Mating a drillchuck to an arbor
Clive Hartland23/10/2013 21:11:47
2929 forum posts
41 photos
I am about to fit a fit a B16 arbor to a keyless drill chuck, what should I look out for?
Versaboss23/10/2013 22:11:34
512 forum posts
77 photos
Don't quite understand your problem, but maybe check that the chuck also has B16 taper (and not one of the Jacobs tapers).
Greetings, Hansrudolf
Robbo23/10/2013 22:35:12
1504 forum posts
142 photos
Clive,
About the only precaution is to check that the arbor runs true before you glue it into the chuck, rather than find out afterwards.
Phil
Nobby23/10/2013 23:26:55
587 forum posts
113 photos
Hi
To check if they are same .with finger put on some high spot blue and gently fit the arbor into the chuck and
See how it touches. MY son was a fitter in the RAF and he sugested to his dad on a job like this use a black felt tip pen and when dry try as i said with the high spot
Nobby
Edited By Nobby on 23/10/2013 23:27:56
Clive Hartland24/10/2013 08:35:48
2929 forum posts
41 photos
I ask because I have previously had a problem with a smaller chuck that would not stay on the arbor, even though the taper showed no fault when blued and offered up. It was finally fixed by knocking it onto the arbor with a hide mallet.
speelwerk24/10/2013 09:40:41
464 forum posts
Degrease arbor and chuck, than place the arbor in the fridge for a while to obtain a better grip. Niko.
Stub Mandrel24/10/2013 14:37:47
4318 forum posts
291 photos
This worked for me once.
Geoff Theasby24/10/2013 17:30:31
615 forum posts
21 photos
Clive,
That worked well for me, after taking advice from a local club member.
KWIL24/10/2013 19:11:48
3681 forum posts
70 photos
In the old days when we used to replace CI valve guides in car engines, we knocked out the old, but put the new ones in the freezer, made a depth guage and merely placed the new ones. Worked a treat, no hammering and always in the right place.
Clive Hartland24/10/2013 22:03:55
2929 forum posts
41 photos
Thanks for all the info, I will freeze the arbor and do it that way.
clogs02/11/2013 21:19:04
630 forum posts
12 photos
HI Guy's ...I've a few old drill press's bought used and the chuck's used to work loose after a while....
I used 222 Locktight or screw - lock to keep them together.....clean the chuck and its mating face...just a couple of drops of the fluid, hand fit...spin to check for run out...once ur satisfied place a block of wood under the chuck and hang a weight on the operation arm to keep the chuck tight...overnight shoud do it......one of mine was real bad, had tram lines in it, used a little extra fine valve grinding paste to lap it in, a good clean up and Locktite...it's never come of.......only do this if u'll never want the chuck off again say for say MT drill bits....
Frank in France
