availability of spline cutters
John Burridge | 14/04/2012 20:47:05 |
54 forum posts | Hi to all, Does anyone know where you can get hold of spline cutter simalar to involute type cutter as i need one to make a batch of replacement leadscrews on a M300 Harrison lathe cross slide leadscrew. I could grind up a single point tool and flycut them but a multitooth cutter would makes things easier. Do anyone know of a secondhand tool dealer who might have them in stock at a reasonable price. Alternatively i could make a multitooth cutter and form relieve it and heat treat afterwards. Regards John Burridge |
John Stevenson | 14/04/2012 21:57:04 |
![]() 5068 forum posts 3 photos | John, Don't think you are going to be lucky with an off the sheft cutter. Ash Gears in the States have the odd one but again with so many pitches and still 8 to the set, chances are low.
I did some shafts a while ago and made a multi tooth spline cutter. Some info here. http://bbs.homeshopmachinist.net/showthread.php?t=41591 John S. |
Steve Withnell | 15/04/2012 09:37:49 |
![]() 858 forum posts 215 photos | Slightly off track - how are internal splines cut? (ie a pinion that slides on a splined drive shaft? |
mgnbuk | 15/04/2012 09:42:36 |
1394 forum posts 103 photos | how are internal splines cut? Broached |
GoCreate | 15/04/2012 10:36:05 |
![]() 387 forum posts 119 photos | Splines can be of involute form and cut using an internal gear shaping method. In a jobbing shop internal splines may also be done by spark erosion (EDM). Or wire erosion Nigel Edited By tractionengine42 on 15/04/2012 10:37:45 |
John Stevenson | 15/04/2012 13:26:51 |
Posted by MICHAEL WILLIAMS on 15/04/2012 13:04:50:
With CNC now in common use rack form cutters and CNC motions could again generate almost perfect external gears and splines with very simple cutter shapes . Regards , Michael Williams .
When we demonstrate cutting gears by CNC at the shows we tend to use a largish tooth form so people can see it and it also allows us to use a bigger cutter so faster speeds and longer life.
The samples we cut are usually 2 MOD or approx 12 DP and we cut these with a perfect involute with an off the shelf 3mm three flute end mill, basically because we have them on stock ! We also cut helicals the same way. http://www.youtube.com/watch?v=OI8f6Lrwx00 John S. Edited By John Stevenson on 15/04/2012 13:28:49 |
colin hawes | 15/04/2012 18:33:01 |
570 forum posts 18 photos | I have seen beautifully cut splined gears cut by a CNC laser in steel about 3/8 inch thick at an exibition. Colin |
Stub Mandrel | 15/04/2012 21:12:34 |
![]() 4318 forum posts 291 photos 1 articles |
I cut the splines on this gear using a 'Stan Bray' toolpost slotting tool, and made the 'internal gear' by plunging in a 3-flute cutter - it only acts as a dog clutch on another gear. Outer gear using the Ivan Law single point cutter method. Neil |
Andrew Johnston | 15/04/2012 23:39:59 |
![]() 7061 forum posts 719 photos | Neil: Wow, those are pretty nifty gears, I'm impressed! Regards, Andrew |
Ian S C | 16/04/2012 13:05:30 |
![]() 7468 forum posts 230 photos | You ought to see (I'v no photos) the sprockets we use for the chain drive on the hay bale feed out machines we build, they are cut out with oxy acetylene, and cleand up with an angle grinder, the 35 mm hole for the shaft gets bored out on my lathe, and a hub welded on with a key way broached for a 3/8" key. The sprocket is cut from 10 mm hot rolled plate. It works, its cheap. Ian S C |
