Recycling a CH pump
Roger Hart | 11/04/2014 10:44:04 |
157 forum posts 31 photos |
A few bits from the junkbox and a silver steel shaft to replace the 10mm ceramic shaft and some ball races (ex junkbox). The inner stainless shield and ceramic bearings were discarded although the new shaft did run fairly ok in the ceramic bearings. A very handy little grinder, just needs a simple grinding rest now. A warning though, the rotor is jacketed in stainless steel and has sharp edges - be careful, I found out the hard way.
JasonB | 11/04/2014 11:34:47 |
![]() 25215 forum posts 3105 photos 1 articles | Hope its going to get some suitable guarding as well |
Oompa Lumpa | 11/04/2014 13:10:32 |
888 forum posts 36 photos | I have something very similar to this arrangement but I have progressed to actually having a little table on mine AND an actual toolholder - with degrees - that slides along the table. One day there is going to occur a sort of nuclear fusion/explosion in my shed and all of the bits of my T&C grinder are all going to miraculously come together in one cataclysmic event! (I hope I have never seen a "guard" on one of these style of grinders and I would wonder how you could actually fit one, that would be of use and not hindrance. To my recollection I have not seen one fitted to any of the Quorn grinders, not safety guards anyway. graham. |
JasonB | 11/04/2014 13:12:47 |
![]() 25215 forum posts 3105 photos 1 articles | I'm sorry if you see it that way John but as a moderator I feel a certain responsibility to MHS and more so to the beginner who may see such a post and rush out to the workshop this weekend to make a similar grinder and possibly mount a grit wheel to it. I don't care what Roger or you for that matter what to do in your shed but when its made public I would hope the poster feels a duty of care to others who may follow suit. If they don't then thats one of the roles of a moderator. Should I also keep quiet if someone posts a boiler that has been soft soldered from thinwall tube, no stays and has no safety valve and intends to run it at 100psi? J |
jason udall | 11/04/2014 13:14:26 |
2032 forum posts 41 photos | Nice conversion. .ceramic bearings eh..... Does it have the speed/torque..seem to remember these things are stallable..might even be an advantage.... |
GarryC | 11/04/2014 13:41:06 |
![]() 740 forum posts 1043 photos | "Why oh why do people who have nothing to offer the post and have nothing else to boast about just jump in to keep their name alive?" Well out of order John. Sounds like 'a moment of madness' to me and for very obvious reasons concerning Jason - but we've all done that! Jason's contribution to this forum is immense - think you should apologise...just my opinion. Looks very nice Roger. Regards, Allan. Edited By Allan. on 11/04/2014 13:41:36 Edited By Allan. on 11/04/2014 13:45:45 |
Neil Wyatt | 11/04/2014 19:25:33 |
![]() 19226 forum posts 749 photos 86 articles | Hey, let's not start a flame war here! Jason and John have both explained their positions. It's reasonable for Jason to comment on the guarding as beginners do copy what they see on this forum and in print. It's also fair comment by John that the poster could have been contacted by PM instead. The rest of the comments are just distracting us from the point, which is that Roger has done a nice bit of recycling. Dare I say it, I run a diamond bonded wheel without a guard - it's 95% solid aluminium and is not going to burst explosively. At the other end of the spindle is a grit wheel, in a guard. I also wear safety goggles whenever using it. Finally, what we do in our own workshops is our own business, but in my previous job I was very struck that the employees who took safety most seriously were the youngest ones. I never had anyone under 30 question the need for risk assessments, fire drills or safety gear - but I did get them reporting near misses and potential hazards. Neil FWIW my little study today shows that 1.3% of MEW articles are about safety., published at a rate of about two a year. |
GarryC | 11/04/2014 19:54:09 |
![]() 740 forum posts 1043 photos | Hi Neil I guess we all see these things differently. For me John's post was over the top and offensive and am quite surprised and disappointed it could be seen otherwise or ignored.. Amazed even! Ignoring this kind of behaviour leads to more of it. Not for me this.. Bye. Allan.
Oompa Lumpa | 11/04/2014 20:39:18 |
888 forum posts 36 photos | Well I decided to make a cover for my new surface plate, bit of quarter ply and couple of lats around the edge. Nothing small enough so get out my little saw and rip some 2x1: And this is the safe way to store these saws when it's not in your hand: graham. |
Michael Cox 1 | 11/04/2014 20:44:38 |
555 forum posts 27 photos | I am amazed at the mirth generated by this post. The OP had just modified a central heating pump to make a motor for driving a diamond abrasive wheel. It was not a finished project just a report on the conversion of a clapped out pump into a potentially useful grinding set up. For me the OP should be applauded for his original thinking. If I put my negative H&S hat on then the big danger I see is actually the rather long, thin unsupported shaft carrying the diamond abrasive wheel. This could bend and buckle if there was the slightest imbalance in the grinding wheel!!!! Calm down, have another glass of wine (but don't go into the workshop afterwards!!!!), relax. Enjoy the ingenuity in re-purposing a redundant pump into a motor. Mike |
Rick Kirkland 1 | 11/04/2014 20:55:27 |
![]() 175 forum posts | Right on Mike ! ! Rick |
John Stevenson | 11/04/2014 21:02:29 |
![]() 5068 forum posts 3 photos | Personally I'd be very careful, that 1/20 HP motor is liable to rip someone leg off. |
Oompa Lumpa | 11/04/2014 21:15:19 |
888 forum posts 36 photos | Posted by John Stevenson on 11/04/2014 21:02:29:
Personally I'd be very careful, that 1/20 HP motor is liable to rip someone leg off. Now that IS funny! Just wondering where the rest of the mirth is as alluded to by Mike Cox there? I do have a bit of a reputation of being a bit slow on the uptake though I would be grateful if someone would explain the joke to me? Anyone? graham. |
Steven Vine | 11/04/2014 21:35:43 |
340 forum posts 30 photos | I don't recall where any moderator with a duty of care to the forum owners has advised suitable guards to accompany the hundreds of unguarded lathe chuck and milling chuck pictures. These belittling safety cautions grind my gears. And to say the safety warning is there to protect beginners is laughable. What, are these beginners 7 year olds. Get real guys. Take care y'all. |
Alan .204 | 11/04/2014 22:14:28 |
304 forum posts 14 photos | What a good idea Roger would never thought of doing that with an old pump great idea, as for the rest of this thread I kind of see both sides of the argument, for me though I would like to think anyone that has the know how to make that would also be wise enough to know whether it needs a guard, not having a pop at Jason though as stated can see both sides, I wish sometimes though people would not get involved, I'm sure if Roger was pissed of with Jason's comment he would have said so, so no need for anyone else to get involved no matter what there thoughts are.
Life's to short.
Al. |
_Paul_ | 11/04/2014 22:15:59 |
![]() 543 forum posts 31 photos | Posted by John Stevenson on 11/04/2014 21:02:29:
Personally I'd be very careful, that 1/20 HP motor is liable to rip someone leg off. ROFL |
Alan .204 | 11/04/2014 22:18:57 |
304 forum posts 14 photos | What does ROFL mean.
Al.
John Haine | 11/04/2014 22:24:02 |
5563 forum posts 322 photos | It's what you do when that motor has ripped your leg off (though you might not be laughing very loud) |
Martin Walsh 1 | 11/04/2014 22:27:56 |
113 forum posts 2 photos | it means Rolling on floor laughing
best Wishes Martin
Alan .204 | 11/04/2014 22:29:50 |
304 forum posts 14 photos | Do you mean roll around f--king laughing.
Al. |
