Reaming Brass
12mm hole x 4mm width.
Clive Hartland27/06/2012 18:05:09
2929 forum posts
41 photos
Am making 4 x cranks with a 12mm hole in one end. OK, bored to within about .05mm and then put a good 12mm reamer through but they chatter, the holes come to size OK.
Any comments, apart from doing it slowly and lubricate etc?
blowlamp27/06/2012 18:18:09
1885 forum posts
111 photos
I'd leave a bit more meat for the reamer to bite into.
I usually ream brass dry, but sometimes use paraffin if needed.
Martin.
Michael Gilligan27/06/2012 20:08:52
23121 forum posts
1360 photos
Classic problem with Brass
Clockmakers use 5-sided Broaches for that very reason. [The resulting negative rake angle works a treat] ... unfortunately these are usually slightly tapered over the whole length; but I guess you could make something with a parallel section.
Speedy Builder527/06/2012 20:39:07
2878 forum posts
248 photos
I bought some strange reamers some time ago, they have 3 or 4 flutes machined on a quadrant of about about 100degrees and on the rest of the diameter (260 deg) there are NO flutes.. I was told that they may be for thin sheet. This probably doesn't hep you, but another trick was to put some rag around the reamer to 'fill' the flutes and reduce chatter. Use talow or lard as cutting lubricant.
Mark Foster 128/06/2012 01:26:36
34 forum posts
try some matches in the flutes
Terryd28/06/2012 06:31:04
1946 forum posts
179 photos
\hi \live,
Use an accurate D bit. Can be made easily at home using silver steel. Inexpensive, very accurate and no chance of chatter. G H Thomas gives a good account of how to make one in his book 'The Model Engineers Workshop Manual',
Terry
Richard Parsons28/06/2012 08:42:11
645 forum posts
33 photos
How many 'blades' do your reamers have/ I was always taught that whilst you cannot 'mike' a 5 bladed reamer it cuts better and gives a better finish.
I have some 6 bladed reamers but you have to use them at the right speed to get them not to chatter.
To clean up a 0.05 mm hole I would use a tool makers broach. This is a bit of bar of the right size which has been slash cut across irs end at about 10 degrees. If it is well polishes with sharp edges it leaves a beautiful finish, but take it slowly with lots of oil.
Rgds
Dick
pierre ehly 228/06/2012 09:25:28
25 forum posts
Hi,
Speedy Builder,
This type of reamer are called "alesoir facon paris"
http://magafor.net/article.php?grp=822&famille=675
very good finish
brgds
pierre
Swarf, Mostly!28/06/2012 09:41:08
753 forum posts
80 photos
Hi there, Clive,
Please check your PMs (different subject).
Best regards,
Swarf, Mostly!
Ian S C28/06/2012 10:33:47
7468 forum posts
230 photos
I'd go with Dick's tool makers reamer, I often use these, usually un hardened for one off jobs. If you use an ordenary reamer on brass, it should be one that is reserved for brass only, just as with files. Use it with steel, and it looses its edge. Ian S C
Michael Gilligan28/06/2012 10:56:59
23121 forum posts
1360 photos
Pierre,
That's very useful, thanks
A clever design, which should have "self-aligning" properties because of the full radius "plain bearing"
... I would expect them to be good for deep holes.
Richard Parsons28/06/2012 12:02:51
645 forum posts
33 photos
Yes I often use tool maker's broaches unhardened. I also hone the small ones in a clock makers screwdrivers honing jig I can get them razor sharp that way.
a 4mm hole 12 mm deep is a doodle. But go slow and use only a light pressure they can be greedy things.
Rdgs
Dick
Ian S C28/06/2012 15:38:30
7468 forum posts
230 photos
A slight clearance can be gained by leaving a slight bit of a burr on the edge after sharpening, or possibly on resharpening after reaming the hole to dead size. Ian S C
