Bill Dawes | 23/03/2010 19:11:09 |
605 forum posts | I am looking to buy a gas torch for brazing/silver soldering but a bit confused with all the options of butane, propane, butane/propane mix & MAPP.
I was thinking along the lines of a torch with disposable canister attached ( I anticipate it will be occasional use only) however as we do caravanning do have larger gas bottles (both propane and butane at the moment) but any guidance welcome.
I have a camping gaz butane canister torch that I have used for many years on plumbing jobs but assume it will not be hot enough for brazing.
Bill Dawes. |
mgj | 23/03/2010 19:27:34 |
1017 forum posts 14 photos | Its not about occasional use or not, but how much heat you need! You can't beat the Sievert starter kit, which runs off propane. 4 bar HP regulator, plus hose and a torch. The kit has their basic nozzle, but you can buy nozzles to suit all purposes. The 4 bar regulator will feed any nozzle too. Cheapest I found it was from Machine Mart (by some margin), but it is available from Reeves and CUP alloys and I think Chronos. (well if I'm honest someone on this forum found it and posted a link - grateful) I had a Calor system, rated off a 2 bar regualtor. You spent half the day heating even the smallest items. The Sievert just wellies it, which is better for the flux, and the whole thing is done in one, thoroughly and with certainty. You can step braze with higher melting point alloys with ease - in fact I regularly use one of the HT alloys just because it has better fillet forming properties than Easy Flo/842. If you are talking of silver soldering jewellery sized stuff then the smaller burners could well be all you need, but I would doubt that one of the disposable canister range has enough urge to heat up model engineering stuff (at reasonable operating costs) |
JasonB | 23/03/2010 19:28:34 |
![]() 25215 forum posts 3105 photos 1 articles | Although the MAPP gas is said to have a hotter flame most of these torches will not put enough heat into larger items.
Given that you already have Propane cylinders I would go with a basic torch to use with them, something like this would be OK for fabrications and even a small boiler for a stationary engine
Jason |
Nigel McBurney 1 | 23/03/2010 19:37:46 |
![]() 1101 forum posts 3 photos | hi Buy a Sievert kit, torch , hoses,regulator and an assortment of burners sizes to suit your needs ,and run off your propane cylinder,reasonably economical and gives a good hot flame,with plenty of gas in reserve for those bigger jobs. Small canisters have no capacity for the medium and large jobs. Brazing needs more heat than silver soldering and there is no choice other than propane.When silver soldering to get the best results,the work and the flux needs to reach the soldering temperature quickly so use a decent sized burner. |
Nigel McBurney 1 | 23/03/2010 19:37:47 |
John Haine | 23/03/2010 20:45:03 |
5563 forum posts 322 photos | For something simple, a Bernzomatic torch head with a yellow MAPP cylinder is excellent. Far superior to all those cheap & not-so-cheerful butane torches that the DIY shops sell. |
Les Jones 1 | 24/03/2010 08:42:27 |
2292 forum posts 159 photos | Hi Bill, If you choose the "Sievert" torch option I bought mine from Millhill Supplies Millhill Supplies But have since found that that "Hamilton Gas Products" are cheaper Hamilton Gas Products I went for the 3486 handle and the 3525 cyclone burner. (10.2 KW) I found there is a large variation in prices from different suppliers. Les. |
Circlip | 24/03/2010 10:50:55 |
1723 forum posts | Wonder if the O/P really wants to "Braze"?? Seems the weapons of choice in the past, ie. the five and two pint blowlamps, are long gone.
Perhaps MUCH too dangerous for the elfins to allow muppets to operate.
Regards Ian. |
Ian S C | 24/03/2010 11:31:28 |
![]() 7468 forum posts 230 photos | What gas does the yellow MAPP cylinder have? The gas I use here is a mix of butane and propane, they'v got the mix right now and it even burns in the winter(few years back if the workshop was cold-no pressure). I'v got a 1/2 pt petrol blowlamp, thats the reason I got the gas! Ian S C |
JasonB | 24/03/2010 12:21:53 |
![]() 25215 forum posts 3105 photos 1 articles | Circlip, I was thinking that. Maybe he wants to "silver braze" as the Americans call it. I doubt propane would get upto the temps required for proper brazing unless it was very small parts as its usually done with oxy/acet or I use the carbon arc rods on a welder.
