Any simple test for aluminium vs zinc?
Paul Fallert | 08/11/2013 17:17:47 |
89 forum posts 3 photos | Other than melting temperature, is there a quick/simple way to distinguish between zinc and aluminium? If I throw a bit of gray metal into the melt pot and it is zinc when I was expecting that is was aluminium, the resulting casting will be spoiled. What do others use to keep these metals separate? The alchemists must have had some simple method of testing their bits of metal. Paul |
Michael Gilligan | 08/11/2013 17:45:38 |
![]() 23121 forum posts 1360 photos | Paul, Weigh it; then check the volume, and calculate the Density. ... Remember Archimedes ? Table of densities here [and many other places] MichaelG. |
jason udall | 08/11/2013 17:53:38 |
2032 forum posts 41 photos | Citric acid or lemon juice? Metal will fiz a bit Compare known ali with unkown... ..btw adding magnesium by mistake is far worse consequence than poor casting. ..." |
Bazyle | 08/11/2013 18:04:09 |
![]() 6956 forum posts 229 photos | and aluminium reacts with caustic soda. Also try making a battery with a bit of copper, mystery metal and acid. You could calculate resulting voltage but comparison with known sample would be easier. |
jason udall | 08/11/2013 18:21:25 |
2032 forum posts 41 photos | Bazyle..good idea..if you chose you ref metal ( say known ali ) with instead of acid say salt water ..then simple go no go test results... ( no volts then ali.. volts then not ali) |
Michael Cox 1 | 08/11/2013 19:44:07 |
555 forum posts 27 photos | Aluminium should not react with vinegar at room temperature. Zinc will react slowly giving of bubbles of hydrogen. Aluminium and zinc will react with strong (15%) caustic soda solution evolving hydrogen at room temperature magnesium will not. Clean zinc and magnesium both react rapidly with copper sulphate depositing copper on the surface of the metal but aluminium does not. If you heat zinc strongly with a blowtorch it will vapourise and oxidise emiting a white smoke. Aluminium does not do this. Magnesium will burn with a bright white flame if heated strongly and give of white smoke. Mike |
dave greenham | 08/11/2013 20:15:15 |
100 forum posts | Bazyle. can you still get caustic soda ? I thought that had been banned years ago. But was a great week killer. Dave. |
dave greenham | 08/11/2013 20:17:07 |
100 forum posts | Oops. Weed killer sorry. Predicted text. Dave. |
Russell Eberhardt | 08/11/2013 20:22:41 |
![]() 2785 forum posts 87 photos | Posted by dave greenham on 08/11/2013 20:15:15:
Bazyle. can you still get caustic soda ? I thought that had been banned years ago. But was a great week killer. Dave. Yes caustic soda is easy to get. You're thinking of sodium chlorate which, as well as being a weedkiller can be used in various recipes to make bombs. Russell. |
Tony Pratt 1 | 08/11/2013 21:02:21 |
2319 forum posts 13 photos | Sodium Chlorate was banned by the dicks in Brussels years ago as a fire hazard and yes it was a good weed killer and also an ingredient in the making of gunpowder/black powder [ as a replacement for sodium/potassium nitrate] so as the Americans say 'go figure' Tony |
Speedy Builder5 | 08/11/2013 22:12:27 |
2878 forum posts 248 photos | Sodium Chlorate available in liquid form over here. Crystals only sold in tins from under the counter now, along with Carbon Tetrachloride. (Old stock guvn'r.) |
jonathan heppel | 09/11/2013 07:45:00 |
99 forum posts | Potassium nitrate was certainly available ten years ago and may still be, albeit in small quantities. It's an essential ingredient for curing ham and bacon. |
Howard Lewis | 09/11/2013 21:59:18 |
7227 forum posts 21 photos | Aluminium, Zinc, and Copper will all react with Caustic Soda. Mercury will react with Aluminium, to produce "whiskers" but you are not likely to be able to get hold (no pun!) of any, because it can be quite dangerous to health (especially Kidneys). Aluminium swarf will burn, (so will Magnesium - BIG time) BE VERY CAREFUL, where, when and how and how much, you test. I would not expect Zinc or Copper swarf to burn. The melting points, may give a clue as to Ali or Zinc, but the purity will cause variations in the actual value. Howard |
