Stationary Engine Series ME
Alex Collins19/07/2013 18:50:33
147 forum posts
38 photos
Hi. I'm a long time lurker in here. I build an engine most years, mainly stationary from whatever metal I have around. I have been looking for my next set of plans when up pops just what i'm looking for in ME This month. I think it's a cruel and tantelising trick to start a build with nothing to make ! I have been forced to start making round bits of metal the correct Dia for things like the Cylinder (Old bit of Cast Iron sash weight). may someone please give me Patience, but i want it now ! Alex.
Stewart Hart20/07/2013 06:39:46
674 forum posts
357 photos
Sounds like you have contracted engineprojectitius
Edited By Stewart Hart on 20/07/2013 06:40:11
JasonB20/07/2013 07:11:15
The problem is that if Stew started with some construction somebody else is bound to moan that there is no list of materials, you can't win
Stub Mandrel21/07/2013 10:17:45
4318 forum posts
291 photos
Don't listen to them. Stew did this on purpose, just to wind you up
Stewart Hart21/07/2013 10:28:00
674 forum posts
357 photos
Posted by Alex Collins on 19/07/2013 18:50:33:
I'd like to know where you're getting the sash weights from there as scares as rocking horse poo Your'e teasing me with that one Stew
Stub Mandrel21/07/2013 11:25:48
4318 forum posts
291 photos
Constipated rocking horse... the only one I have got is so hard a hacksaw bounces off
Gray6221/07/2013 12:26:51
1058 forum posts
16 photos
Neil, I had a couple of sash weights that were as hard as hard can be, chucked them in the wood burning stove and built the fire on top of them, left them there overnight with a slow burn and they have 'normalised' to a state where they were machinable. Turned out to be a nice bit of iron after that.
If you don't have a woodburner, a charcoal barby will suffice instead Just bury the iron in the embers after a good cook out and see what happens.smiley
Graeme
John Stevenson21/07/2013 12:47:36
5068 forum posts
Sash weights, quick check guide.
Bang one on the floor and break the end off, if it's a dull even grey all over on the break then keep it.
If it's got shiny bits in or shiney all over lob it at next doors cat.
When they were made sash weight were the last thing cast from a melt to use the metal up so they can vary from melt to melt.
A bit like pit props, the good wood goes for manufacturing, then it's pit props, then it's IKEA.
Alex Collins21/07/2013 13:09:22
147 forum posts
38 photos
The sash weights came form a Reclaim Yard. Paid a copule of £ for em. The crust is always hard as you like. Hacksaw will never touch it. Tipped lathe tool is the only answer. Clean out the old rope. Tail in the hole. Bottom in the chuck and away you go. Just part it off. HSS Tools will not do !
Nicholas Farr21/07/2013 13:25:18
3988 forum posts
1799 photos
Hi, 4 1/2" cutting disc will cut the rubbishy end off and cut the length you want to work with. Using a thin disc is best.
Regards Nick.
Ian S C22/07/2013 13:16:44
7468 forum posts
230 photos
Apart from one that shattered when I dropped it, the weights that I havecut easily with a hacksaw, or the bandsaw. The broken one was too hard for carbide tools, and I don't have a log burner, or Barby.
Ian S C
JasonB22/07/2013 13:25:40
I've been buying a few of the CI offcuts that Alan at MJ Eng has had recently. All about 6"x6" and 40-50mm think and around £5 each. At that price you can cut them into square section and then turn round and not worry about the waste. Some of our ME suppliers would be looking at £65 for an similar amount of 40mm sq bar!!
J
Stub Mandrel22/07/2013 20:11:17
4318 forum posts
291 photos
It's tough to supply model engineers - there's a big difference between offcuts from a major stockholder and being a man with a garage holding a good range of sizes. It could take twenty years to sell nine feet of 40mm CI bar a few inches at a time.
