John Shepherd | 04/08/2010 20:34:20 | |
222 forum posts 7 photos | I read with interest Harold Hall's article about RCDs in the latest MEW.
Unfortunately he missed out mention of the dreaded Part P of the Building Regulations. The fitting of new consumer units alluded to and new wiring need prior notification to the local Building Authority or require the work to be done by an electrician or company registered to carry out the work.
In fairness I notice Harold did not suggest that any one should do the work themselves but I would urge anyone inspired to carry out any rewiring to check what Part P allows.
I hope this does not deter anyone from fitting RCDs they really are worth having, particularly in the workshop.
B.T.W. If RCD is the prefered name why does the front cover refer to RCB?
chris stephens | 05/08/2010 01:27:21 | |
1049 forum posts 1 photos | I seem to recall hearing that the Regs say you can still do your own wiring with the new colours, but have to get it signed off, when finished, for a fee of course.
Could someone clarify?
chriStephens
Gray62 | 05/08/2010 09:50:16 | |
1058 forum posts 16 photos | Part P can be read here http://www.theiet.org/publishing/wiring-regulations/part-p/ | |
KWIL | 06/08/2010 08:51:05 | |
3681 forum posts 70 photos | Looking at Part P notes (above) seems it fits with Q5, not being in a kitchen or special area, installation of sockets etc. | |
Paul Boscott | 06/08/2010 14:56:35 | |
![]() 99 forum posts 21 photos | Chris is correct that you can do the actual work yourself BUT you MUST have it signed off by a qualified person. The catch is if it is not inspected, tested and singed off and there was a problem with it the house insurance would be void. | |
John Shepherd | 06/08/2010 17:14:45 | |
222 forum posts 7 photos | I do not wish to enter into protracted discussions about Part P as there is a lot of miss information out there not least from some of the local councils.Hopefully the following will suffice to clafify the main points of Part P and DIY.
If it is not notifiable then you can do it if you think you are competent and remember all alterations should be subject to testing in accordance with the wiring regulations. DIY electrical work has not been outlawed but it has been brought into the Building Regulations and cannot done freely as it was before, and in many cases cannot be carried out without involving your local council. Note that apart from a Building Inspector (or someone specifically appointed by them), nobody can certify someone else's work as being compliant with the Building Regulations. Unless it is arranged by or in cooperation with the Local Authority Building Control (LABC), a 3rd party electrical inspection is of no value in terms of complying with Part P. If you are carrying out notifiable work yourself you must submit a building notice to LABC. The work will then be inspected at first fix stage and then on completion by the LABC or a competent person appointed . They will also carry out testing to BS7671 All for a fee of course so in some cases it will be cheaper to have the work done by a person who is a member of a ‘Competent Person’ scheme who can then self certify.
Edited By John Shepherd 1 on 06/08/2010 17:27:35
Edited By Diane Carney on 06/12/2010 11:20:20 Edited By Diane Carney on 06/12/2010 23:30:56 | |
KWIL | 07/08/2010 10:53:22 | |
3681 forum posts 70 photos | Another interesting result of all of this, a Design Engineer may be fully qualified and experienced in designing electrical apparatus but cannot install it because he is not qualified, what rubbish is this?? | |
Paul Boscott | 07/08/2010 11:31:03 | |
![]() 99 forum posts 21 photos | Kwil
Unfortunately those of us that think we can complementally do the work get caught in the cross fire resulting from the necessity of protecting the public at large from cowboys.
But even I had to borrow an earth loop tester as that measurement cannot be guessed and with out a low enough earth return path an RCD will not trip at the designed speed so as to afford the specified protection.
Paul
Josef1 | 06/12/2010 00:46:57 | |
1 forum posts | I dont think a building inspector can even sign off electrical work as he is not usually qualified,and he will ask for a certificate .A garage/workshop is classed as a special location if it is remote to the main building any electrical work except replacing like for like due to damage will require a certificate from a goverment registered scheme.You can sign off other peoples work if your registered if they comply with the regulations and they are classed as compident (sic?) person,but in doing so you are putting your name to that job ,so if your not 100% your not going to do it ! .I work as a NICEIC electrician and this is just my opinion on this matter. The regs are a minefield and open to interpretation hope this helps. | |
Terryd | 06/12/2010 08:00:33 | |
![]() 1946 forum posts 179 photos | John, Can you edit your post, it appears to have caused the dreaded table stretch. If you post from Word or another word processor use the 'Post from Word' facility at the icon at top of message window when messaging. I think it will be the picture you inserted, it needs editing out. I'm using carriage return to keep my message readable. Terry | |
MichaelR | 06/12/2010 08:27:01 | |
![]() 528 forum posts 79 photos | Could a competant person sort out the post that has caused a problem with this page.
Stick. | |
Terryd | 06/12/2010 10:47:06 | |
![]() 1946 forum posts 179 photos | Hi Stick, I know what the problem is but the moderators appear to be involved with the Sandown Exhibition this week. John needs to get rid of the graphic he posted from Word Terry Edited By Terryd on 06/12/2010 10:47:36 Edited By Terryd on 06/12/2010 10:50:08 | |
Terryd | 06/12/2010 10:49:49 | |
![]() 1946 forum posts 179 photos | John, Sorry To repeat but I have tried to keep my message readable This time Can you edit your post, it appears to
at top of message window when messaging. I think it will be the graphic from Word you inserted, it needs editing out. I'm using carriage return to keep my message readable. P.S. the 'Home keys and other Nav buttons are at the bottom of the page Edited By Terryd on 06/12/2010 10:52:40 | |
Diane Carney | 06/12/2010 11:25:48 | |
419 forum posts 11 photos | Hi chaps I removed the offending table from John Shepherd's post - apologies to him. Perhaps there is another way he could convey the information? DC Edited By Diane Carney on 06/12/2010 11:26:36 | |
MichaelR | 06/12/2010 13:26:17 | |
![]() 528 forum posts 79 photos | Hi Diane.
A job well done, Thanks. Edited By Stick on 06/12/2010 13:27:11 | |
John Shepherd | 06/12/2010 17:24:14 | |
222 forum posts 7 photos | Terry
I assume you were having difficulty with your post but all three reminders for me to remove a table in my post within a short space of time today are perfectly readable to me.
When I first submitted the post in August I don't remember it causing a problem then and three was no picture included. (I am aware of the problems of pasting from Word having been a culprit before).
Since then some stupid avatars that I am not responsible for have appeared in my post also. | |
Terryd | 06/12/2010 22:57:31 | |
![]() 1946 forum posts 179 photos | Hi John, No offence intended, My first post was stretched at the time and I made a Third posting to ensure it was readable. The second posting was addressed to Stick not your good self. Did you actually type into the posting dialogue box when these latest smilies appeared? If so we have problems. Terry | |
Diane Carney | 06/12/2010 23:33:09 | |
419 forum posts 11 photos | Supid avatars deleted John. Haven't a clue where they came from. They have now appeared elsewhere! I'll try and get onto the pesky things and chase 'em! Diane | |
NJH | 06/12/2010 23:34:45 | |
![]() 2314 forum posts 139 photos | Terry I'm getting a bit worried about you - you seem to be getting younger and younger.
You don't have a picture of yourself in the attic do you?
N
Terryd | 07/12/2010 02:49:18 | |
![]() 1946 forum posts 179 photos | Hi NJH, No it's just that I seem to have caught the Benjamin Button (as in 'The Curious Case Of') syndrome. Dear old Dorian just didn't get older! Last month I had the acne that I never had as a teenager originally. Scary. ![]() Regards Terry Edited By Terryd on 07/12/2010 02:50:58 |
