lee hawkins 1 | 16/03/2014 09:42:41 |
111 forum posts | Hello Where is it possible to Buy a 3/4 diameter 8 TPI Acme Die, I want to make my own custom made leadscrew for my lathe build, I could most probably use a myford leadscrew but the price for these is terribly high also if I buy second hand it's hard to trust sellers as to how worn it is Regards lee Edited By lee hawkins 1 on 16/03/2014 09:44:53 |
Tony Pratt 1 | 16/03/2014 10:01:41 |
2319 forum posts 13 photos | I don't know if they even exist, but this sort of job really needs to be screw cut. Tony |
Michael Gilligan | 16/03/2014 10:12:11 |
![]() 23121 forum posts 1360 photos | Lee, For a custom build you would probably do better to buy a length of leadscrew from Marchant Dice [or some similar supplier]. Here is their ebay shop. MichaelG. |
Les Jones 1 | 16/03/2014 10:52:53 |
2292 forum posts 159 photos | Hi Michael, Les. |
lee hawkins 1 | 16/03/2014 11:43:51 |
111 forum posts | OK, Thank you for the Advice Graham, I am not sure why a die should/would produce pitch errors? I have cut some quite large threads in the past that have worked perfectly, admittedly I have only cut short lenghts of Acme threads I need 3/4 8tpi because I have all and will be using myford cogs/change wheels, I contacted merchant dice, what they have wont work, Kingston engineering want close to £100 Regards lee |
John Stevenson | 16/03/2014 12:08:31 |
![]() 5068 forum posts 3 photos | Try Jim Marshall at lathe-parts.co.uk He sells S/H Myford parts and only sells decent stuff. Remember if you use the leadscew from the tailstock end first that end is never or very, very, rarely used |
Nobby | 16/03/2014 12:11:58 |
![]() 587 forum posts 113 photos | Hi |
Michael Horner | 16/03/2014 12:48:58 |
229 forum posts 63 photos | Hi Check out HPC they do an 8tpi ACME lead screw **LINK** Cheers Michael |
Robbo | 16/03/2014 14:36:38 |
1504 forum posts 142 photos | Lee, When I asked Tracy Tools about a die of similar size, which I wanted to clean up a threaded round bar, they said it would have to be made specially. Which made the cost out of reach, beyond the amount you quote from Kingston. Having said that, Tracy do sometimes have odd taps and dies, so may be worth asking. Phil |
Bazyle | 16/03/2014 16:02:12 |
![]() 6956 forum posts 229 photos | A leadscrew will normally ony wear on one side - threading towards the chuck. If you are making custom just get a used one and use it the other way round. Even if you do end up wanting to do a bit of thread work going away from the chuck you will be on the back end of the original configuration so less worn. Once you have this set up you can always then make a new one on the lathe you have built. |
Flying Fifer | 16/03/2014 16:46:22 |
180 forum posts | Lee, I`ve got an old Myford leadscrew & yes its worn in the usual place.ie near the chuck end. However as JS states above you could turn it a*** aboutface. I replaced it on my original ML7 years ago but kept it in the cuminandy box. So far it hasn`t so if you want it you can have it for the postage/carrier price if you want. I`m assuming you are in the UK. regards Alan |
lee hawkins 1 | 16/03/2014 18:06:52 |
111 forum posts | Alan, That would be fantastic!, yes I am in the uk, I have sent you a message with address And thanks to all who posted with help and advice, most appreciated Regards lee
Michael Gilligan | 16/03/2014 18:26:20 |
![]() 23121 forum posts 1360 photos | Posted by Graham Meek on 16/03/2014 11:17:12:
I do not see a 3/4" diameter 8 TPI "Acme" listed, the Trapezoidal thread form is 30 degrees where-as the Acme is 29 degrees. Gray, Gray, Given that Lee said he was proposing a "custom" leadscrew for his lathe, I thought perhaps he might be better-off using whatever configuration was readily available. MichaelG. |
Michael Gilligan | 16/03/2014 18:52:56 |
![]() 23121 forum posts 1360 photos | Posted by Les Jones 1 on 16/03/2014 10:52:53:
Hi Michael, Les. . Les, Agreed, it does seem odd ... I think we can probably put it down to "poetic license". I tried their website this morning, but it was down; so I posted the ebay link. I bought a short length of their "Trapezoidal" leadscrew a while back, and was impressed by the quality for the price. I haven't used it yet, but anticipate making a "finishing tap" from the first few inches. MichaelG.
Jeff Dayman | 16/03/2014 18:57:50 |
2356 forum posts 47 photos | Hello Lee Hawkins, Per your request the link below shows where you can buy a 3/4"-8 Acme thread die. Beare in mind it is a cleanup die only and not meant to cut a thread on a leadscrew, just to chase one to clean it up. As others have mentioned threadcutting it or getting some rolled thread leadscrew stock would be a better way. The dies do exist however, as the link shows. http://www.mcmaster.com/#2486a16/=r49otj Cheers JD |
lee hawkins 1 | 17/03/2014 08:09:39 |
111 forum posts | Gray, Thanks for posting that explanation, I know what you mean now. It's the longer the thread length and the inaccuracy of the rod/bar that would be creating the trouble you describe, longer the rod/bar worse it gets. I get all sorts of ambitious Ideas when working from a tight budget, I find myself very very lucky in that on this Forum there are very helpful and kind people,that are always willing to help others out Regards lee |
Martin Kyte | 17/03/2014 09:29:39 |
![]() 3445 forum posts 62 photos | I shall probably get shouted at for this but here goes. Cutting a lead screw with a die will probably introduce errors. However does this really matter in the context of the use to which the lathe is being put? Self act for turning does not care about inaccuracy. Screw threading for model making is usually only short lengths anyhow so again cumulative error down the lead screw is less important. Slight concentricity errors will be taken up in the flexure of the leadscrew. So as long as the user does not plan on making accurate long threads for positioning I don't see why he should not have a go at it. That said it's probably a lot of effort for not much return. Martin |
Hopper | 17/03/2014 09:50:28 |
![]() 7881 forum posts 397 photos | Is the Myford leadscrew not a left hand thread? Good luck finding a die if it is. I gather you are are building your own lathe from scratch, but using Myford gears etc that will match 8tpi?
Perhaps you could do something like buy a length of all-thread threaded bar at the local hardware store, with 8 or 12 or 16 tpi etc and rig it up as a temporary lead screw with the appropriate gearing to then cut yourself a 8 tpi acme thread in the lathe and make your leadscrew that way. I am sure this topic has been raised before and if you google around, lengths of leadscrew can be purchased at a quite reasonable price. I remember being surprised at the time how cheap it seemed. But cant find it anywhere! |
Martin Kyte | 17/03/2014 10:48:43 |
![]() 3445 forum posts 62 photos | Personally Gray I agree with you. A job is always worth doing well but not always worth doing better than you need. As I suggested, I would not take the die cut route but each to his own. Mostly we all over-engineer at home because it's fun. Martin |
colin hawes | 17/03/2014 13:18:43 |
570 forum posts 18 photos | I would certainly not try to cut a leadscrew thread with a die . I can't see it being successful in an amateur workshop. When I have to cut a square or acme thread I grind a HSS vee shape tool to rough cut it to near full depth and finish with a tool of the correct profile. Dies are almost certain to give an accumulated error. Colin |
