Member postings for pierre ehly 2
Here is a list of all the postings pierre ehly 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Unidentified Rule
26/02/2018 08:29:08
hi,
French & English sector (the ancestor of computer)
Thread: Unusual reamer
16/02/2018 08:21:16
Thanks guy's
Shared knowledge is better
p-mick
15/02/2018 12:44:05
hi,
The reamer is called " alesoir a main facon paris" (hand reamer paris style)
Advantages are better finnish & lower tolerance possible (H7,H6&hellip
http://www.magafor.com/article.php?grp=822&famille=675
p-mick
Thread: Keyway cutter for Myford
12/12/2017 14:44:27
Hi,
See ME 17jul1970
Lathe planing adapter by LC Mason
P
Thread: Looking for a 1/4" ratchet
09/02/2017 15:59:53
Hi,
The rolls-Royce of tools:
Snap-on Box ratched (1/4x5/16)
pm
Thread: Myford change wheels
28/12/2016 17:38:52
Andrew,
and for metric thread
20, 21, 21, 25, 30, 35, 40, 45, 50, 55, 60, 65, 70, 75
p-mick
Thread: 38 Tpi thread
16/02/2014 18:46:21
Cleeve,
Harold hall site
http://homews.co.uk/page30.html
brgds
pierre
Thread: Myford quick change gearbox questions
09/01/2014 10:21:04
Hi,
The ML7 was built with an 5/8" LS until Apr73 (sn:K111727) and the S7 use a 3/4" LS.
Both machine using the same Gbx, an adaptation muss be available.
pm
Thread: Silver Soldering Tungsten Tig Electrodes to Mild Steel
10/09/2013 09:40:57
Hi,
Carbide brazing process explained here
21-jan-2013
Read "Popular mechanics oct 1952"
http://books.google.fr/books?id=jdwDAAAAMBAJ&pg=PA211&lpg=PA81&ots=KUR9lUj5EQ&dq=popular+mechanics+oct+1952&hl=fr
pierre
Thread: Myford M7 Lathe
20/05/2013 10:42:31
Hi,
a good explanation here:
http://swarfer.co.za/lathe/backgear.php
pierre
Thread: Cutting wood screw threads on the lathe
28/02/2013 22:02:11
Hi,
The drawing is from a russian blog talking a bout USM1/Garant Carbine
This was also my first wood-screw drawing
pierre
Edited By pierre ehly 2 on 28/02/2013 22:03:39
28/02/2013 08:14:09
Thread: Carfbide Brazing Help Please
21/01/2013 12:07:55
Hi,
pierre
Thread: ML7 Lubrication
27/11/2012 08:13:40
Simon,
use a 1ft of clear plastic tubing (windshield cleanner nozzle)
Push it over the oil nipple and maitain it with the hand (the oil pressure push it out)
d'ont forget to oil the back gear mechanism (2 points)
pierre
Thread: Myford ML7 safe spindle speed
15/10/2012 16:03:43
Hi joylon,
The ML7 manual say
640 Rpm ( 1"7/8 pulley & 1450 Rpm motor)
870 Rpm (2"1/2 pulley & 1450 Rpm motor)
1070 Rpm (2"1/2 pulley & 1750 Rpm motor/ 60hz)
This higher value is the max safe Rpm, old babbit bearing manual say
100 meter/minute (330ft) linear speed is max , with heat contol (hand touch)
The probleme is less modern lubricant than heat evacuation.
Certainly too much modication for the benefit
brgds
pierre
Thread: Myford saddle
14/10/2012 18:09:26
Kevin,
http://www.usinages.com/manuels-documentations-machines-outils-disponibles/index-des-documentations-machines-outils-accessoires-t25730.html
Scroll down to "Myford" then dowload :
1 _" Myford pignonnerie" an explanation of change gears for Series 7 lathes + ML10
2_"Myford ML4 manual" a succint manual for the ML4 with a threading chart a the end
For the set-up remove all gears, then start from the lead-screw, inserting a strip of copy
paper between the gear teeth (remove prior use).
brgds
pierre
08/10/2012 11:04:27
hi kevin,
Have a look here: (ML7 apron IPC, similar to ML4)
http://www.myford.co.uk/acatalog/Myford_ML7_Apron_Assembly.html
The play is the play from the gears & rack assy, for precise move, use
top slide or lead screw & graduated hand wheel.
No idea for the gearbox installation (depend on your skill)
Hemingway kit is selling plans & kit for a ML7/S7/ML10 Gbx,
this plans contain certainly installation instructions
pierre
(owner of ML7 sn K37512)
Thread: Myford ML7 Spindle Problem
17/09/2012 10:55:30
hi James,
An good explanation by david of the ML7 back-gear here:
http://iwr.ru.ac.za/~iwdf/lathe/backgear.html
The pulley is certainly sized by lack of lube,
another common problem is a separation of the pulley and is gear (press-fitted)
Further dismantling will requiring a Press
pierre
Thread: cutting a 1mm pitch thread on Imperial lathe
16/09/2012 19:00:05
Hi martin,
look here (at bottom of page 1) Metric conversion set 1481
www.usinages.com/.../confirmation-donnee-notice-boite-avance-myf...
or at quick change gearbox manual BA section (select 0-BA)
pierre
Thread: Myford ML7 serial number query
10/09/2012 18:31:52
Hi,
Look here @ usinages.com (french forum about chips making)
http://www.usinages.com/tours/mon-premier-tour-myford-t8648.html
My answer( p-mick) is just below the 2 top pictures and contain 2 files
S7 built-datas.xls & S7- belt-change.pdf
pm
