Jarek Ziel | 03/12/2012 08:29:22 |
1 forum posts | Hi! I'm not englishman, and i have trouble with some sentce. Can you explain to me what does it mean the "turn for grind"? I will very grateful. Jarek
Tony Ray | 04/12/2012 12:19:23 |
238 forum posts 47 photos | Jarek, 'Turn for grind' does not make any sense on its own, perhaps you are reading something that was e.g. translated from e.g. Chinese ? Turn is probably from the verb turning ie. to remove metal using a lathe. Grind in this is probably from the verb grinding i.e to remove metal by ginding eg as done by a cylindical grinder. if you could reply with thefull paragraph from where you have taken 'turn for grind ' I might be able to work it out for you.
Tony |
Ady1 | 04/12/2012 12:22:55 |
![]() 6137 forum posts 893 photos | "turn for grind" is bad english It has no meaning for us As mentioned, if you give us the entire sentence or paragraph then we should be able to help translate it into good english |
Robert Dodds | 04/12/2012 12:47:00 |
324 forum posts 63 photos | Jarek, Engineers have had a form of Text Speak for many years. You need to make clear where this statement is used but IMHO it is a short instruction to turn typically 0.5mm oversize to the dimension and then remove from the lathe and grind to finish size, maybe after hardening the part. Bob D |
magpie | 04/12/2012 13:55:34 |
![]() 508 forum posts 98 photos | Tony. if Jarek do'es not understand english very well he will have trouble with e.g. and i.e. Robert. He will also probably not understand IMOH. But i agree with you both that we need the full sentence in order to grasp the meaning. Cheers Derek. |
Siddley | 04/12/2012 14:13:42 |
![]() 150 forum posts 1 photos |
Jarek - can you find a 'scientific and technical' dictionary in English and your own language ? That is what I had to do when I emigrated to Spain. It will help you a lot. |
Split Pin | 04/12/2012 17:13:55 |
13 forum posts 1 photos | "turn for grind" is as described by Bob D, it is an instruction to a skilled operater in a machine shop to indicate that there is a need for further machining on that part of the job to complete it, either a particular surface finish is required or a more precision size than would be normally achieved from commercial turning i.e 0.0001" or 0.001mm, Depending upon heat treatment method different allowances would be added, the original drawing may have been produced for in house use where all the participants understand the process of manufacture, and no doubt contains more information than is being presented by the original poster Steve G |
Grizzly bear | 04/12/2012 17:28:34 |
337 forum posts 8 photos | Hi Jarek, Where are you from, Poland? Come back on the forum, you will get good help. (I have typed this slowly, so it will be easier to read). Regards, Bear.. |
DMB | 04/12/2012 17:33:06 |
1585 forum posts 1 photos | Jarek, Hope this might help - i.e. = Latin abbreviation for id est, English = that is. e.g. = Latin abbreviation, English = for example. IMHO = modern computer abbreviation = In My Honest Opinion. The two Latin abbreviations are commonly used. John |
GaryM | 05/12/2012 23:52:57 |
![]() 314 forum posts 44 photos |
Posted by DMB on 04/12/2012 17:33:06:
<snip>......IMHO = modern computer abbreviation = In My Honest Opinion.....<snip> John
I think IMHO is normally taken as In My Humble Opinion although David Cameron may disagree |
Terryd | 06/12/2012 13:16:15 |
![]() 1946 forum posts 179 photos |
Posted by Gary Marland on 05/12/2012 23:52:57:
LOL
Robert Dodds | 06/12/2012 18:07:44 |
I think IMHO is normally taken as In My Humble Opinion although David Cameron may disagree I KNOW I meant "humble" when I wrote the original. I always try to be humble but I can't say I'm always honest. For the future I will resort to using full written English especially as all this banter seems to have scared off poor Jarek .
I think it was Grizzly's joke about slow reading that startred the rot..... Polish jokes are only for Americans to tell, the English tell jokes about the Irish and Germans lampoon the Bavarians. Cross the boundaries at your peril! Bob D
FMES | 06/12/2012 18:51:24 |
608 forum posts 2 photos | I would have thought it meant turn to a size leaving an allowance for grinding, i.e a couple of thouu oversize on a crank say, to allow for journal grinding. and then as I read up the posts - exactly what Split pin said. |
Stub Mandrel | 06/12/2012 19:34:11 |
![]() 4318 forum posts 291 photos 1 articles | I have enough Irish in me to tell Kerryman jokes (my bit is from Cork). > I think IMHO is normally taken as In My Humble Opinion although David Cameron may disagree "I My Hugs Often", perhaps? addressed to Ed Balls, no doubt...
Neil |
Takeaway | 07/12/2012 08:53:58 |
108 forum posts | Turn to grind = cut (turn) metal part using lathe but leave + 0 .3 - 0.5mm on outside diameter and smaller same amount in holes. 0.3 - 0.5 is called "grinding allowance". Then grind part to finish size. I hope you understand. Stuart |
