Dougie Swan | 13/01/2010 16:25:20 |
269 forum posts 73 photos | Hi, I have an Axminster RF30 mill and was wondering if there were any articles that anyone knows about from MEW that describe the making and fitting of a power feed, either for this mill or some that could be adapted cheers Dougie |
Donald Mitchell | 13/01/2010 17:09:44 |
![]() 90 forum posts 3 photos | Hi Dougie, ( you sound as if you could be Scottish ?) You will find an article on fitting a home made power feed to a mill like yours ( I think ) on the following link. http://www.wcc.net/~jkmccoy/shop/pwrfeed.htm Good luck, enjoy. Donald Mitchell Castle Douglas Bonnie Scotland |
Michael Freeman | 13/01/2010 17:46:28 |
11 forum posts 20 photos | Hello Dougie,
A partial answer really. I am about to start on a power feed for my RF25 (also from Axminster tools) and am listing the work done on my website http://www.mikes-models.com/powerfeed.html when I have done some that is. I only mention it here since my method is using a 12 volt windscreen wiper motor but after struggling for a while on how to power the motor with variable speed I found the Proxxon power feed (see my website).
If you want to email me re my approach you can do so via the website above.
Mike |
Julie | 13/01/2010 22:55:42 |
24 forum posts 1 photos | Hi Dougie,
Trust the field gun is coming along nicely.
We have the Axminster power feed unit fitted to our Warco mill, we got it off ebay quite cheaply a few years back.
You are welcome to look at it if it helps.
(Tony & Julie)
The one thing about the "real thing" is it does have a speed control, quick disconnect, and a rapid transverse - all of these would need to be done as well - not just the mechanical aspects if you make your own.
Julie |
Ian S C | 14/01/2010 02:52:18 |
![]() 7468 forum posts 230 photos | Hi Dougie,I built one in a few hours,its crude,its simple and it works for me.Motor,an elderly Lucus windscreen wiper motor with the shaft from the wormwheel extended about 1" outside the case to take a 10 tooth sprocket.Next a 20 tooth sprocket fitted to(in my case)to the lefthand control wheel.The motor fitted to a bracket that is bolted to the T slot that runs along the front of my machine.A switch fitted,center off,left-right on,this wired to give foreword and reverse.The two sprockets joined with a loose fitting bit of bike chain(so you can just slip it off)My power supply is from an old Zerox copier,the transformer is about a 7" cube,a battery charger would do nicely.Thats about all,I only had to make one of the sprockets-the 10T.Speed control came a wee bit later,its a home brewed rotary switch with three contacts and resistors,bits of Nichrome wire.No electronics,you can make a guard for the chain.Ian S C |
Dougie Swan | 15/01/2010 18:29:11 |
269 forum posts 73 photos | Thanks for the replies, I'm going to follow Mike's progress on his link above and check ebay like Julie suggested Once again Thanks Dougie |
Michael Freeman | 25/03/2011 17:33:06 |
11 forum posts 20 photos | Just to round the circle, my power feed has been completed and works very well. For more information go to my websites mikes-models.com and my blog Mike Edited By Michael Freeman on 25/03/2011 17:34:16 Edited By Michael Freeman on 25/03/2011 17:35:58 |
Michael Cox 1 | 25/03/2011 20:23:34 |
555 forum posts 27 photos | Hi Dougie,
I have fitted a powerfeed to my X1 mill. I think the principles could be readily transferred to other mills. Futher details are here:
Mike |
Murray Tricker | 26/03/2011 04:49:29 |
10 forum posts | Hi All. Re the use of a windscreen wiper motor for table feed. I used a circuit (widely used I believe) that uses a 555 timer device and a mosfet transistor to get variable speed. Works well with a reduction drive to the handwheel shaft. With a bit of thought the reduction drive can also acts as a clutch. A bit elaborate for some perhaps? Anyway my recommendation re using these motors is to sus out the maximum voltage and use that to get a fast return feed. I beleive that 15 volts is the nearer this than 12 volts. I also believe that a windscreen wiper motor can be stalled without burning out!!!! I have done this several times with no problem. |
Mark P. | 26/03/2011 08:42:56 |
![]() 634 forum posts 9 photos | I used an old wiper motor as well with a 2:1 reduction drive on my Warco WM16 mill.For the speed control I found a vairiable speed controller from Maplin electronics,powered from a battery charger.I found that a 2200 uf capacitor across the output of the charger gave me a smoother current for the controller,this has worked well for the last 3 years.
Regards Pailo. |
Alex gibson | 26/03/2011 11:12:36 |
35 forum posts | hi all,
I used a 12v dewalt cordless drill with a pwm controller on my x3 mill.
kind regards
alex |
