Chris123 | 15/08/2013 18:24:13 |
123 forum posts | Hi, does anyone use a fly cutter to face aluminium? What shape should I make to the HSS tool bit? Any other advice?!
Thanks, Edited By Chris123 on 15/08/2013 18:25:44 |
JasonB | 15/08/2013 18:32:29 |
![]() 25215 forum posts 3105 photos 1 articles | Yep, I just round the corner over and give it 5-10deg or rake. |
Thor 🇳🇴 | 15/08/2013 18:42:32 |
![]() 1766 forum posts 46 photos | Hi Chris, Flycutting was discussed on this forum earlier. The toolbit need a bit more rake than for steel, and smooth surfaces. Have a look here, or here. Thor Edited By Thor on 15/08/2013 18:44:04 |
magpie | 15/08/2013 19:32:31 |
![]() 508 forum posts 98 photos | Hi Chris. I use a lathe profile tool in the fly cutter for all my fly cutting now. No more sharpening, just turn the insert round a little when it shows wear. Brass, ally, steel, cuts them all just fine. There are two more photos on the subject in my photos. |
Stub Mandrel | 15/08/2013 19:59:56 |
![]() 4318 forum posts 291 photos 1 articles | I use a basic HSS toolbit and get a mirror finish. Flycutting ally is one of the nicest maching operations. Neil |
Danny M2Z | 15/08/2013 20:05:53 |
![]() 963 forum posts 2 photos | Posted by Chris123 on 15/08/2013 18:24:13: > Hi, does anyone use a fly cutter to face aluminium? > What shape should I make to the HSS tool bit? > Any other advice? G'day Chris. If using a HSS tool, sharpen it as a LH lathe tool. I find that kero (paraffin) as a cutting lube can improve the final finish. Regards from the land of the kangaroo * Danny M *
Chris123 | 15/08/2013 20:09:51 |
123 forum posts | Thanks for your replys! i will have a look at the links later. I think I have an old LH lathe tool in an old size so I'll try that first tonight.
Thanks. |
_Paul_ | 15/08/2013 21:32:19 |
![]() 543 forum posts 31 photos | I use this for alloy cylinder heads
mechman48 | 16/08/2013 10:14:18 |
![]() 2947 forum posts 468 photos | Chris I have used a left handed carbide tipped cutter in a home made holder for some fly cutting, I used an old MT2 drill taper & machined a holder to suit the cutter. It has cut Brass, Ally, & MS without too much effort.. but only with light d.o.c. on. I now use a 4 tipped indexible insert for any fly cutting that I need to do & it has cut all materials quite effectively. Cheers George. |
Engine Builder | 16/08/2013 12:55:04 |
![]() 267 forum posts | Here's the one I use, it can be used in lathe or mill. As the sweep is large you get a nice finish and unless the work is large, you don't get the second cut so a nice finish is acheived. |
Chris123 | 18/08/2013 12:53:11 |
123 forum posts | Thanks for all the advice. I tried a piece of HSS with a radius on the end. I pretty much got a polished finish first time. The picture is below, it's HE30 / 6082 T6. 1000rpm, 50mm diameter cut, table speed between 12-252mm/minute (didn't really make much difference). I tried various different methods, even with the head tilted 0.5 degree so that it only cut once, I'm not 100% but I think when the leading side of the fly cutter was cutting it was a better finish and with the trailing side cutting it was a much worse finish. Using a traditional shape lathe tool gave a nice machined finish, similar to a computer disc.
However I think the best advice I read was to use the lathe instead!
I found a face cutter at a car boot sale this morning for £5 so will probably use that in future!
Thanks,
Edited By Chris123 on 18/08/2013 12:56:19 Edited By Chris123 on 18/08/2013 13:04:32 Edited By Chris123 on 18/08/2013 13:17:50 |
