Own design milling vice
Michael Checkley06/04/2014 14:09:25
121 forum posts
66 photos
After spending a fair bit of time kitting out my workshop, retrofitting CNC machines and a house move. I have reached a point were I can start creating!
but....before I could dive in to rc aero engines I was struggling to find a vice that would fit my Denford Novamill and the projects I had in mind so I decided to design my own. So this became the first project and (I can say now its finished) was a good one for understanding the machines and tooling I can gathered together.
The parts were made on either a Denford Starturn lathe, Novamill or warco mill.
Michael Checkley06/04/2014 14:22:17
121 forum posts
66 photos
Some drawings.....
Michael Gilligan06/04/2014 14:28:16
23121 forum posts
1360 photos
Michael,
That looks a very fine piece of Design and Machining
... I hope that Neil will offered the chance to publish !!
John McNamara06/04/2014 14:29:06
1377 forum posts
133 photos
Hi Michael
Very nicely made, you must get a kick out of using it.
john
Rick Kirkland 106/04/2014 14:39:59
175 forum posts
Michael, that's too good to bung on a machine and get swarf and cutting fluid on it!
Rick
John Stevenson06/04/2014 15:00:15
5068 forum posts
Michael,
Nice work.
Anyone notice that this vise / vice is ideal for a CNC machine in that the fixed jaw is the one nearest to you ?
So if the left hand side of the fixed jaw is referenced to 0,0 then all moves will be in the X+, Y+ quadrant which is the way most people draw.
The drawback to using a vise where the back jaw if fixed is that 0,0 will move in relation to the width of the blank parts put in the jaws.
Again nice work and do send it in for Neil to use.
[EDIT] Bought a new keyboard but this one spells worse than the last one.
Edited By John Stevenson on 06/04/2014 15:01:18
David Jupp06/04/2014 15:11:20
978 forum posts
26 photos
I have a Novamill awaiting re-commissioning, I'd be interested in the design if you decide to publish.
Neil Wyatt06/04/2014 17:54:56
19226 forum posts
749 photos
86 articles
Hi MIchael,
If you are interested in writing the vice up for MEW, email me on [email protected]
Thanks
Johnboy2506/04/2014 18:36:20
260 forum posts
Hi Michael..
This certainly looks the job including the professional drawings detailing it. I too would like to see this in MEW.
Oompa Lumpa06/04/2014 21:19:35
888 forum posts
36 photos
I would endorse John's comment, I too would like to see it written up, a very elegant piece of engineering.
graham.
Edited By Oompa Lumpa on 06/04/2014 21:20:18
Michael Checkley06/04/2014 22:47:03
121 forum posts
66 photos
Thanks for the positive comments!
The vice is 80mm wide jaws and opens a maximum of ~80mm so this only just fits on the Novamill. I have fitted a larger bed to my mill and a column raising block so I'm a bit better off for space.
I have component and assembly drawings so an article in MEW would not be impossible.
I like your design Gray, very low profile. My vice uses an 'off the shelf' leadscrew and nut and it was packaging up the nut that really set my height (~60mm)
Future plans are to do end stops and different jaws.
John Stevenson07/04/2014 01:25:28
5068 forum posts
From the shots I have seen Michael your drawings are first rate and very understandable.
Steamer191507/04/2014 08:38:27
171 forum posts
42 photos
First class work Michael. Please publish.
Best regards,
Steve.
Ian P07/04/2014 11:23:44
2747 forum posts
123 photos
Michael
What a sensible and practical vice you have made, to say nothing of the quality of design and construction. Its exemplary.
I look forward to seeing the design in print
Ian P.
Gray6207/04/2014 11:33:53
1058 forum posts
16 photos
Here's a random thought, how about a collaborative article, Gray and Michael - 2 takes on a similar subject.
It would make for an interesting subject to see how 2 experienced and obviously very accomplished engineers approached the subject and came up with similar but different end results.
Micheal, that paint finish is excellent - maybe you could include the paint process as part of the article, I'm sure others would benefit smiley
Graeme
Michael Checkley07/04/2014 14:36:08
121 forum posts
66 photos
Neil has given me the green light to submit and article for MEW so I will have a go at putting one together and hopefully see my design in print. It will be my first article so will see how it goes.
With regards to the paint I`m embarrassed to say its nothing special just 100ml plastikote spray cans over a grey primer. I like this paint as it has good self levelling properties and remains flexible. How it stands up to oils I will have to wait and see. A column raising block I made for the mill uses the same paint and is still mostly attached.
John Riedeman23/02/2015 02:19:45
2 forum posts
Were the prints ever published? This looks like a great summer project for me in learning how to use the current Novamill we have at school. If I can make this for it, then I'll be pretty versatile in using the machine. Thanks.
David Jupp23/02/2015 07:46:28
978 forum posts
26 photos
MEW, issues 223 & 224 I believe.
John Riedeman02/03/2015 15:24:46
2 forum posts
Ok, thanks! Do you think I need both issues or just one? It looks to be on the cover of Issue 223. And looks like I can purchase this in the US also correct? I'm not familiar with this magazine (yet).
fizzy02/03/2015 16:12:16
1860 forum posts
121 photos
I have to ask...how on earth do you get that finish? Ive got a decent set up but I cant get a finish anything like that on the mill??
