In - Out, Back - Forward,
OuBallie | 13/09/2014 13:39:31 |
![]() 1181 forum posts 669 photos | 'End of World still Nigh' but need to keep myself occupied while waiting. I have fitted two DPDT 3-position toggle switches to the FeedRodMotor remote station; 1) Left/Off/Right for the Saddle movement selection, 2) ?/Off/? for the Cross-slide ditto, but how to label it is the question. Is there a standard for describing the movement? The 'net has a selection as usual. The same applies to the Y-axis on a milling machine as well. This is something I've never bothered with beforehand, but pedant gene is being awkward and in a huff right now. Geoff - How long does a %#*+ head cold last? |
Ed Duffner | 13/09/2014 14:20:56 |
863 forum posts 104 photos | How about? - Advance / Off / Retard - Plunge / Off / Withdraw - Advance / Off / Withdraw - In / Off / Out - Cut / Off / Back-Out - ^ / Off / v
Peter G. Shaw | 13/09/2014 15:56:26 |
![]() 1531 forum posts 44 photos | I would say "In-OFF-Out" because for most jobs, one moves the the tool "in" to make the cut, and "out" at the end. Advance, Retard, Plunge all seem to imply a different type of operation to me, although they could apply here. Cut, Back-out & Withdraw would be be more applicable I think than the first three, but overall I would go for the In-Out option. I have read at least one author talking about "putting the cut on", but I don't recall taking the cut off. For milling, I would use Forward-OFF-Backward as in Forward = away from you and Backward = towards you. The trouble with milling is that cutting can take place equally well in either direction, whereas in lathework, most work involves either doing something to a longitudinal external diameter, or facing a disc. Cutting an internal diameter does involve cutting the other way round, but in my limited experience is less often done. Regards, Peter G Shaw
David Colwill | 13/09/2014 16:30:29 |
782 forum posts 40 photos | I would say X- (slide moving away) off X+ and Z- off Z+ but that's just me David. |
colin hawes | 13/09/2014 17:07:00 |
570 forum posts 18 photos | The convention used for CNC programming is left-to right axis -X table moves to left.......+X table moves to right in and out axis -Y table moves out (towards operator) in and out axis +Y table moves in (away from operator) Vertical axis +Z tool moves up ..............-Z tool moves down That's the way I remember it anyway so the cross slide on a lathe would be +/- Y. Colin |
Andrew Johnston | 13/09/2014 19:58:16 |
![]() 7061 forum posts 719 photos | What Colin describes is true for a CNC mill, but is not true for a lathe. The convention for a CNC lathe is cross travel is X, axial travel is Z and live tooling is specified as the C axis. Regards, Andrew |
colin hawes | 13/09/2014 21:09:21 |
570 forum posts 18 photos | Andrew. thank you for the lathe axis description I've only worked with CNC machining centres so I am pleased to learn a little more. It's a useful forum. Colin |
jason udall | 13/09/2014 21:20:08 |
2032 forum posts 41 photos | On lathes also x+ leaves more metal as does z+...the z axis is generaly "common" to mills..the pseudo y axis for live tooling/milling is a interpolation of x and c axes...the z y plane can also be programmed "wrapped" round the part...again a interpolation of x z and c..lathes with y axis do exist but these are generally deemed machining centers and these have many axis not conveniently named |
OuBallie | 15/09/2014 09:37:55 |
![]() 1181 forum posts 669 photos | Thanks for the responses guys, much appreciated. As usual, the mind boggles at the way English can be used to describe something in a multitude of different ways, and all meaning/describing the same thing. I will give Ed's arrows a try first, and see how I get on with them. Geoff - Head cold clearing, so End of World NOT Nigh |
jason udall | 15/09/2014 11:20:43 |
2032 forum posts 41 photos | Arrows point ing in the direction of motion... Yep...no need to remember what it means..so at a moment of stress no chance of error. ..all good |
Howard Lewis | 10/10/2014 00:03:23 |
7227 forum posts 21 photos | With the Common Cold, the rule is: If you do nothing, it will go after seven days. If you take medication, you will be rid in a week! I favour the ideas of arrows, unlikely to be misunderstood. Howard |
Howard Lewis | 10/10/2014 00:03:29 |
OldMetaller | 10/10/2014 08:04:06 |
![]() 208 forum posts 25 photos | I now have The Hokey Cokey as an earworm... D'oh! Regards, John. |
Oompa Lumpa | 10/10/2014 08:18:37 |
888 forum posts 36 photos | Posted by OldMetaller on 10/10/2014 08:04:06:
I now have The Hokey Cokey as an earworm... D'oh! Regards, John. I am not impressed John. You have now given it me. Bugger. graham. |
