Steve Withnell | 21/08/2011 20:10:00 |
![]() 858 forum posts 215 photos | A couple of years ago I bought a cheap laminator from WH Smiths, at the time they were just under £20.
I thought I'd share how I'm using it in the the workshop:
I started off setting up conversion tables in Excel - bottom left is imperial fraction to metric, using only the range I need for the work at hand, then printing it as big as it will go onto an A4 sheet, laminated it and now I've got a really handy chart that sits on the bench as work progresses. (I've also Imperial fraction to Imperial decimal etc). The point is it's only the range I need in the increments I need in a very easy to read format because I've used the biggest possible font, consistent with getting on a single age.
A while back I designed some bevel gears for an engine I built, so repeated the trick - Printed off the data as big as possible onto A4, laminated it (top left)
When ME kindly provided the PDF's for the Whittle engine and I decided to have a crack at it , I cut and pasted the crank drawings from the PDF into Word, then stretched the image until it just fit the page, banged it into the laminator and now I've a copy that's very readable, and has survived coolant spills, tools left on in etc. See bottom left.
At top right is a Stuart Models plan. My last one was in a very poor state by the time the engine was complete, so this time I took the the scissors to it and cut it into four seperate pieces and laminated them double sided using a plain A4 sheet of paper as a background.
I find it beneficial not having to have an A1 / A2 drawing on the bench when in the case of the Whittle engine, there was many hours expended on just one component. So the handy size is good.
The other obvious benefit is that the laminated version will stand a lot of mistreatment, but if you want to draw on them, well you can use either permanent or non-permanent markers over the top if you want.
Hope this is of interest!
Edited By Katy Purvis on 01/06/2015 12:07:08 |
_Paul_ | 21/08/2011 20:30:05 |
![]() 543 forum posts 31 photos | Bought an Aldi one some time ago, so in my workshop I have Tap/Drill charts, Size comparison charts etc. blu tacked in strategic positions nothing more that Excel spreadsheets printed (big type ![]() A good tip if you write on one with a permanent marker and subsequently want to remove your scribblings go over it with a dry wipe pen then quickly wipe the wet marker ink off, same technique seems to work on most plastics. Regards Paul |
Bogstandard | 21/08/2011 20:59:31 |
263 forum posts | I have complete tapping charts for each type of thread plus conversion charts when working between metric/imp and the other way around, that saves having to go thru the small type in my Zeus book. So only what is required is on my drawings slide. BTW, a bit of meths usually removes permanent marker, plus if it starts to run low, a spot in the marker pen can get you going for a bit longer. The laminator is also good for making the odd sign, like the one on my trailer for my disability buggy Edited By Bogstandard on 21/08/2011 21:01:16 |
Stovepipe | 21/08/2011 22:52:15 |
196 forum posts | Also, those display folders are useful for keeping the manuals in that come with all the tools we buy. I can now lay my hands on the manuals for any tool in the workshop.
(Yes, I know I'll be drummed out of the forum for "reading the instructions first", but that's a risk I'll have to live with ! (grin!))
Dennis
John Coates | 22/08/2011 12:47:45 |
![]() 558 forum posts 28 photos | I bought a hot and cold A4 one last week from Poundstretcher who now have them down to £10
It was reduced from £25 to £20 on the item ticket but was advertised at half price in a flyer in the local weekly free paper. It was still marked at £20 on the shelf but it scanned as £10 at the till
Don't know what it performs like as I'm waiting to get some laminating pouches
John |
John Coates | 22/08/2011 12:55:59 |
![]() 558 forum posts 28 photos | Forgot to add
The reason for getting one is exactly the same as Steve
I produced tables in Excel for the screw cutting change gears for my lathe, the RPM at different Hz for the 3 phase motors attached to inverters on the lathe and the mill, and the RPM for cutters of various sizes on the mill
Once laminated they are available immediately and don't soak up oil, sweat or cutting fluid like paper only ones seem to do
![]() John |
AndyB | 22/08/2011 20:06:51 |
![]() 167 forum posts 7 photos | Hi all,
I have the changewheel chart, thread sizes with tapping drill sizes, and imperial fraction and decimal sizes with metric equivalents to 4 decimal places in front of the main workhorse.
Sorry about the quality of the photo, it wasn't actually of the charts.
Andy
Nicholas Farr | 22/08/2011 20:54:01 |
![]() 3988 forum posts 1799 photos | Hi, laminators are also useful for making home made information plates and the like, for your machines etc., like the one in the photo below.
Edited By Nicholas Farr on 22/08/2011 21:04:46 |
Stub Mandrel | 24/08/2011 21:51:47 |
![]() 4318 forum posts 291 photos 1 articles | Could be a way of making panels for electrical equipment. I've uses a printed sheet behind perspex, but thi is limited for projects (like the latest) which don't have a flat panel. Neil |
_Paul_ | 25/08/2011 15:26:26 |
![]() 543 forum posts 31 photos | You can with a little ingenuity make your own self adhesive plastic labels and/or covers for books: Print your desired graphics on gummed paper (or plain if book binding) put two sheets inside the laminating pouch face out, once laminated cut off the edges and voila plastic coated stickers/book covers. Regards Paul |
mick H | 25/08/2011 18:23:58 |
795 forum posts 34 photos | Decent laminating pouches in The Works at £1.99 for 20. |
NJH | 25/08/2011 18:52:33 |
![]() 2314 forum posts 139 photos | For full size drawings I use Artcare Sleeves - these are available in sizes from A4 up to A1. I put the sheets back to back and hang them from bulldog clips screwed to the workshop wall. On long term projects ( or very long term like my "Stent" for example) I got a copy of the drawings made then cut them up into A4 sizes to show each individual component, fitted them into cheapo A4 clear punched pockets, and filed them in a ringbinder. It's then easy to take out the drawing for the bit being worked on and hang it on the lathe, mill, marking plate etc. for easy reference during machining. Data sheets for tapping data and any permanent, often consulted, reference etc are fixed to the wall and covered by a large sheet of clear acrylic. Regards Norman |
Anthony Knights | 01/09/2011 22:06:32 |
681 forum posts 260 photos | |
Springbok | 14/10/2011 09:42:02 |
![]() 879 forum posts 34 photos | I had been thinking of one of these for some time could also use it after all workshop stuff is done for my various clubs.
Bob |
