mick | 02/07/2012 11:20:33 |
421 forum posts 49 photos | I've been looking on-line for over half an hour for an "O" ring supplier, I only need one 3/8th. or 9.50mm O/D "O" ring, I'm quite happy to buy the minium quantity of 20 but not too happy about the minium order of £10 + VAT + £3.75 p&p Any body know of a friendly supplier?
Flywheel | 02/07/2012 11:31:08 |
34 forum posts 1 photos | Why not try your local Bearing/oil seal supp;ier they will probably sell you just the one |
Windy | 02/07/2012 11:51:21 |
![]() 910 forum posts 197 photos | ALDI sell boxes boxes of imperial and metric o rings if not in now they eventualy come back in the store. Polly might be able to help If desparate PM me with dimensions id od and diameter of cord as long as it's not a special material required (silicon?) will see what I have. Windy Edited By Windy on 02/07/2012 11:53:59 |
Roger Woollett | 02/07/2012 12:11:51 |
148 forum posts 6 photos | I have used Simply Bearings in the past and found them very reasonable. They list 9,5 i/d, 12.5 o/d nitrile rings as £2.29 + VAT for 2off. Postage is £1.50. They have a big range and a choice of materials. Roger Woollett
Terryd | 02/07/2012 13:20:07 |
![]() 1946 forum posts 179 photos | Hi Mick, Try Macc models, I have bought quite a few 'O' rings of various materials and sizes and he sells singles. It is worth looking through his extensive catalogue to stock up on a few items to make P&P worthwhile as he charges by weight. In fact he is showing a 3/8" od, 1/4" id silcone 'O' ring for 29p at the moment here. Regards Terry Edited By Terryd on 02/07/2012 13:21:12 |
DMB | 02/07/2012 14:40:04 |
1585 forum posts 1 photos | Hi Mick, Stuff the postage, put them on shopping list for xbns., e.g., Guildford next weekend, Bristol in Aug. If you live near enough, Ardingly showground also next weekend - lots of micellaneous stands there. Bound to be one flogging black rings. John |
Gordon W | 02/07/2012 14:45:49 |
2011 forum posts | I usually get this sort of thing at the local garage (Car repair ) or tractor place. Generally have selection boxes and different materials. |
Phil Ashman | 02/07/2012 15:33:50 |
33 forum posts | I've bought O rings from this company, I think they come in bags of 20, but they're not too expensive, about £7 for 9.5mm. Phil |
Mike p | 02/07/2012 16:22:35 |
27 forum posts | Hi, I have just looked in Blackgates Engineering catalogue and find the 3/8" od listed at 36p. I have used them before and found them most helpful. My catalogue is for 2009 I doubt they have increased by much. Their phone No. is 01924 466000 or www.blackgates.co.uk Mike p Edited By Mike p on 02/07/2012 16:30:35 |
mick | 02/07/2012 16:42:42 |
421 forum posts 49 photos | Thanks to all, knew I could count on the collective grey matter as usual. Mick |
Jon | 02/07/2012 18:00:10 |
1001 forum posts 49 photos | Depends what you want and where you get them from, the sizes are nearly all different even though conform to BS. How many do you want in nitrile or viton and cross section? i can post you some.
Stub Mandrel | 02/07/2012 21:47:09 |
![]() 4318 forum posts 291 photos 1 articles | Try screwfix or machine mart for selection boxes for abouit £5-7. IIRC they are metric, but in small steps so you will probably find one you can use with little adjustment. Chronos do better quality ones in small quantities. Neil |
Gordon A | 02/07/2012 22:39:52 |
157 forum posts 4 photos | Greetings Mick, You could maybe take a look at this place. Not used them myself, but they appear to have a good range of products. http://www.polymax.co.uk/ Gordon. |
