Ron Hancock | 19/09/2014 21:12:50 |
![]() 526 forum posts 95 photos | Hi can anyone tell me what welding rods to use for welding 5 inch boiler. I am building from scratch think it will be easier than Gas and hope its cheaper to, i have looked at welding site but list's three different types of Rods Ron |
Steambuff | 20/09/2014 07:37:31 |
![]() 544 forum posts 8 photos | Ron, One quick 'side' question, are you a member of a ME club or plan to run in public? If so you need to speak to your boiler inspector first. (I think you need to be a coded welder and/or provide samples as well) Dave
fizzy | 20/09/2014 10:28:50 |
![]() 1860 forum posts 121 photos | Hi Ron I don't mean to be rude but if you have to ask this question then you don't have a hope in heck of welding a boiler. Sorry but that's just how it is - it would never be steam tight and most certainly wouldn't pass a test. Im not being negative, im being realistic, honestly I am. Have a look at one of my old posts where I build a boiler for under £200 and you might see where I am coming from. Having said this I will offer some help.
Rod type is governed by boiler material type. If its a copper boiler you will need an industrial water cooled tig set to get the amps needed for that thickness, 250 amps or above - and that makes it 3 phase. the copper must all be deoxy - or it will crack - fact! You need a good understanding of weld prep. You will also have to completely redesign the boiler and have the design approved as you can not weld up a boiler which was designed to be soldered, the joints are all completely wrong. Then theres the aspect of ability and/or qualifications...
On the other hand, if it is to be used and seen only by you, you can do whatever you like - but it will leak! Steel is far more forgiving, much easier to work, loads cheaper and you can just about use a non professional weld set for it....but again, unless you are an extremely experienced welder it will leak! |
Ron Hancock | 20/09/2014 11:34:26 |
![]() 526 forum posts 95 photos | Hi Thank you for feedback no i am not a coded welder i did used to be a gas welder Arc welder and Mig welder for many years. Having said that i was not going to do it myself my son who welds alloy and stainless all day long was going to do it for me. I just have to buy the rods for him so he can take to work and do in his breaks for me. Thanks for the advice Ron |
Circlip | 20/09/2014 11:34:58 |
1723 forum posts | Oh dear, Machine Mart strikes again. It was bound to happen (and prophesied) once the disposable income brigade were able to buy cheap professional (???) equipment for "Gluing" metal together. For "Welding pressure vessels", the term Coded welder comes into operation. Ran a fabrication shop with a dozen welders, three were "Coded" and only one of the three "Coded" to weld approval for British Rail. You're allowed to blow yourself up but Insurance companies/HSE get really naffed off if you attempt to injure the innocent unwashed.
Regards Ian.
Edit, Just read the "welds Stainless and Alloy all day long", Yes so could ALL of mine. Edited By Circlip on 20/09/2014 11:37:41 |
JasonB | 20/09/2014 13:14:54 |
![]() 25215 forum posts 3105 photos 1 articles | Ron, this is Fizzy's thread where he shows the build of his boiler. As you can see it can be done without a coded welder provided the joints pass a relatively inexpensive test. J |
John Baguley | 20/09/2014 13:47:34 |
![]() 517 forum posts 57 photos | Jason, You will probably know the answer to this as I know the traction engine people do this quite often. If I provide all the materials cut out, do the weld preps etc. and then pay a welder to stick it all together for me, what's the situation regarding CE marking of the boiler. Is it necessary, in other words, would it still be classed as a home built boiler? I need to get a new copper boiler made for a 5" loco (KIng) that I am completing for a friend who runs a small engineering business. He has a coded welder come in to do work for him on a regular basis and he would be more than capable of Tig welding it all together. To say he was good would be an understatement! Our club boiler inspectors say they would not have a problem testing it so long as material certs were provided and copies of the welders qualifications etc. John |
JasonB | 20/09/2014 14:08:22 |
![]() 25215 forum posts 3105 photos 1 articles | Thats one of the grey areas, by paying for it are you paying (a Professional) for a boiler or a service? You would also need to check who holds the codes for that welder, I think most are actually held by the employer and only an independant welder whould have his own codes and insurance. Though it sounds like this welder may have his own codes. Maybe Fizzy can confirm. Also he would need to have the correct codes for this type of work I don't think someone coded for say structural steel will be coded for a pressure vestle These two facts make it a bit iffy to say the welds don't need checking as they have been done by a coded welder, better idea would be to pay the little bit extra and have the welds tested and present these test certs to the boiler inspector. CE only applies when a product is sold, as you have not bought a complete boiler CE will not apply. J |
John Baguley | 20/09/2014 14:28:31 |
![]() 517 forum posts 57 photos | Thanks Jason, That's all useful to know. We'll look into all of it before going ahead. I would imagine the guy has his own codes as he does work for a lot of companies, often stuff that other welders won't/can't touch due to lack of expertise. John |
Mark C | 20/09/2014 14:42:34 |
707 forum posts 1 photos | It's interesting reading the comments about coding and experience etc. About 25 years ago I was lucky to be on a visit to Compare in Cornwall and see the robotic welding station welding up the seam joints (the long one up the side), I wonder if it was coded as it was not having its welds 100% inspected but the receivers did all get a test cert. Mark |
fizzy | 20/09/2014 19:06:10 |
![]() 1860 forum posts 121 photos | John/Jason - Going by my understanding you are NOT allowed to pay someone to weld the boiler as by doing so it is then deemed a professional job and the insurance company wont touch you - mad though this is! The codes always have the welders name on them, the company might have paid for them and own them but they are named individuals. I don't know if your inspector will allow an NDT cert - mine does as he knows my history of being a welder and so this is realy just a formality to satisfy the book, but don't be surprised if a different inspector takes a different view, especially an egotistical pillock who knows nowt about boiler making, and believe me, there are lots of them around! If its copper my choice would be SIFSILCOPPER NO 7. Remember what I said about amps though - it saps heat like nothing else! I wouldn't tig the tubes either, I solder them so I can remove them easier. And run the redesign by your inspector first. |
Ron Hancock | 20/09/2014 19:49:02 |
![]() 526 forum posts 95 photos | Some how don't think my Son would charge me.
