Alan .204 | 12/01/2014 20:47:13 |
304 forum posts 14 photos | Thinking of buying a set of ER 32 collets for the mill it's an MT2 taper any advice on where to buy them would be helpful, will make an adapter for the lathe also.
Regards Alan. |
Michael Cox 1 | 12/01/2014 21:13:58 |
555 forum posts 27 photos | I have bought collets from CTC in Hong Kong. Very good prices and quality but postage can add up. Also be aware you may get charged duties, vat and a Post Office fee which adds substantially to the bill. If you can keep each delivery below circa £20 then often these duties and fees do not apply. Mike |
Ron Vale | 12/01/2014 23:03:03 |
24 forum posts | ARC EURO are as good as any, and very quick service too |
Tony Ray | 12/01/2014 23:05:44 |
238 forum posts 47 photos | Holster Tooling on Fleabay are ok too |
John Haine | 12/01/2014 23:32:40 |
5563 forum posts 322 photos | I bought a set of ER40 collets for the Myford collet holder I bought for my S7 from Quick and did a deal. |
JohnF | 13/01/2014 00:00:49 |
![]() 1243 forum posts 202 photos | Alan, Have look at this thread |
Mike Bondarczuk | 13/01/2014 04:35:30 |
91 forum posts 6 photos | Alan, I purchased a complete ER32 set from Amadeal at the same time as my mill and the service was excellent, no connection to the supplier. However, I am still looking for a threaded ER32 adapter to screw straight onto my Myford. Any ideas where I can find one. Mike |
Emgee | 13/01/2014 09:56:31 |
2610 forum posts 312 photos | Hi Bogstandard2 Mike, thanks for the link to your ER32 collet holder pages, looks fine to me so will sort out a billet !!Rgds, Emgee |
Roderick Jenkins | 13/01/2014 10:16:13 |
![]() 2376 forum posts 800 photos | Alan, I bought my ER25 collets from arc and have been perfectly happy with them. One of the advantages is that their range includes 0.5mm steps in the smallest sizes. These are essential since, whatever the advertising says, you will not get a 3-2mm collet to grip a 2.1mm drill. The situation is probably worse with the larger ER32 collets. For my 2MT mill I chose ER25 in preference to ER32 since my mill is not man enough to use 3/4" or 20mm endmills but I do find it useful to hold 1mm drills. ER32 only goes down to 2mm. Also the ER32 chuck is bigger and this uses up some of my already restricted headroom between job and tool. I now find that I tend to leave the ER25 chuck in the mill spindle all the time and use the collets for all drilling as well as milling, even though the collet nut can sometimes get in the way. Obviously these comments refer to my particular mill and modelling requirements. Rod |
Howard Lewis | 13/01/2014 12:24:52 |
7227 forum posts 21 photos | ER collets are GOOD! ER32 seems a bit big for a machine with a MT2 quill. You could find the nut getting in the way sometimes, and as Roderick says, it may be difficult to grip really small drill or cutters. Years ago, when I had a ML7, and a Rodney milling attachment, I bought ER25, from Chronos, and have never regretted it. Since buying a Mill Drill, I use the ER25 collet holder in a 2 -3MT sleeve. Although I now have collet chucks for the larger lathe, ex Warco, in ER25 and ER32 (I have just 4 collets to extend from the 16mm of ER25 to 20mm; but they are rarely used). Also made up square and hexagon holders for ER25 and ER32, to use in the vice on the Mill/Drill. I have made ER25 holders for Taps on a Tailstock Sliding Die Holder mandrel, and for a Floating Holder for Hand Reamers. (For machine reamers made up soft ER32 collets to take 1, 2 and 3MT shanks. Did not change the Topslide set over between boring for the collets, and turning the OD of the collets. Slitting the collets was interesting!) For drill grinding on my Worden, I made up an ER20 holder. The 1 -13mm collets were expensive, or seemed so! Making your own holders is a useful exercise in screwcutting. For all these pieces, I bought the closing nuts and spanners (and the ER20 collets) from Arc Euro Trade. Possible suppliers (take your choice) Arc Euro Trade, Chronos, Warco, Chester, and others. Howard
richardandtracy | 13/01/2014 15:13:03 |
![]() 943 forum posts 10 photos | ER32 Collet chucks from YSTool on E-Bay. They are marginally cheaper than CTC & seem to have the same quality. For the collets, Arceurotrade are the cheapest individual collets I have seen if you don't want to lash out for a set all in one go. The MT4 ER32 collet chuck I got from CTC has seen a lot of work over the last 3 years and is still doing well. Regards, Richard |
Alan .204 | 13/01/2014 18:56:32 |
304 forum posts 14 photos | Thats a good read chaps most informative, I should have said that my mill is a Centec 2B and the lathe is a Colchester Bantam, Gary a member on this forum has nearly finished a riser block for me so height should not be a problem, so does the panel think ER32 or ER25, I will be making a collet holder for the lathe at some point so please bear that in mind.
