chris j | 08/09/2012 17:02:54 |
338 forum posts 17 photos | I have been looking at some plans for various bits of kit and noticed that Harold Hall notates his drawings with a numbers like Steel 230M07 and Steel 080A15. What do these numbers denote and are there lists of the different kinds ? |
Brian O'Connor | 08/09/2012 18:51:06 |
74 forum posts 19 photos | Hi Chris, They are BS numbers, which replaced the old wartime EN numbers back in the 70s. The first one, 230M07, is a free-cutting carbon steel (the 2) having 0.3% sulphur (30) and 0.07% carbon (07). The M denotes that is complies with required mechanical properties. It is the same as the old EN1A, the steel so beloved by model engineers. The 080A15 is a 'straight' carbon steel (0) having 0.8% manganese (80) and 0.15% carbon (15). The A denotes that it complies with required chemical properties. Every country seems to have its own set of standards but there are cross-reference lists on the web, often on steel manufacturers' sites. I have such a list but can't remember where it came from. If you are interested I'm sure that Googling 'steel grades' or something similar will bring up something. Regards, Brian |
chris j | 08/09/2012 19:26:33 |
338 forum posts 17 photos | That's great Brian, thanks.
Wolfie | 08/09/2012 23:33:34 |
![]() 502 forum posts | I generally get my metal from M Machine in Darlo cos they are local. When you look at their listings they will provide the BS numbers. I have to assume that other suppliers do similar..
chris j | 08/09/2012 23:40:15 |
Posted by Wolfie on 08/09/2012 23:33:34:
Yes my local supplier will use numbers but they don't mean much to me at this point in my engineering life. For example the two numbers in the OP that Brian explained in great detail for me (thanks) however it went over my head a bit. That said I realise I can't expect eveyone to spoon feed me info but it gives me something to work with. |
David Littlewood | 09/09/2012 00:03:44 |
533 forum posts | Chris, You might find this book quite a useful introduction to most of the materials of use to model engineers, including the commonly used steel grades: **LINK** David |
chris j | 09/09/2012 00:11:43 |
Posted by David Littlewood on 09/09/2012 00:03:44:
Chris, You might find this book quite a useful introduction to most of the materials of use to model engineers, including the commonly used steel grades: **LINK** David Brilliant thanks |
Harold Hall 1 | 09/09/2012 13:56:03 |
418 forum posts 4 photos |
Having Chris J referred to the specification numbers I quote for my projects I feel I should comment. There are hundreds of steel specifications but only a handful will ever find a place in the home workshop and of the handful two are likely to cover 99% of all steels required in the majority of workshops. |
chris j | 09/09/2012 14:03:03 |
338 forum posts 17 photos | Thanks everyone for all for the help. Good answer Harold, nice for a learner driver like me ! Chris |
Harold Hall 1 | 09/09/2012 15:04:14 |
418 forum posts 4 photos | How come the smiley, together with extra characters, appeared in my comments above?, I did not put it there. Harold |
chris j | 09/09/2012 15:29:11 |
Posted by Harold Hall 1 on 09/09/2012 15:04:14:
How come the smiley, together with extra characters, appeared in my comments above?, I did not put it there. Harold It's just a little comuter glitch is my guess. |
Bernard Laycock 1 | 09/09/2012 15:45:51 |
32 forum posts | I think you're gilding the lily a bit. Most of the model engineer suppliers that I'm aware of don't quote the BS numbers for any of the metals they supply, indeed I remember phoning one to ask if they sold EN1A steel and the reply was "All our steels are free-cutting". And stainless steel is even worse. If anyone can tell me the name, address and phone number of a supplier who even knows about metal grades and is prepared to sell small quantities, I would be delighted to shop with them. Bernard |
Russell Eberhardt | 09/09/2012 16:06:52 |
![]() 2785 forum posts 87 photos | A useful table showing these steels can be found here.
Unfortunately this numbering system (to BS.970) has been superceded by that in BS. EN. 10027 which I find very confusing and gives very little information as to what each grade is suitable for. Here in France most suppliers stick to the old French system. Russell. |
chris j | 09/09/2012 16:11:47 |
Posted by Bernard Laycock 1 on 09/09/2012 15:45:51:
Bernard This guy seems very knowledgable and likes to chat. He is in Great Yarmouth but will have whatever you want delivered straight to your door. Chris |
David Littlewood | 09/09/2012 16:19:37 |
533 forum posts |
How come the smiley, together with extra characters, appeared in my comments above?, I did not put it there. Harold Harold, I drew David C's attention to this problem last month; see: **LINK** David |
David Littlewood | 09/09/2012 16:23:18 |
533 forum posts | Bernard, I think you have been a little unfortunate in the metal supplier you approached. I have found the chaps at Mallard Metal Packs, **LINK** and Noggin End Metals, **LINK** are both helpful and knowledgeable, and are often able to source specific grades of metal not in their normal catalogue. David |
Harold Hall 1 | 09/09/2012 17:51:40 |
418 forum posts 4 photos | The following Bernard are two suppliers who advertise in ME/MEW and who stock a vast range of metals, not only steel but many others, some special. In almost all cases they quote either the earlier of present day specification numbers. MK Metals even supply additionally to EN1a/230M07 the leaded versions. MK Metals at **LINK** M-Machine at **LINK** If a supplier states only bright mild steel then this is probably what they ordered. If they had ordered, say ENI A, surely they could quote in the catalogue Free cutting mild steel EN1A. If then they only ordered bright mild steel they are at the mercy of accepting what ever the supplier chooses to supply, which may differ from batch to batch I am presently trying to use up steel that I purchased before I took this decision to be more demanding as to what I am being sold. As a result, I often find myself using material that does not machine as well as I would like and am very tempted to dispose of it as scrap, but the bank manager part of me often prevents that.. Harold
Stub Mandrel | 09/09/2012 19:49:34 |
![]() 4318 forum posts 291 photos 1 articles | metals Supermarket give the EN numbers of all their steel, including short ends, and have a wide selection. I have EN1A in 1 1/2" and 2 1/4" bar at the moment, and straight square EN1A which machines almost as well. Neil |
jason udall | 10/09/2012 00:48:48 |
2032 forum posts 41 photos | Just a thought ... Model engineers are not alone in "having trouble" with "new" EN specs Eg EN 230M07 At work we are increasingly seeing drawings with EN numbers ( not to be confused with EN1A) so faro good..now customer wants this spec and this spec only needs mill cert. for metal BUT has to say (for exmple) EN 230M07 . A mill cert. declaring EN1A will not do. No the mill can't put both on cert. or supply cert saying (for exmple) EN 230M07.. nor can any other mill...."funny" says customer.."had all our suppliers saying them same thing..."
Used En1a as example but real nightmare in bronzes even when the specifed bronze has wider spec. than an available alloy...
So you are not alone ,at least many tables of equivalents are available online to model engineers and sec.s are "converted" easily...shame customers can't read for themselves
Nathan Sharpe | 10/09/2012 21:24:37 |
175 forum posts 3 photos | While not quite on topic but still a "materials" point, I emailed CES today and had my mail intercepted by "Spamarrest". They asked me to verify my email address before me email would be forwarded to CES. Anyone else had this happen? I will delete the email and phone them instead. |