Jason |
Pat Bravery | 24/03/2010 18:25:55 |
![]() 96 forum posts 24 photos | I also was interested in having some brazing facility and upon looking at the link to Machine mart decided to buy a torch at £27.01, I reaffirm the old addage that you get what you pay for. I tried to braze some 1mm steel plate and I gave up after 5 mins as there was insufficient heat. I had the regulator on the highest setting. I will use it for soldering and dig a bit deeper for a proper set up. Pat |
Steve Garnett | 24/03/2010 18:42:10 |
837 forum posts 27 photos | Posted by Ian S C on 24/03/2010 11:31:28: What gas does the yellow MAPP cylinder have? According to Wikipedia, the composition of the gas is: propyne 30%, propadiene 14%, propylene 43%, propane 7%, C4 (isobutane, butane) 6%. So basically it's LPG. The Bernzomatic gas (the stuff in the yellow cylinders) specifically has a combustion temperature of 1,982°C (3,600°F) in air and 2,867°C (5,193°F) in oxygen. You can't use it for welding steel though, because the welds end up being brittle due to the hydrogen in the flame, which infuses into them. So yes, it can weld (nearly as hot as acetylene with oxygen) but really it was only ever used for cutting in this context, and generally underwater at that, where it had advantages until they all started using exothermic cutters. |
Ian S C | 25/03/2010 11:50:40 |
![]() 7468 forum posts 230 photos | Thanks Steve, I'v used LPG for cutting(not under water), found it worked quite well, although it uses a lot of Oxygen 4.5:1 for a neutral flame compared to 1:1 for Oxy-acetylene.It gives a softer edge to the cut than Oxy-acetylene,got for brazing realy big stuff. Ordenary LPG in NZ burns at 4890F, but LPG has 2500BTU per cu ft compared to Oxy-acetylene with 1475 BTU per cu ft. Ian S C |
JohnF | 27/03/2010 17:47:14 |
![]() 1243 forum posts 202 photos | Hi Bill everyone seems to advocate Seivert torches; I have been using Bullfinch torches professionally on a daily basis for over 30 years and find them superior to others I have tried. These are the auto ignition torch--a little more expensive but very convenient and you can get a range of nozzles for varying work size. Look at www.adamsgas.co.uk but there are many other suppliers. All the best John |
Richard Parsons | 05/07/2010 15:03:21 |
![]() 645 forum posts 33 photos |
I have used Seivert torches for along time. But once in a silversmith class I used a Air propane unit. It was a Rolls Royce of torches. I have hunted for one ever since. Any one any ideas as to where I could get one? I think it was called a Flame-master, but as good things go they seem to have gone. |
Niloch | 05/07/2010 21:18:03 |
371 forum posts | It wasn't Flame-fast by any chance? Flamefast equipment was very popular in schools' CDT Depts. especially for natural gas. Edited By Niloch on 05/07/2010 21:21:04 |
Richard Parsons | 08/07/2010 08:32:00 |
No it was a Flame Master. I know of the Flamefast kit and this was different it was in solid cast aluminium and had an economiser trigger which you pulled in to use the torch. There was another one at the same college which had three gas supplies gas, compressed air and oxygen. It was made in Germany and was probably ‘a liberated’ item. I have a micro flamefast burner, which is a devil to use as I have to clean out the residues left by the gas each time. I have not tried it over here yet. |
A D 1 | 15/04/2020 16:21:19 |
5 forum posts | Hello everyone, I know I am kind of resurrecting an old thread here, sorry in advance if that's the wrong approach. I recently got the Bullfinch Brazing torch, and I would appreciate your input with a problem I am having: I am trying to braze some 8mm threaded bar to a section of 30x30x3mm mild steel The steel is drilled 8mm and the threaded bar is sitting in hole. The steel is set on, and partially surrounded with fire bricks, but I am struggling badly to reach a temperature where the brass brazing rod runs into the joint. Is the steel section too big for this torch? Or would it be a flux issue? (I ordered brass brazing flux, but the company sent me silver solder flux-I am temporarily using this) The steel gets red hot easily enough, but the rod doesn't melt (or at least certainly doesn't flow) by touching the steel - only when the flame is directly applied to it. Would appreciate your thought, Thanks, Á D |
JasonB | 15/04/2020 16:25:15 |
![]() 25215 forum posts 3105 photos 1 articles | If it is the 404 that you have then all the videos I have seen of it are with quite thin material so probably not getting hot enough |
A D 1 | 15/04/2020 16:28:51 |
5 forum posts | Thanks for the quick reply. Do you have any experience brass brazing with propane only? I am wondering if the Sievert would give better results, or would an oxy- or air-gas torch be needed for that size of steel? Thanks |
