the link from the pic above http://www.maedler.co.uk/ try it yourself, for me it just leads to a dead end back to germany being given a dead link is very frustrating and wastes a lot of time you found your link by doing a separate search for Huco | ||
Dave Halford | 19/08/2021 17:59:55 | ||
2536 forum posts 24 photos | Posted by brian jones 11 on 19/08/2021 16:37:38:
Well I shall try out this free hobbing method I agree the gears will only mesh with others produced by the same tap but it will be interesting to see how two such gears perform together and if they would suffice for light duty dont you think and BTW I belong to the school of thinking first and asking around before making chips, unlike the suck it and see brigade. quote It doesn't take that long to cut spur gears by conventional methods, provide one gets on with it rather than pontificating on forums as per AJ with his superior minded 4 axis CNC machine Obviously forgotten how long it does take to cut spur gear - the point of my original post = as they used to say "read the question carefully first, dont give an answer you would like to be asked." I was just thinking out of the box There's a thread on here where someone free hobbed with a tap, if I remember correctly the tooth count was wrong (as in fractional teeth) till the blank was much smaller than required. | ||
not done it yet | 19/08/2021 18:09:48 | ||
7517 forum posts 20 photos | try it yourself, for me it just leads to a dead end back to germany There is a phone number quite clearly indicated and easily called. Why not call it? Seems a simple enough way to get sorted? A lot of people seem to miss the simple options to sort out a problem. | ||
JasonB | 19/08/2021 18:19:27 | ||
![]() 25215 forum posts 3105 photos 1 articles | Posted by brian jones 11 on 19/08/2021 17:42:10:
I feel like giving up sometimes, why not just got to the web address for Huco that is in Speelworks posted image, then go to products and then gears which give you this. Do you need more help getting to a specific type of gear................ ......................you found your link by doing a separate search for Huco
No as I said it's in the image Speelwork posted, You have even highlighted what I said in your quote! "why not just got to the web address for Huco that is in Speelworks posted image" NOT LINK I've highlighted it for you, can't really make it any clearer.
Edited By JasonB on 19/08/2021 18:42:40 | ||
speelwerk | 19/08/2021 20:15:23 | ||
464 forum posts 2 photos | Posted by JasonB on 19/08/2021 18:19:27:
Edited By JasonB on 19/08/2021 18:42:40 I ordered from Madler Germany directly or from their Dutch branche Koppe, for little money they even made it to your spefication, all very friendly and helpfull, just phone or mail them. Do not know of course about Huco but expect them to be the same. Niko. | ||
Phil super7 | 19/08/2021 20:35:36 | ||
24 forum posts | I Recall this method of using a tap to cut a worm wheel was used in an article in MEW some time ago, The article was precise angle adjustment of the table on the Worden T&C Grinder I tried it out worked beautifully. Edited By JasonB on 19/08/2021 20:47:10 | ||
Andy Stopford | 19/08/2021 20:51:38 | ||
241 forum posts 35 photos | Posted by brian jones 11 on 19/08/2021 12:05:43:
OMG what a painfully slow process as you mill each one Not really. It depends what machine you have, and what material you're using, but if you use a proper gear cutter I wouldn't say it was painfully slow, and a lot easier than trying to jury-rig something with a tap. Home-made single tooth cutters are slow and tiresome, but work if you don't want to fork out for a proper gear cutter. Another approach if you don't have a mill is to use a single-tooth cutter in the lathe toolpost, shaper-wise. That really would be painful, but again, you'd get there in the end (I haven't tried that one myself, but I don't see why it shouldn't work given sufficient patience). I have made gears using a proper shaper and a home-made cutter. It works fine, but it's very easy to forget to wind the toolholder back up before indexing to the next tooth. Result - a loud bang as the shaper punches out the entire tooth* in one go, but, surprisingly no discernible difference in tooth quality, at least with benign materials like nylon or bronze. Best avoided though I think. *Really the gap between teeth of course | ||
Andrew Johnston | 19/08/2021 21:02:53 | ||
![]() 7061 forum posts 719 photos | Posted by John Haine on 19/08/2021 15:40:43:
For larger tooth counts the tooth form will surely be involute as the tap is in effect a rack form cutter? Fair point. The teeth on the worm wheel I free hobbed with a tap look triangular. But the wheel is quite small (~1/2" diameter) so any involute curvature will be also be small. The tap was UNF so the pressure angle will be 30°. Since the tap form is triangular the gear teeth will tend to a triangle rather than the more familiar rack form. No doubt gears made by the same method will run together but there will be significant forces pushing them apart. The small worm wheel shown is for a speed adjuster on a Pickering governor, so I doubt it'll ever get turned: Andrew | ||
Andrew Johnston | 19/08/2021 21:32:47 | ||
![]() 7061 forum posts 719 photos | Posted by brian jones 11 on 19/08/2021 16:37:38:
I belong to the school of thinking first and asking around before making chips.........
Unfortunately you seem to have mislaid the first step. If the tap is skewed by the helix angle to get straight teeth on the gear how does it drive the gear blank as there will be no tangential force. The tap drives a worm wheel because it creates teeth that are not straight and hence there is a force causing the blank to rotate. Andrew |
