valve grinding suction pads
mick09/08/2014 15:27:09
421 forum posts
49 photos
I feel sure someone will know, but where can I get hold of a small diameter suction pad to grind in eighteen inlet and exhaust valves? The valve head diameter is 11mm./ 7/16''.
Bazyle09/08/2014 15:56:18
6956 forum posts
229 photos
Not sure about size but some kind of childs arrow / dart springs to mind if they are still make like they used to be. Alternative might be something like a low strength glue, double sided tape, or bluetack.
Michael Gilligan09/08/2014 16:06:53
23121 forum posts
1360 photos
Mick,
At that small size, you might find it worth investigating the tips that are used on suction pick-up tools.
Harry Wilkes09/08/2014 16:13:52
1613 forum posts
72 photos
Picked up mine from local car spares shop and I'd bet Halfords would stock them as well !
Michael Gilligan09/08/2014 16:25:11
23121 forum posts
1360 photos
Posted by Harry Wilkes on 09/08/2014 16:13:52:
Harry ... in that size? ... I'm amazed.
maurice bennie09/08/2014 16:48:25
164 forum posts
Hi Mick I wonder if a button magnet on a metal extension rod would work ?
Maurice.
maurice bennie09/08/2014 16:55:00
164 forum posts
Hi Mick again I think not on second thoughts if you have a steel barrel.
brain not in gear Maurice?
JasonB09/08/2014 16:57:03
On small IC engine valve I slip a bit of silicon tube onto the top of the valve and then poke a suitable rod into the other end then you can twist it between finger and thumb while lightly pulling the valve onto its seat. Also use something with a finer grit than teh standard paste sold in car shops on small valves like this.
Though my prefered way is to leave the valve on the parent bar so you have something solid to hold and then part off once its seated, like this one where you can see the dull area that has been ground with 600g SiC powder.
Phil Whitley09/08/2014 21:14:13
1533 forum posts
147 photos
there used to be available a T shaped handle that clamped to the stem of the valve after it had been inserted into the guide, you could then pull it onto the seat and recut with grinding paste You could make something up like that?. even if you find a sucker that size it will be virtually useless, the big ones can be a P ing the A.
Windy10/08/2014 00:26:40
910 forum posts
197 photos
With my poppet valve made out off a car exhaust valve it is non magnetic so magnets no good.
As far as semi rotating the valve for lapping with grinding paste the short section of the valve stem at the collet end I can twist in my fingers no need for anything special to hold it.
With your design of engine it might not be possible?
Paul
Clive Hartland10/08/2014 08:33:53
2929 forum posts
41 photos
While grinding in a valve seat I dont ever do a full rotation of the valve! I do it in small arcs and then lift and do another section. A small valve can be done with finger pressure quite easily.
Circlip10/08/2014 08:49:19
1723 forum posts
In the dim and distant, some valves (Full size) had a screwdriver slot cut in the head, t'aint missile tech. to use a dremel to achieve a similar result.
Regards Ian.
mick10/08/2014 09:42:45
421 forum posts
49 photos
Valves are stainless steel, so magnets aren't an option, also the valve head is 0.075'' thick, so a screw driver slot isn't any good either, I was hoping for an easy solution, so back to the drawing board, it'll be a bit tedious, but some form of bonding might have to be the way forward.
Gordon W10/08/2014 10:24:23
2011 forum posts
Could you not make one or two? A soft rubber or plastic tube glued to a dowel with a short length of tube overhanging and cut square . works ok on a one off but how long it would last I suppose will depend on the tube material. Or use a soft plastic and bore, form the end with a ball cutter ? Trouble is there will not be much air pressure at that diameter so holding is never going to be good.
John Shepherd10/08/2014 10:35:51
222 forum posts
7 photos
Perhaps pads made out of SUGRU might do the job?
http://sugru.com/buy/?gclid=CIfcrOSxiMACFfMZtAodilcAGQ
Mike Poole10/08/2014 10:52:30
3676 forum posts
82 photos
I have used a drill chuck on the valve stem in the past, it might speed things to leave the drill on it! Might be a bit quick though.
Cornish Jack10/08/2014 10:57:06
1228 forum posts
172 photos
Would the suction pads used for removing halogen light bulbs be adaptable?
Rgds
Bill
Gordon W10/08/2014 11:06:44
2011 forum posts
Double sided sticky tape, can even be bought ready cut in circles.
Clive Hartland10/08/2014 12:14:55
2929 forum posts
41 photos
Double sided sticky tape, you can also buy circular pads of Velcro, stick one on the valve and its partner on the stick, simples.
Why didnt I think of that!
Hopper10/08/2014 12:53:14
7881 forum posts
397 photos
Is it necessary to grind the valves in at all? Modern automotive practice is to cut the seats, face the valve and put it together without grinding in. They use a three angle seat cut with a very narrow seating ring about 1mm wide. Seems to work just fine on the full size stuff. Will it not apply to the tiddlers?
