Magnetic tool storage
Bob Perkins10/09/2013 13:39:19
249 forum posts
60 photos
I've been having a bit of a sort out and shift around in the workshop after completing a couple of projects. I've swapped the the positions of my lathe and mill as I think the storage space between the two will work better. I'm also looking to improve the storage of the assortment of various scanners, Allen keys etc that perhaps tend to end up balanced on various parts of the machines. Has anybody used these silverline magnetic tool holders?
I'm thinking about fitting them to some cabinet doors I have next to my machines. Easy to grab!
Regar
Bob..
Keith Long10/09/2013 14:19:50
883 forum posts
11 photos
Hi Bob
I've not used them but 2 things come to mind.
The tools may become slightjy magnetised and grow a "beard" of swarf
You'll need to keep the doors closed or only work in aluminium or brass as the tool holders will attract iron/steel swarf and particles as well.
It's amazing how the stuff can spread itself!
Keith
Edited By Keith Long on 10/09/2013 14:20:22
donkey10/09/2013 15:12:00
85 forum posts
5 photos
I use the magnets from ikea. They are about three inches long and only cost £1.99 each so I have one on all machines. They have a plastic cover in various colours so easy to remove any swarf. I believe they are in the kitchen department and they are very strong. Easily holds up spanners and chuck keys. But yes they do magnetise slightly so go to pound land and get yourself a demagnetiser can't remember how much they cost.
Bri
Peter G. Shaw10/09/2013 15:24:03
1531 forum posts
44 photos
I too get fed up with magnetized tools, and whilst I do have an old, or even ancient, tape head demagnetiser which does work on small tools, it can be a right pain. On the other hand, sometimes it can be a boon, especially when trying to insert screws in awkward places. Personally, I would avoid, but then I do have the luxury of having various odd sets of drawers & trays around the place which suffice to hold all the tools associated with that particular piece of kit.
Peter G. Shaw
Geoff Theasby10/09/2013 15:43:24
615 forum posts
21 photos
I use magnetised tool holders all over my workshop, on overhead beams, tool cupboard doors and on the walls. I get them from CPC (Usual disclaimer) Swarf is easily wiped off. They are a good way of using empty space.
Geoff
speelwerk10/09/2013 16:21:17
464 forum posts
Magnets and tools are for me not a good combination, the one I have is stored far away and only comes in use when a small part lost and you are searching the floor to find it. Niko.
jason udall10/09/2013 17:20:41
2032 forum posts
41 photos
Look for self adhesive cable clips. .bit like terry clips in nylon
....use them on machine to hold specific wrenches (allen keys etc.) to that machine or tool set..in particular jacobs chuck key ..just next to the start stop buttons...
Bazyle10/09/2013 17:37:12
6956 forum posts
229 photos
This kind of plastic tool holder can be improvised with just 2 in wire mesh. Some areas can be subdivided into finer holes for smaller tools with a bit of wire. Good way of using up the bit of mesh left over when you have made security grills for your shed.
David Littlewood10/09/2013 18:06:27
533 forum posts
I tend to agree with the comments against magnietic holders. I use small strips of wood screwed to the wall; for allen keys, and other milling machine bits, this has vertical holes to take each item, and for ring spanners a small screw or pin for each spanner works well. Home made, scrap wood, cost zero.
The bracket to the right of the mill below shows the idea:
http://i980.photobucket.com/albums/ae281/dlittlewood/DRO-Console.jpg
David
Edited By David Littlewood on 10/09/2013 18:13:05
JA10/09/2013 19:09:44
1605 forum posts
83 photos
Magnetism is like a virus. Evententually you will find your milling cutters magnetised. This can lead to very poor finishes when milling steel.
JA
