Rich2502 | 19/01/2012 01:53:15 |
83 forum posts 3 photos | any one know where i can get two 36mm ID x 5mm section nitrile o rings cheaper than £7 / 8 online ?
Seeing as they cost a few p each i don't want to give my money to a o ring bandit.
Springbok | 19/01/2012 04:05:54 |
![]() 879 forum posts 34 photos | Rich
Welcome to the forum could you post a profile
Nitrile rings cost more than just a few pence will check in workshop today
and see what I have. If not will look through my records as bought some at a reasonable price some time ago.
Could you let us all know what you are building.
Bob
Brian Dickinson | 19/01/2012 04:35:49 |
![]() 62 forum posts 13 photos | EAP international @ Rochdale in Lancashire |
John Haine | 19/01/2012 08:50:58 |
5563 forum posts 322 photos | Don't know if they are suitable but Aldi's Thursday offers today includes a box of assorted O rings at £5.99 for 420 in 32 sizes. |
Roger Woollett | 19/01/2012 09:15:32 |
148 forum posts 6 photos | Simply Bearings have a pack of two for £5.46 including VAT and P&P Roger Woollett |
Niloch | 19/01/2012 10:00:51 |
371 forum posts | The Aldi offer sounds unbeatable especially if they are nitrile but if you are nearer a Screwfix branch check out product ref: 16982, 550 rubber rings for £20.10 |
Ian S C | 19/01/2012 10:34:15 |
![]() 7468 forum posts 230 photos | Before the earthquakes here (10,000 and counting), I used to make steel moulds for making rubber automotive parts (war time Willys Jeeps), from that I would say its fairly easy to make the moulds, its finding the firm with the raw rubber, and the vulcanising gear. The firm I used had fairly primative gear. I don't know the status of the company at the moment, but theres $NZ5/6000 worth of moulds of mine there at the moment, I'll proberbly never see them again. Ian S C Edited By Ian S C on 19/01/2012 10:35:51 |
Gray62 | 19/01/2012 12:12:49 |
1058 forum posts 16 photos | Bearing Boys do a good selection of O rings amongst other things ![]() |
Jon | 19/01/2012 16:49:36 |
1001 forum posts 49 photos | Specialist hydraulics or O ring supplier that im afraid. Where are you? I have two proper BS 221 which roughly equates to 36ID X 43.5 O/D x 3.53 cross section. The boxed sets will only be less than 2.92mm cross section for that 36mm ish I/D also marked 221 so some things wrong. Is it something you are building in which case can change the design or to replace an existing O ring? Have a look in yellow pages for a supplier local, some will do cash and not have to have minimum order usually £15 and £5 worth of same item. |
