Belt conversion on X2 milling machine
Where to find one
rebekah anderson05/11/2013 11:52:45
135 forum posts
Hiya every one.
i am looking for a belt conversion kit for the X2 milling machine so that I can ramp up the speed and it's quieter.
I have seen the plans to make your own but I don't have the capacity to make the pulleys.
Does any one know who sells a complete conversion kit or can make one.
cheers guys and gals
Old School05/11/2013 13:12:46
426 forum posts
40 photos
Rebekah
Little Machine Shop in the USA has them they ship to the UK have used them in the past with no problems.
Oliver
I.M. OUTAHERE05/11/2013 18:13:51
1468 forum posts
Hi Rebekah,
The kit from LMS works well but if you go to their website and look it up you will find at the bottom of the page 2 windows named Chris's tips and another called compatibility which you can click on to find if it will fit your machine or not .
Some machines are genuine sieg some are clones and there may be some minor differences , and if you are still unsure send the an E-mail as they are excellent to deal with (usual disclaimer etc) .
I'm not sure if ARC do one and if they don't maybe they should look at supplying them .
Ian
Bob Perkins05/11/2013 19:03:32
249 forum posts
60 photos
Hi Rebekah
I bought a gas spring conversion kit from LMS @12 months ago for my SX2. Excellent service. Don't forget the import tax, which from memory was @ £15.
Bob..
dave greenham05/11/2013 19:42:48
100 forum posts
Hi
i wouldn't swear to it but I seem to recall that someone said that SPG Hinckley do them. May be worth an email.
dave g
John Shepherd06/11/2013 08:28:10
222 forum posts
7 photos
I have seen reference to a set of drawings to make a two speed belt conversion on a Yahoo group but have not been able to find them. You may not wish to make your own but it might be good to see what is involved if any one can tell us where they can be found.
There are also some kits listed on Ebay at the moment.
John Hinkley06/11/2013 13:49:32
1545 forum posts
484 photos
John,
If you PM me with your email address, I have a pdf file of the plans that I can send you. They were circulated by Jerry Rollet, originally on a Yahoo! forum, I understand, so they are in the public domain. Never been a member of Yahoo! myself and I can't remember where I got them from, either, or I'd post a link for all to see!
John H.
Blue Heeler07/11/2013 05:09:18
342 forum posts
Just how different is an X2 with a belt drive? Is it a 'mandatory' upgrade?
rebekah anderson07/11/2013 11:46:36
135 forum posts
it's quieter and faster from 2500 to close to 4000 rpm
Ian S C07/11/2013 13:29:17
7468 forum posts
230 photos
And no more broken gears. Ian S C (that's if you'v gone that way)
John Rudd08/11/2013 12:28:55
1479 forum posts
I can attest to the comments made.
Not all mini mills are the same.
I made the belt drive for my Chester Conquest based on Jerry Rollet's plans and found that there were dimensional differences....So ended up making changes on the fly....
None the less, the conversion is very worth while and satisfying
Essm11/11/2013 10:52:51
29 forum posts
8 photos
Hi Rebekah
This is my first post so bear with me if it all goes wrong
I fitted a belt drive kit earlier this year and was very pleased with both the kit and the resulting performance.
The kit was from Turkey and is available on e-bay. Search for SIEG x2 mini mill belt drive conversion
I have added (hopefully) a couple of photos on the album.
Fitted at the same time was a gas strut to replace the torsion spring and this works a treat. The strut was ref GS6-15-260-300 with a 10mm Ball stud from SGS Engineering UK - and was set for 40Kg if I remember correctly. It was a little overlength so I fitted an angle bracket to lift the top fixing point up a little as per the photos. I also fitted the longer rack from LMS to take advantage of all the extra travel.
Also fitted was a set of Angel Eyes LED's to provide a good light onto the work surface and the driver for these was attached to the rear of the control box.
Hope this is of interest
Stuart
