Ady1 | 07/08/2012 23:31:17 |
![]() 6137 forum posts 893 photos | On fleabay, but it's the interchangability of composite sections which makes it interesting Almost like a Transformers Toy Remove the X at the beginning of the www.Xebay link to view |
David Littlewood | 08/08/2012 00:01:54 |
533 forum posts | Link didn't work for me. David |
John Stevenson | 08/08/2012 00:11:20 |
![]() 5068 forum posts 3 photos | For some reason he put an X infront of Ebay ?
Alistair Grant 3 | 08/08/2012 00:14:35 |
5 forum posts | David, Just go to ebay site and search for 330767741825. This is the item number |
Michael Gilligan | 08/08/2012 00:21:29 |
![]() 23121 forum posts 1360 photos | Here is Cool Tool website and there is a promotional video on You Tube, dated 04-Dec-2007 [not for me, thanks] MichaelG. |
Ady1 | 08/08/2012 01:02:32 |
![]() 6137 forum posts 893 photos | For some reason he put an X infront of Ebay ? fleabay links are verboten in here |
Gone Away | 08/08/2012 01:43:40 |
829 forum posts 1 photos |
Posted by Ady1 on 08/08/2012 01:02:32:
Are they? When did that happen? .... seems to me there have been plenty in the past |
Springbok | 08/08/2012 05:12:23 |
![]() 879 forum posts 34 photos | Ve haf vays of makeing you talk so you had better explain vy das ist verbotten!!
Bob |
Michael Gilligan | 08/08/2012 07:41:22 |
![]() 23121 forum posts 1360 photos | One interesting point ... mentioned in the text under that You Tube Video
The availability of [very] long beds and cross-slides. That's a significant advantage of using extrusions ... I wonder if they are available individually ? MichaelG.
______________________________________________
The availability of [very] long beds and cross-slides. With a nod to Michael Williams' comments on the Metalmaster thread ... obviously there would be terrific problems with alignment at those distances ... but it would be very useful raw material.
Edited By Michael Gilligan on 08/08/2012 07:43:16 |
Michael Gilligan | 08/08/2012 07:58:01 |
![]() 23121 forum posts 1360 photos | O.K. "Cool Tool" suddenly gets very interesting. Would this install and run on a Raspberry Pi ??? MichaelG.
First thoughts are here GPIO looks the way to go Edited By Michael Gilligan on 08/08/2012 08:15:40 |
David Clark 1 | 08/08/2012 09:05:02 |
![]() 3357 forum posts 112 photos 10 articles | Who banned Fleabay links then? We might delete them if somone consistently posted links to their own auctions otherwise we leave them alone. They are obsolete in a few weeks anyway so not a good idea. regards David Edited By David Clark 1 on 08/08/2012 10:13:14 |
DerryUK | 08/08/2012 10:06:25 |
125 forum posts | <Would this install and run on a Raspberry Pi ???> There is a caveat in LinuxCNC requirements that video and system memory should be separate ie not shared in system memory. The way things are going with RasPi though someone will crack it. |
Michael Gilligan | 08/08/2012 10:33:44 |
![]() 23121 forum posts 1360 photos | Thanks Derry, I will sit back and wait for the Geeks to do something amazing. MichaelG. |
Peter G. Shaw | 08/08/2012 12:46:44 |
![]() 1531 forum posts 44 photos | This is the metal version of the original Unimat 1 which is a very low power machine using plastic & aluminium. Peter G. Shaw
Kevin Bennett | 08/08/2012 18:40:54 |
![]() 193 forum posts 56 photos | hi all you can do anything with this type of aluminium extrusion if you want to be creative you can get all types of aluminium extrusion from Flex link i am having a go at using it for a cutter grinder using the 40 x 40 mm section. i am lucky as i have a contact at my old work place so i can get hold of small off cuts TY Kevin |
