John Stevenson | 25/11/2012 23:00:40 |
![]() 5068 forum posts 3 photos |
OK been working on doing some harrison M300 screw cutting plates.
John S. |
DMB | 25/11/2012 23:27:23 |
1585 forum posts 1 photos | Hullo John, Dont know how you illuminated subject but my thinking is along lines of something to diffuse the light source or even lighting aimed opposite direction and reflected back to subject, possibly with a mirror. Rgds, John |
John Stevenson | 25/11/2012 23:45:39 |
![]() 5068 forum posts 3 photos | Gert has a light box for doing photo's but to be honest point and click is good enough for me. My interest is in machining, everything else is peripheral. |
mark mc | 26/11/2012 08:22:33 |
92 forum posts 16 photos | That is very nice, very tidy. I would love to be able to do things like that. |
Michael Gilligan | 26/11/2012 08:43:56 |
![]() 23121 forum posts 1360 photos | Nice work John Thanks for letting us learn at your expense ! MichaelG. |
NJH | 26/11/2012 10:01:37 |
![]() 2314 forum posts 139 photos | Hi John Nice plates - bad 'photos - point and click just 'aint good enough! Yes the answer is to diffuse the light source. ( Photos could be a bit sharper too) Speak nicely to Gert and enrol her services in the light tent. As you well know the best work can be spoilt by lack of attention to detail. ( I still think the plates are good though and I guess it's better than good pictures of bad plates). Cheers Norman
Edited By NJH on 26/11/2012 10:04:31 |
V8Eng | 26/11/2012 13:06:05 |
1826 forum posts 1 photos | If the stuff is easily moveable take it outside on a cloudy day and take the pictures, that usually works for me. But do not let the camera's built in flash operate! Edited By V8Eng on 26/11/2012 13:12:31 |
_Paul_ | 26/11/2012 13:43:22 |
![]() 543 forum posts 31 photos | The perspex one looks really good _Paul_ |
Billy Mills | 27/11/2012 09:35:39 |
377 forum posts | Hi Sir John, Have used celulose as a resist coat, laser off the paint then etch. Fill the etch with paint then wipe off the surface. Also useable for PCB's. Would agree with the comments about the "industry standard aerosol". We do a lot of perspex signs, as you say the backside paint then engrave and contrast coat works great. For illuminated signs you can paint a ground colour ( say red) then overcoat white then engrave through the lot. The white reflects back the light into the box giving more even and brighter lighting. Your warping stainless might be down to too much power and too slow movement, it is always good to start low and work up rather than using cutting power but I have not used the molly route myself. I am always very careful about just what gets exposed, few months back witnessed the effects of cutting PVC in a CO2 machine, everything was corroded and the control board was a write off. It is a good idea to check the lens after blasting at something unusual, debris will significantly reduce power in some machines where the air assist is not so good. Billy. |
Robin teslar | 27/11/2012 18:13:37 |
![]() 127 forum posts 8 photos | Photo tip FWIW You need and old white bedsheet, then perhaps a dining chair that you can push the squab out or something to make a box frame. Drape the sheet over to form a white box. Direct some strong lights on the sides, cut a hole in the centre of the top sheet to point the camera down and shoot, do have a plain matt background (green is good) It the way to take those tasty plates of food pix for example
Robin |
Clive Hartland | 27/11/2012 20:45:53 |
![]() 2929 forum posts 41 photos | A good light box can be made with crumpled up kitchen foil attached to all the inside surfaces of a large cardboard box. If the object has a lot of shiny surfaces then place it in a cold fridge for a while and it will be less shiny when you take it out because of condensation ( Good for silver or plated objects) not precision machinery of course. Outside, a muslin covered frame will filter the light and remove extreme dazzle points. Clive Edited By Clive Hartland on 27/11/2012 20:46:22 |
varonica leon | 22/03/2013 11:50:27 |
1 forum posts | Informative post thanks for sharing with us. It's very useful for me. |
