missing motor
Dave Owen19/08/2012 13:05:15
29 forum posts
Hi
hope someone can help, i have finally built a workshop ( after 20 odd years without one) and have been rebuilding my warco 220 lathe which was carefully stored away. unfortunatly i can not find the motor, obviously i put it away too carefully. I have contacted warco and they were very helpfull in supplying details of the motor and where i can get one from, sadly this option is very expensive, probably about £300 in all, does any one have any ideas about a cheaper option?
thanks in advance
KWIL19/08/2012 16:08:11
3681 forum posts
70 photos
What size of motor is it you are looking for? Details would help to locate one.
Peter G. Shaw19/08/2012 16:17:28
1531 forum posts
44 photos
Hi,
Not so much an idea about where to obtain a replacement motor, but more an idea about what to get - if you see what I mean.
I can't remember what the nominal speed is of the existing motor, but if possible, how about a 2-speed motor - one speed being the normal speed, with the other being a slower speed. This would then allow for a reduction in the minimum speed of 125rpm which would make screwcutting under power easier.
Alternatively, how about going 3-phase, apparently much smoother and can also have variable speed along with a jog facility.
Or finally, go DC along the lines of other lathes and milling machines, eg my MiniMill has a 500W DC motor - the 220 has a 550W AC motor so not much difference there in power but can be speed controlled. Apparently the Seig or equivalent controllers, and I assume motors, are available as spares.
In fact, a combination of speed control and the existing belt arrangement would mean that the actual speed control range could be limited which would simplify the control arrangements and would not result in as much torque loss.
As you may gather, I have a 220 lathe and the possibility of achieving a lower speed range down to say 15rpm or so has long intrigued me.
As I say, just some random thoughts.
Peter G. Shaw
Dave Owen19/08/2012 17:05:19
29 forum posts
hi details of motor: are : 1 phase 7AACC size 80 D19 .55kw 1425/1430 rpm B14B flange plate mount N110 capacitor start
thanks for quick replies
David Littlewood19/08/2012 17:14:02
533 forum posts
Dave,
For not that much more than £300 you could buy a 3-phase motor and a VFD, and you would find that was very much better than a 1-phase motor.
David
FMES19/08/2012 17:17:52
608 forum posts
Try http://www.rotor.co.uk/index.html
Ketan Swali19/08/2012 17:24:51
1481 forum posts
149 photos
Posted by Peter G. Shaw on 19/08/2012 16:17:28:
Peter,
He will be better off going down the 3-phase motor and invertor route. Using the normal brushed motor with SIEG controller for a differnt application is not advisable. they are better suited 'as spares" to replace exisiting SIEG breakdowns. The same applies to the brushless motor with SIEG controller, even though it has higher torque than the brushed versions. Also, the brushless option would work out dearer than the 3-phase motor and invertor option. May be good idea for David O to discuss with Transwave, unless WARCO already asked him to do this.
Ketan at ARC.
Peter G. Shaw20/08/2012 17:26:35
1531 forum posts
44 photos
Hi Ketan,
As I said, just some random thoughts to consider if having tosource a new motor. Certanly if my motor failed, I would look at alternatives along the converter/3-phase line.
Peter G, Shaw
Jon21/08/2012 10:56:12
1001 forum posts
49 photos
010210430
£89.99
From Machine Mart just check the spindle dia or bore out existing.
Ady121/08/2012 11:20:41
6137 forum posts
893 photos
Drummond Lathe
I bought a modern sealed motor but it ran very hot when the going got tough, especially if I was doing hours of backgear work
So I retro fitted the old scroggy chunky electric motor which came with it when I originally picked the lathe up and it's been great
This sort of thing
They are really built to "last forever", like your mums old Hoover or a Singer sewing machine
2c
Stub Mandrel21/08/2012 21:00:27
4318 forum posts
291 photos
For £250 I'll help you look for it
