First lathe recommendation.
Jim Newberry 110/12/2013 18:32:47
24 forum posts
12 photos
Hi all,
I have been after a lathe for a little while now and, after giving it quite a bit of though, I have come to the conclusion that I would prefer to buy a brand new machine rather than second hand so I will be heading to the Model Engineering Exhibition at Sandown this weekend. With the money I made this afternoon selling my wedding ring - no I'm not kidding! - I am hoping to take the plunge there and then.
So - I think I have narrowed the search down to three or four machines and I'd like people's input please. I reckon my first lathe should be something relatively small and simple - I am planning on using it to make smallish steam engines, initially at least, and I think something with too many bells and whistles will only confuse me - knowing me I'll try to run before I can walk and only end up making a mess of everything.
The contenders are - Clarke CL250 (I like the fact that this one can have a milling attachment added at a later date), Warco Super Mini, Sieg SC2. All three are in the order of £500 or so. Also in the running is the Clarke 500 - twice the price but comes with a mill/drill (although see earlier comment about not getting something with too many features - just contradicted myself there!)
So - thoughts please everyone?
JasonB10/12/2013 18:42:33
I don't think you will find any of those lathes for sale or to view at sandown going by the short list of traders
Jim Newberry 110/12/2013 18:44:06
24 forum posts
12 photos
Ah. Must admit, I hadn't considered that possibility!
John Rudd10/12/2013 18:52:44
1479 forum posts
My own recommendation would be a Sieg super C3 if your funds can stretch to it...
it is a far superior machine than the opposition mentioned...
the Clarke CL500 is a little er can we say 'agricultural '.....mill wise, again the Sieg SuperX2 fits in nicely with the lathe when funds permit....
I'm sure there'll be other recommendations, but this is mine.....
(I have the above, plus a Chester 9x20, a Chester Eagle 30 mill and a Chester Conquest mill....can't have enough toys... )
Michael Cox 110/12/2013 19:43:36
555 forum posts
27 photos
Also consider the Amadeal CJ18, see www.amadeal.co.uk.
This machine comes with a 100 mm spindle flange and chuck whereas most competitos only have an 80 mm spindle and chuck. The machine is virtually the same design as the Sieg C3 but it is made by Real Bull. Some say that the Real Bull build quality is better than that of the Sieg machines.
All the lathes that you mention can be fitted with milling attachments. However these are only suited to light milling and a carried lock and a leadscrew handwheel are needed to use the attachment efficiently. Also read
michael cole10/12/2013 19:44:31
166 forum posts
I would forget about a mill attached to a small lathe, you will hate it.
Jim Newberry 110/12/2013 19:46:49
24 forum posts
12 photos
Thanks for the tip John. The Super C3 isn't a million miles out of budget so is now officially on the contenders' list! Would you mind me asking what it is that makes it superior? What I'm thinking is whether many of the features that make it superior are features that I wouldn't necessarily need anyway - for instance, I notice that it has a longer bed but I'm not sure I need a bed that long anyway so I wouldn't necessarily want to pay extra for something I don't need. Do any other features fall into a similar category?
Many thanks,
Jim
John Rudd10/12/2013 20:01:28
1479 forum posts
The Sieg offering has a brushless motor as opposed to the Amadeal m/c for starters.......
AFAIK, the Amadeal job also has the gearbox......
Robbo10/12/2013 20:53:01
1504 forum posts
142 photos
Warco (and Chester) will be at Ally Pally with machinery.
JasonB10/12/2013 20:59:32
And Axminster with their Sieg machines
John Rudd10/12/2013 21:02:03
1479 forum posts
Again, AFAIK, the Warco and Chester machines have brushed motors and use a gearbox for the Lo/Hi speeds.
Now unless they have changed the gears from plastic to metal, these will always be a consideration for these machines...( the plastic gears afford some protection against doing damage,the metal gears maybe noisier)
Personally, I don't like the cam lock arrangement on the Amadeal m/c, prefer the Sieg method....
Bazyle10/12/2013 21:59:31
6956 forum posts
229 photos
Depending on your location and means of travel you might be able to get to the Warco business showroom to have a look at their machines. Otherwise you should definately wait until the Ally Pally show to get some proper hands on appreciation.
While at both shows take the time to talk to club stands of all types to get their views bearing in mind each person you talk to will have a different bias and experience.it is a quick way to get a lot of one to one discussion time.