Swarf, Mostly! | 09/11/2013 22:48:20 |
753 forum posts 80 photos | Hi there, all, You can determine the specific gravity of an object using just a rigid rod, three bits of string, a counter-weight, a measuring tape and a bucket of water. Suspend the rod by roughly the centre using one piece of string, hang the counter-weight on one end and the object from close to the other end using the other two pieces of string. Arrange the object, counter-weight and 'centre' suspension positions until the system is in balance. Measure the two spacings between the suspensions of the object, the counter-weight and the main suspension point. Then lower the system so that the object is freely immersed in the bucket of water and not trapping any air bubbles - adjust one but not both suspensions to restore balance. (It's best if you only move the object, you'll have to move it further from the main suspension - leave the counter-weight position unchanged wrt the main suspension.) Measure and note the new inter-suspension distances. The object will have 'lost' the weight of its volume of water. By a bit of algebra, the specific gravity of the object can be calculated (I'd describe the details of the calculation here but it's a bit too close to bed-time!). Look up the specific gravity in the reference books or on the Internet to get a pretty reliable clue as to the metal's identity. This method may sound a bit Heath-Robinson but it's certainly capable of distinguishing between aluminium (alloy) and zinc or die-casting metal. Best regards, Swarf, Mostly!
Edited By Swarf, Mostly! on 09/11/2013 22:51:26 Edited By Swarf, Mostly! on 09/11/2013 22:52:40 |
Michael Cox 1 | 09/11/2013 23:39:45 |
555 forum posts 27 photos | Posted by Howard Lewis on 09/11/2013 21:59:18:
Aluminium, Zinc, and Copper will all react with Caustic Soda. Caustic soda will not react with copper. Mike |
Gone Away | 09/11/2013 23:51:14 |
829 forum posts 1 photos | When I was involved with die-cast parts years ago, in both aluminum and zinc we just used to pick them up to find out which was which. Zinc is pretty heavy compared to aluminum. Close to steel actually. |
Michael Gilligan | 10/11/2013 00:18:06 |
![]() 23121 forum posts 1360 photos | Posted by OMG on 09/11/2013 23:51:14:
When I was involved with die-cast parts years ago, in both aluminum and zinc we just used to pick them up to find out which was which. Zinc is pretty heavy compared to aluminum. Close to steel actually. . Quite so ... as per my first reply. I presume that others are just fond of their Chemistry sets. MichaelG. |
Gone Away | 10/11/2013 01:05:49 |
829 forum posts 1 photos | Posted by Michael Gilligan on 10/11/2013 00:18:06:
Quite so ... as per my first reply. ... er .... yeah ..... sans the weighing, checking the volume and calculating the density I guess it is. (Sorry, Michael - couldn't resist). |
Michael Gilligan | 10/11/2013 05:40:40 |
![]() 23121 forum posts 1360 photos | Posted by OMG on 10/11/2013 01:05:49:
Quite so ... as per my first reply. ... er .... yeah ..... sans the weighing, checking the volume and calculating the density I guess it is. (Sorry, Michael - couldn't resist). . Yes ... exactly Your experience allowed you to estimate the density; thus skipping those formal steps. That's a reasonably safe thing to do ... because the difference in these densities is roughly 3:1 Paul was obviously unaware of this, so I was trying to help him understand the principle. ... finding the shortcuts comes later. MichaelG.
SteveW | 10/11/2013 07:38:10 |
![]() 140 forum posts 11 photos | How about soft solder? If its sheet then zinc will 'tin' fairly easily but ali will not. Not so convenient on lumps which I guess was the OPs situation. SteveW |
