Member postings for Mark Foster 1
Here is a list of all the postings Mark Foster 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Reaming Brass
28/06/2012 01:26:36
try some matches in the flutes
Thread: Subscription gifts
10/06/2012 00:46:35
Kwil more than the rest of the world ! what I and others do not like is all this free stuff appears only available to the mother country .I just ask people to open there eyes .Many a fine modle built here in Australia and the US we all buy the Mag .we should not be descriminated against .
09/06/2012 01:10:11
please please please make what ever you do world wide . England is a very small place there are other people who read your great mag .
Thread: Maybe CNC
08/06/2012 01:21:42
Its not the package but the support youneed. Its easy when you know how But getting there is the hard bit .Without support its way to steep .
08/06/2012 01:19:57
take a look at sheet cam .It works well with Mach . but it is not 3d
08/06/2012 01:17:16
Dont bother as the mag makes it all the way to Australia . without any gifts its a con from the poms !
Thread: What lathe to get?
13/04/2012 14:50:13
hi well in my workshop have the following lathes DSG 13x42 , Leinen Approx 9x18 , and a hercus southbend boxford type . a nice lot of lathes and the lathe I like using the most for small jobs is the Hercus ( quick change box ) all the bells etc VFD .The hercus does the most .easy to use . the only lathe I have sold was a Myford baught brand new saved for when I was at school . would not give a flat bead lathe shed space ( I learned a lot on this lathe .book in one hand machine in other ) I find a v bed lathe strets ahead of a myford .I red all the books as a young fellow and Myford was it . so that is what I bought. . wish it had been a Hercus . buy the bigest lathe you can afford .
Thread: Is RS 'Dispensing Solder Cream' the answer
11/04/2012 08:58:39
Try to get some LACO soft solder flux .great for that sort of job . Its what we use to do it on the job
Thread: Ian Bradley Heinrici Engine ME 3741
06/04/2012 14:47:11
how about a picture ? or a bit of the plan if it is the same as mine .
Thread: advice on polishing small BA nuts and bolts
01/04/2012 23:41:41
Have you a mate who reloads his own AMO . put it in a case tumbler with some wallnut shells .and there polish .you will see your face in them .
Thread: Turning / machining Aluminium - Tips
30/03/2012 00:04:31
try a bit of sunlight bar soap on the job works well
Thread: Dean Smith and Grace
16/03/2012 22:58:34
yes I have a 13x42 DSG easy nice machine Has it got graduations on the tailstock
16/03/2012 13:32:30
the radial holes just have screws in them to locate the bearing .(from memory ) think it would be better to have a steped bore
16/03/2012 13:30:17
I have built one I think ! the bearing is just pinched in the Al bit .you have to wash out the bearing no oil . Mine has been heated with a Metho burner . runs for hours on a small amount . a nice running engine . How about a picture . I will take one of the bit .If its the same engine
Thread: Silver Solder - Cadmium Free
04/03/2012 22:54:32
I have also found the cad free stuff just Junk !!! some improvment with LACO flux but not a patch on the old cad stuff .I use it most days its my trade .still have a couple of kg of the old stuff .I worries me about the boilers being built with this !
Thread: Drill Sharpening Wheel
28/02/2012 23:20:22
try CTC tools take a look on the net .great tools etc
Thread: bcd mill - stuck key
25/02/2012 23:35:55
just grab it with the side cutters . Works . but marks the key .file up or replace key
Thread: Eyesight problems
23/02/2012 23:45:46
Hi guys Ihave a lens that goes behind the carterage on my welding helmet .it is great . ask at your welding shop I use a 1.5 a breath of fresh air for us older members
Thread: What to look out for?
12/02/2012 07:40:57
why no try a boxford, southbend ,Hercus . I find a myford just hard work. After a v bed lathe . Flat bed lathes tend to shy away from work .
Thread: Small Power Hacksaw
09/02/2012 11:54:33
take a look at Myford boys power hacksaw .itsa nice thing
