mick H | 12/05/2014 18:45:14 |
795 forum posts 34 photos | Can anyone tell me please whether or not it is possible to obtain flexible tubing that can withstand say 4 Bar pressure......something along the lines of braided flexible tap connectors but much finer....about 1/8" to 3/16". I would like to incorporate it into an air testing rig for small locos. I usually make do with 1/8" copper but it kinks easily and lacks flexibility when the loco has to be moved for adjustments etc. I have also tried rubber tubing but this suffers from ballooning or is otherwise too thick to give much flexibility. |
maurice bennie | 12/05/2014 18:55:10 |
164 forum posts 1 photos | Hi Mick Have you tried flexible car brake pipe used on most kit cars. Maurice. |
Neil Wyatt | 12/05/2014 18:58:37 |
![]() 19226 forum posts 749 photos 86 articles | I'm sure you could find something here: The clear vinyl tube is rated to 2.7 bar and goes down to 1/8 inch. I cant find braided-reinforced nylon tube less than 1/4 on that site, but I know In have seen it in very small sizes. Neil Edited By Neil Wyatt on 12/05/2014 19:02:50 |
JasonB | 12/05/2014 18:59:47 |
![]() 25215 forum posts 3105 photos 1 articles | The plastic pnumatic tube will take 10bar plus and you can get easy to use push fit connectors, something like this unless you have a specific need for braided Edited By JasonB on 12/05/2014 19:01:53 |
Nick Hughes | 12/05/2014 19:02:34 |
![]() 307 forum posts 150 photos | Hi Mick, Try Goodrich hoses as listed here:- **LINK** The 600-02 has a 2mm bore and a 5mm dia over the outer braid. This does tend to be expensive, but is probably the best and I've used Goodrich on my motorcycles for years. Nick. |
WALLACE | 12/05/2014 19:12:52 |
304 forum posts 17 photos | It's a bugger to cut ! I've found a thin metal cutting disc in the angle grinder best - but will need flushing out to remove any cutting debris W. |
Bob Brown 1 | 12/05/2014 19:20:36 |
![]() 1022 forum posts 127 photos | Stainless steel braided Teflon hose (brake hose) is certainly an option, pressure is not a problem as it is good for +250 bar working pressure and should be OK for the temperatures just over 250 degree C. It is normally sized by dash number which is in 1/16" increments so -3 is 3/16. You should also be able to get snap connectors to make connecting things up very easy. I find it reasonable to cut if you wrap the cut in tape and use a fine toothed saw, done it quite a few times in my motor sport days (rally cars) Bob Edited By Bob Brown 1 on 12/05/2014 19:22:45 |
fizzy | 12/05/2014 19:39:14 |
![]() 1860 forum posts 121 photos | wrap it tightly with insulation tape then cut through the tape - stops it flaring. |
Oompa Lumpa | 12/05/2014 20:02:09 |
888 forum posts 36 photos | Posted by Bob Brown 1 on 12/05/2014 19:20:36:
I find it reasonable to cut if you wrap the cut in tape and use a fine toothed saw, done it quite a few times in my motor sport days (rally cars) Bob Edited By Bob Brown 1 on 12/05/2014 19:22:45 Showing your age there Bob. I use a very good quality pair of sidecutters and as Fizzy suggests, wrap it in tape where you want to cut. Like Bob, I cut (what seemed like) miles of this stuff back in the day and I must say, using Goodrich or Earl's fittings I never had a failure. graham. |
Bob Brown 1 | 12/05/2014 20:20:35 |
![]() 1022 forum posts 127 photos | Wot's age got to do with it I did a race car for a mate back end of last year with the stuff! It certainly does not come off very easily unless you want to remove the fitting, I've had a wheel smashed off the car and half the suspension wrecked but the caliper was still attached to the car by the hose |
mick H | 12/05/2014 20:56:54 |
795 forum posts 34 photos | Brilliant gents, thanks very much for all that. Now off to do a bit of homework on what you have flagged up. Mick |
