Co2 Cartridges
Steamshy14/01/2013 04:16:59
38 forum posts
Ive got heaps of the small Co2 cartridges left over and for the life of me I cant think of a use for them, I hate throwing anything away that might come in handy one day. So any ideas what they could be used for would be appreciated. Andy
Hi Speed Scrap14/01/2013 06:14:08
23 forum posts
Steamshy, Whaaaat? cant think of a use for them?
Try this, it will give u great enjoyment! (or a headache!)
Step 1: Buy a soda syphon
step 2: use cartridges to make soda water, chill in fridge.
step3: make ice cubes
step 4: mix the ice and soda with your favourite whisky, at a suitable ratio of course!
step 4: at drink O'clock, consume at your leisure!
Then again you probably already did that, and these ones are empty!
Oh well, in that case I'm like you, cant think of a use for them!!
Dave.
Steamshy14/01/2013 06:49:49
38 forum posts
Thanks Speedy, Have tried all the above, The old grey matter is still frozen...as usual Andy
Bob Lamb14/01/2013 08:28:11
140 forum posts
51 photos
If they are "sparklets" bulbs I used to use them at school to make small self propelled projectiles. I'm sure the health and safety brigade would not approve but a length of tube (samish bore as the bulb) with a firing pin (from a flare I dismantled that my dad had brought back from WW2 and hidden in the loft) made quite a good rocket system! You had to carefully file down the lead end first to make it thin enough so the firing pin would make a good hole and if you took too much off it was a bit of a disaster.
I DO NOT RECOMMEND THIS IRRRESPONSIBLE SORT OF ACTIVITY! It was in a slightly different era when teachers encouraged an enquiring mind......................... I won't go into other "rocket" experiments which I gave up after one of them blew up on the launching pad - and I discovered a one inch "Jetex" fuse was not quite long enough!
Bob
Ian S C14/01/2013 11:52:26
7468 forum posts
230 photos
Hi bob, nice to see a like minded type. Great the bang you can make with match heads, Theold wax Vestas were the best. When I was about 12 I discovered how to make gun powder, and rockets.
Ian S C
Roderick Jenkins14/01/2013 12:03:21
2376 forum posts
800 photos
You could send one to Mike Suffolk, he'll need it for the Matador "silencer".
Rod
Jeff Dayman14/01/2013 13:33:48
2356 forum posts
47 photos
Assuming the cyls are empty, you could cut the ends off, deburr, mount in a suitable wood box, and use to store small hardware or taps or drills or files etc.
If they are still full, I would put them on ebay or Craigslist, someone is bound to want them and will probably pay money for them.
JD
Stub Mandrel14/01/2013 20:18:50
4318 forum posts
291 photos
Tsk! Tsk!
If the kids of today did what we did in our schooldays - they'd end up in Guantanamo Bay wearing zip-ties for bracelets.
Neil.
Clive Farrar14/01/2013 21:38:50
125 forum posts
41 photos
Sell them on e bay they are used extensivley in gas BB guns by the gaming fraternity.
Regards Clive
Stub Mandrel14/01/2013 21:46:33
4318 forum posts
291 photos
My air rifle takes CO2 cartridges that appear to be a slightly different size to sparklets bulbs.
_Paul_15/01/2013 00:59:13
543 forum posts
31 photos
Part of my motorcycle puncture outfit uses these type of cartidges as a "one shot" inflator
Once I've plugged the tyre hole I put the catridge in the adaptor/inlator blow up the tyre check pressure and adjust, means a ride home rather than the recovery truck.
All you need now is a motorcycle with a puncture....
RJW15/01/2013 09:00:17
343 forum posts
36 photos
Are the cartridges similar to these by any chance?
If selling on eBay beware of their prohibited items categories, otherwise you could end up with the listing being pulled and a policy violation recorded, I got done recently for a similar misdemeanour!!
Also check the courier's prohibited items, because any pressurised container with the potential to explode in an aircraft is likely to be banned!
Although some carriers will take them, I haven't found one with sane carriage costs!
I've got a couple of similar unused Butane cart's here, they're like rocking horse crap to find, but I can't sell them because I can't post them!
Steamshy15/01/2013 19:20:53
38 forum posts
I think Jeffs idea comes to mind as a good storage device for small drills etc, so will try out your idea Jeff as I am always drpooing those small drills. Yes the same size sparklet bulbs RJW but contained Co2, Postage would be a problem I guess so have ruled it out. My missus said they might make good fenders in one of my model boats....drrrrrr ! I wouldnt have thought they would contain enought gas Paul to blow up a tyre, but you learn something new every day. Thanks for all your ideas . Andy
Edited By Steamshy on 15/01/2013 19:21:33
mgnbuk15/01/2013 20:58:07
1394 forum posts
103 photos
My air rifle Co2 bulbs were supplied mail order from an Ebay vendor - 50 off sent in a Jiffy bag via Royal Mail. Also had a 2kg Co2 fire extinguisher supplied mail order via courier.
There appear to be several sizes for these - I use the plain neck "Crosman" type in the air rifle (14g Co2 IIRC), but used a smaller plain neck type (8g IIRC) for pressurising barrels when I used to home brew (they also fit the "charger" for a Humbrol C02 model aircraft motor). The tyre inflation bulbs in the motorcycle repair kit are bigger than either of the previous two & have a threaded neck for the tyre adapter to screw on to.
Nigel B.
Stub Mandrel15/01/2013 21:42:14
4318 forum posts
291 photos
Ditto Nigel.
My Crosman takes the larger ones and the sparklet adaptor for my Gasparin CO32 motor teh small one. I also have an adapator for the great big sparklet cylinders.
Will Robertson15/01/2013 22:28:52
162 forum posts
41 photos
Could machine a small cylindrical holder for them with a point to burst them as you screw the top on and a small valve to let the CO2 out as required - a handy source of small amounts of compressed gas when a compressor isn't nearby. Could also be used to power a steam engine for short periods of time for quick, highly portable demonstrations.
Handy as a cryogenic agent but in these tiny quantities may not be much use for anything.
I think they're planning to ban breathing soon because of the potential health risks...
Clive Hartland15/01/2013 22:34:32
2929 forum posts
41 photos
The inflating cartridge on a lifebelt is also banned in flights, you have to remove them before boarding.
If you let the pressure out of these Co2 cartridges then there is the risk of condensation occuring!
Bazyle15/01/2013 23:35:44
6956 forum posts
229 photos
I assume they are pretty strong so how about minirollers for moving machines.
Meanwhile I keep wondering about a use for plastic milk bottle tops. (Bottle part cut off is a handy container)
I.M. OUTAHERE16/01/2013 01:50:43
1468 forum posts
I would guess the cylinders are made of aluminium which would make it difficult to do much with other than drill storage . If they're steel ýou could solder on fittings and make small fuel tanks or exhausts for model i/c engines . Plastic milk bottle tops i have - I have read somewhere about melting these in wax to make a machinable wax that can be cast into what ever shape nedeed then machined to make patterns for casting etc. May have been in my local model engineering mag here in australia .
mgnbuk16/01/2013 07:42:38
1394 forum posts
103 photos
All the small cylinders I have used are steel. See how Crosman make theirs here :
Neil, I just have one of the Chinese Crosman rifle clones - a QB78. The fire extinguisher is intended to be a bulk refill station, when I get all the parts together.