JohnF10/12/2013 22:40:44
1243 forum posts
202 photos
Hi Jim, Looking at the list of exhibitors for Sandown I think i would wait until the London exhibition **LINK**
There seems to be a much better choice in the January show but I have not been to Sandown because its to difficult to get to from the North West .
Regarding a lathe well remember what will hold a lot will hold a little -- generally speaking, I would go a little bigger than those mentioned if your budget and workshop will allow and I would without doubt make sure it has a screw cutting [norton] gear box rather than change wheels. For small parts what collet system do you want to use or what do they supply. Are you going metric or imperial? Last but not least what is the back up from the supplier.
My five bits!
John.
Jim Newberry 110/12/2013 23:03:56
24 forum posts
12 photos
Thanks everyone, there is some really useful stuff here and I'll bear it all in mind. The Sandown show is quite an easy proposition for me as it is handy for work (Heathrow) so I'll go along anyway but try to curb my natural tendency to "buy it 'cos it's there" unless I see the right thing. Ally Pally doesn't fit in very well with work dates but if nothing is forthcoming at Sandown I can probably squeeze it in.
Anyway, thanks again for the input, much appreciated.
Jim
Rik Shaw11/12/2013 09:43:35
1494 forum posts
403 photos
Johns comment re: screw cutting gearbox is right on the ball. I have a WARCO WM 250 V-F and the messy and confusing palaver of changing the gear positions with the rubber gloves, strips of paper and complex thread cutting charts is something to avoid if at all possible - never mind the noise!>>
Think of it like this: If you had a car that was like my lathe how would you feel if every time you had to change gear you would have to pull into a lay-by, stop the engine, dismantle the gearbox, reset the gear positions possibly using the spare gears you have to keep in the boot, replace the gearbox cover, clean yourself up and drive away? angry 2>>
Primitive? ........you bet!>>
Rik>>
Robbo11/12/2013 09:56:22
1504 forum posts
142 photos
Jim,
Re your original post
" With the money I made this afternoon selling my wedding ring - no I'm not kidding! - I am hoping to take the plunge there and then."
just what kind of wedding ring?
Phil
mechman4811/12/2013 10:10:35
2947 forum posts
468 photos
I have the same machine as Rik & find it suits my needs most admirably so far, I haven't had the palaver about screw cutting as Rik as most of the few threads I've needed were handled by the tailstock die holder & headstock handle method so I can't comment on the changing gear scenario, until I need to create some other thread than what is set up in original arrangement I'll stick with the above, but we made our choice for our needs at the time. I can see the benefits of a screw cutting gearbox & should I ever get another machine then I would look at it having the gearbox set up, but for what I do at the moment....
George
John Rudd11/12/2013 11:32:25
1479 forum posts
Guys,
please don't lose sight of the fact that the OP has a limited budget.....
Jim Newberry 111/12/2013 12:36:19
24 forum posts
12 photos
Phil,
i should perhaps have mentioned that it was my ring from my first marriage and it had been sitting gathering dust at the back of a drawer for the last five years! I didn't get enough for it to pay for the lathe entirely but it's a good start! It was a 6mm platinum ring.
Jim
GaryM11/12/2013 14:18:43
314 forum posts
44 photos
Hi Jim,
I bought my first lathe two years ago, a Sieg SC2 from Axminster. I didn't know of all the model engineering suppliers at the time.
Thoughts on ownership since then:
I now wish it was bigger (no surprise there), but what I've learnt in the last two years means I have a much better idea of what I would be looking for in an upgrade.
The nut that locks the tailstock to the bed is a pain in the bum. Try to get one with a lever lock. (i.e. Super C3 from Arc or Super Mini Lathe from Warco).
If you decide to fit a thread dial indicator to the saddle for screwcutting you have to remove the leadscrew cover permanently on the Axminster or Arc machines (didn't stop me). Warco has a thread dial indicator fitted.
Turning anything bigger than 3" diameter (e.g. small engine flywheel) gets a bit challenging.
I bought a vertical slide but it is IMHO a waste of money. When I came to machine the bedplate for the Stuart S50 I decided it wasn't worth the hassle of trying to do it on the vertical slide and bought a separate milling machine (bug had well and truly bitten by then). The link provided by Michael Cox 1 above explains why.
HTH
Gary
