Steam Models | 20/01/2014 08:31:14 |
5 forum posts | Hi Everyone I am trying to find 3/16 x 40tpi brass studding for a project I'm currently working on. I have tried all the usual places but have had no success yet. I would be very grateful if anyone could tell me where I might get some, I would like 12" of it ideally. Many Thanks David |
Saxalby | 20/01/2014 09:07:28 |
![]() 187 forum posts 33 photos | I have never seen ME thread studding. What is the project that specifically requires this size. 2BA studding is available, very slightly smaller and approx 32 TPI. Would that not suffice. Barry
Steam Models | 20/01/2014 09:40:07 |
5 forum posts | Hi Barry Thanks for your reply. Unfortunately this is too small. The project is a carburetor for a Westbury Internal Combustion Engine so it needs to be this size. This is already tapped for this size. Thanks David |
John Billard | 20/01/2014 09:51:36 |
42 forum posts | Surely it would not be too difficult to make? I presume that a whole 12 inch length is not needed? Best wishes John B
JasonB | 20/01/2014 12:27:01 |
![]() 25215 forum posts 3105 photos 1 articles | Given the cost of brass studding in the BA sizes its likely to be cheaper to buy a length of 3/16 brass and a die thats if you could even find it in 3/16 x 40 Does it need to be threaded all the way? most studs just need threading each end. J |
Stub Mandrel | 20/01/2014 19:32:19 |
![]() 4318 forum posts 291 photos 1 articles | in brass its a size that's nice and easy to screwcut as well. Neil |
fizzy | 22/01/2014 20:23:12 |
![]() 1860 forum posts 121 photos | Joe at maccmodels sells studding - but as above, its a load cheaper to buy bar and a die
David Clark 1 | 22/01/2014 21:04:24 |
![]() 3357 forum posts 112 photos 10 articles | Buy a 40TPI Coventry die set from Ebay or Tracy Tools and screwcut it. regards David |
julian atkins | 22/01/2014 22:23:29 |
![]() 1285 forum posts 353 photos | why would you spent a relatively large sum on a coventry die head to thread some 3/16" brass bar? (unless youve just won the lottery!) a tailstock dieholder with a hole drilled through it for the material will do perfectly ok for 3/16" x 40 tpi. i have a lever tailstock on my lathe which assists things a bit, but it would be a few minutes work to thread same as described on most lathes. never had any 'run out' on the thread. ive quite often cut ME threads this way in the lathe in brass and bronze cheers, julian Edited By julian atkins on 22/01/2014 22:24:17 |
Nobby | 22/01/2014 22:31:01 |
![]() 587 forum posts 113 photos | Hi David
Edited By Nobby on 22/01/2014 22:31:29 Edited By Nobby on 22/01/2014 22:32:04 |
JasonB | 23/01/2014 07:27:28 |
![]() 25215 forum posts 3105 photos 1 articles | Julian, DC1 suggested a die set not the whole head, you use one of the cutters as your form tool and screwcut with that. I think Tracy even do a special holder for them.
J |
Steam Models | 30/01/2014 16:44:39 |
5 forum posts | Thank you everyone for your suggestions. I had tried threading the bar myself, but for some reason the threads proved too loose. I managed to track down a supplier that carry this size, BA Bolts. |