Al. |
Alan .204 | 13/01/2014 19:07:58 |
304 forum posts 14 photos | One thing I meant to ask this may seam a daft question but having never had any collets before, does one set fit all or is it a imp and separate metric set.
Al. |
JasonB | 13/01/2014 19:16:21 |
![]() 25215 forum posts 3105 photos 1 articles | In theory one (metric) range fits all but in practice I like the Imperials as well. It takes quite a bit to close a 4-3mm ER32 down to 1/8", also you don't have the three handed job of two spanners and stopping the tool dropping out when closing down onto a smaller size. The imperials will lightly hold imperal shanked tooling just by friction leaving your hands free to tighten the nut and stop the spindle turning. J
Edited By JasonB on 13/01/2014 19:20:32 |
Roderick Jenkins | 13/01/2014 19:54:38 |
![]() 2376 forum posts 800 photos | Posted by Alan .204 on 13/01/2014 18:56:32:
Thats a good read chaps most informative, I should have said that my mill is a Centec 2B and the lathe is a Colchester Bantam, Gary a member on this forum has nearly finished a riser block for me so height should not be a problem, so does the panel think ER32 or ER25, I will be making a collet holder for the lathe at some point so please bear that in mind. I think only you can answer that Alan. It really comes down to the range: ER25 1-16mm or ER32 2-20mm. I use mine for all sorts of workholding, including in the dividing head on the milling machine, so this may be a factor if you have such a thing or a rotary table. The ER 32 will have a bulkier chuck, this may or may not be an issue for you. I'm sure either size will be fine. Oh, and I completely agree with Jason on the imperial question. I've got 1/8, 1/4, 3/8 and 1/2" imperial as well as the metric set (also from arceurotrade) Rod Edited By Roderick Jenkins on 13/01/2014 19:56:26 |
Alan .204 | 13/01/2014 21:28:36 |
304 forum posts 14 photos | Thanks Rod I've had a think and recon I will go for the ER32 it my well be handier on the lath, also I possess a dividing head, I keep threatening it that I will use it one day.
Thanks to every one who helped with the question. Al. |
Another JohnS | 13/01/2014 22:10:01 |
842 forum posts 56 photos | Al; There is no wrong choice here. For my Centec 2B, I use my ER25 collets 99% of the time. the 1% is for a boring head, or shell end mill holder, or, once a decade or so, a drill chuck. One issue that I have found is that the 10mm collet is always in the mill, and it's always the one you want on your 2nd ER collet holder, so I do have duplicates of some of my ER25 collets. (frustrating when you find that you want to use the same collet in two places at once...) John. |
ronan walsh | 13/01/2014 23:50:28 |
546 forum posts 32 photos | Posted by MICHAEL WILLIAMS on 13/01/2014 22:09:41:
An ER32 chuck is a big thing to hang off a feeble No2 Morse taper . Overhang of cutters is considerable and the whole stack up of shank , chuck and cutter will often be excessively flexible leading to poor cutting and uncertain sizing . There is no golden rule but generally speaking when using a collet chuck the actual end mills used should be limited to being not much bigger than the big end of the taper shank and ideally a bit smaller . Knowing limit of size of endmill select chuck size to suit . MikeW I have to agree with this. The lighter morse tapers are not the best for milling and i have often seen the no.2 chuck and cutter on my Tom Senior clearly flexing under load. I do notice that the runout is reduced if using end mills rather than 2 flute slot drills. |
JasonB | 14/01/2014 07:34:08 |
![]() 25215 forum posts 3105 photos 1 articles | Using that rule of thumb suggests ER32 will be fine as they only hold upto 20mm which is "not much bigger" than the 17.8mm large end of the taper. Just don't use a 3/4" shank tool with larger cutting width.
J |
magpie | 14/01/2014 08:07:38 |
![]() 508 forum posts 98 photos | I have been using ER32 on a 2Mt in my Chester Champion 20 V for the last 3 years, but as I am in no great hurry to do ANYTHING these days, I don't try to take big cuts and expect too much from the machine. So far I have had no problems with this setup. Says he touching wood. Cheers Derek |