Plus it's his Loco as well but i do most of the Work.
Suprised as only wanted to know grade of Rods so i can have for when he is back of Holiday
fizzy | 20/09/2014 19:51:16 |
![]() 1860 forum posts 121 photos | Ron _ I was answering a question above, not suggesting you would have to pay!! that SIFSILCOPPER NO 7 is the grade of rod - but be warned, they are not cheap!
Ron Hancock | 20/09/2014 20:36:16 |
![]() 526 forum posts 95 photos | Not sure if silver solder would be a lot more !! I like the Idea of Tig as at any time you can reweld not like Silver Solder. Plus like the idea of my son doing the hard bit !!! Ron |
julian atkins | 20/09/2014 22:06:41 |
![]() 1285 forum posts 353 photos | it is perhaps unfortunate that Ron's request for help hasnt had a more positive result apart from Fizzy. all Ron is seeking to do is buy in advance the rods required for his very experienced TIG welding son to do the necessary. from what i understand Ron's son has all the necessary qualifications and experience to satisfy Ron's club boiler inspector. im not a fan of TIG welded boilers, and Fizzy's comments regarding need for deoxidised copper are essential, plus strict adherence to whatever the club boiler inspector may require as the job progresses. cheers, julian |
Ron Hancock | 20/09/2014 22:57:57 |
![]() 526 forum posts 95 photos | Hi Julian thank you for your comment i am glad you understand. I had agreed with club i would take it in at every stage to be checked. After tonight i have decided on this boiler to Gas weld. I am hoping to start soon a 7 1/4 i will then use a steel boiler. I am thinking of building a K4 finally found my dad's Loco and would love to build one in his memory. I used to go on the foot plate regular from around 5 years old. It looks like a nice tender engine if i had known which one before i started the Simplex i would have defiantly built that one. Your word's ring in my ears build one you really want but did not know till today witch one it was long time ago. Would love to find other Loco they used it was a lot bigger and dreadful with a heavy load i remember big plates on front just kept spinning wheels to get going. It was more like an express and may have been. Sure in time i will find out as i learn more. Are you going to the Warwick show next month Julian. Thank you again Julian Ron |
Carl Wilson 4 | 21/09/2014 06:28:17 |
![]() 670 forum posts 53 photos | Posted by julian atkins on 20/09/2014 22:06:41:
The negative posts were quite frankly typical of some of the fairly bonkers posts that are made on here. |
Vic | 21/09/2014 10:29:18 |
3453 forum posts 23 photos | Posted by Carl Wilson 4 on 21/09/2014 06:28:17:
The negative posts were quite frankly typical of some of the fairly bonkers posts that are made on here. Agreed Carl. It's a shame but some folks seem to get pleasure by deriding others. An apology or two normally smooths these things over but are not often forthcoming. |
Bob Brown 1 | 21/09/2014 11:24:30 |
![]() 1022 forum posts 127 photos | I have no problem with TIG welding and would be fine if the correct materials and filler rods are used be it copper or steel. OK there are some rules to follow if intend to run an engine in a public area but not insurmountable. Negative comments are usually by people that do not understand the process or just too set in their ways. Just because something has been done in a particular way does not mean that it is the only way or the best, it's called progress.
Bob |
Circlip | 21/09/2014 11:37:26 |
1723 forum posts | " The negative posts were quite frankly typical of some of the fairly bonkers posts that are made on here. " Yes and the ultimate negativity is the refusal of an insurance certificate for what "Seemed like a good idea at the time". Better to warn of the Cons rather than be glassy eyed at the Pros. By far the greatest profit in the case of litigation doesn't go to the injured parties but does come out of the pocket of the offender. Ultimately, the original poster weighs any advise freely given by all parties and makes his own decision.
Regards Ian. Edited By Circlip on 21/09/2014 11:37:51 |
