Exe lathe
Nobby | 21/08/2012 13:35:26 |
![]() 587 forum posts 113 photos |
Edited By Nobby on 21/08/2012 13:35:40 Edited By Nobby on 21/08/2012 13:36:31 |
Ian S C | 21/08/2012 14:37:17 |
![]() 7468 forum posts 230 photos | Nice one Nobby, foot motor, or electric? Should look good, with the rust gone, and a bit of paint. Ian S C |
Nobby | 21/08/2012 16:48:47 |
Hi Ian
Les Jones 1 | 21/08/2012 18:42:45 |
2292 forum posts 159 photos |
Hi Nobby, Les. |
Nicholas Farr | 21/08/2012 19:28:39 |
![]() 3988 forum posts 1799 photos | Hi Nobby, might there be a small grub screw or two inbetween the teeth. If all else fails, maybe you could take the handwheel off the other end and withdraw the leadscrew, and then maybe get a better look at how it is fixed on. Regards Nick. |
NJH | 21/08/2012 20:00:00 |
![]() 2314 forum posts 139 photos | Hi Nobby Well that should keep you busy for a bit! It looks reasonable cosmetically so a bit of elbow grease should make a big impression. I find this type of project very rewarding - bringing stuff back to life so to speak. Do you intend to treat us to a photo diary of your restoration? ( please!) Norman
Edited By NJH on 21/08/2012 20:01:23 |
Nobby | 21/08/2012 20:06:59 |
Hi Guys |
NJH | 21/08/2012 20:11:21 |
![]() 2314 forum posts 139 photos | Nobby I notice that Tony ( at Lathes.co.uk) is seeking photos of this lathe - no doubt you will already have seen the information presented there. I guess he might be a useful contact re removing bits? N |
Nobby | 21/08/2012 21:34:12 |
Cheers N Edited By Nobby on 21/08/2012 21:37:39 |
Nobby | 21/08/2012 22:01:07 |
Hi Les |
Ady1 | 21/08/2012 23:18:30 |
![]() 6137 forum posts 893 photos | You can use an old shifter, (adjustable wrench) with a couple of stainless pins drilled and inserted into the jaws One size fits all as you open the wrench up, an adjustable pin spanner
Have fun nobby
Ady1 | 22/08/2012 00:04:40 |
http://www.practicalmachinist.com/vb/general/making-spanner-wrench-168434/ |
Nobby | 22/08/2012 09:54:43 |
Hi Andy nobby |
Martin W | 22/08/2012 11:19:40 |
940 forum posts 30 photos | Hi Nobby Looking closely at your photo of the gear it looks like there might be a seam between the gear and the part with the holes in. If so could the part with the holes in it be a collar that screws onto the shaft and locks the gear onto a keyed shaft. That way it would allow different gears to fitted to the lead screw shaft. Just a thought Martin |
Ian S C | 22/08/2012 13:40:22 |
![]() 7468 forum posts 230 photos | No sure of the protocol here, a driven shaft on the LH end, would it have a left hand thread? Or would that be on the driving shaft? Just thinking out loud, sorry if I confuse things. Ian S C |
Springbok | 22/08/2012 16:10:07 |
![]() 879 forum posts 34 photos | Well when you have finished it will you put it into a museam as a working machine Bob |
Nobby | 22/08/2012 20:23:01 |
Hi Nick & Guys |
Stub Mandrel | 22/08/2012 20:47:50 |
![]() 4318 forum posts 291 photos 1 articles | Looks a worthwhile project Nobby.
I like Ady's adjustable pin spanner Neil |
Nicholas Farr | 22/08/2012 21:13:35 |
![]() 3988 forum posts 1799 photos | Hi Nobby, I should have realised that it was a collar with pins through the gear and into the leadscrew. Same type of keying that you get with the old Drummond and one or two other makes of lathe from that era. Martin's obsevations said it all really. I'd say the threaded hole up the middle of the leadscrew would be for a set screw for retaining it all together when in use, as I suspect that the gear and the collar are normally just a sliding fit. Hope the rest of the rebuild goes OK and I bet it will look a nice machine when it's finished. Regards Nick. Edited By Nicholas Farr on 22/08/2012 21:28:18 |
Nobby | 23/08/2012 17:56:05 |
Hi Nick . Ian & Guys
Edited By Nobby on 23/08/2012 18:01:11 |
