Here is a list of all the postings Dougie Swan has made in our forums. Click on a thread name to jump to the thread.
Thread: Alyn RLE Last and First |
23/07/2023 18:06:42 |
Go Jason I for one will be following along Dougie |
Thread: I C valve grinding paste |
21/02/2023 17:59:27 |
Thanks Where is the sampler pack available from Dougie |
21/02/2023 11:21:15 |
Thanks for all the replies I have used the fine end of car valve grinding paste and as Jason says it's a bit rough I will try to get my hands on some finer carbide Thanks Dougie
20/02/2023 20:30:48 |
Hi Can anyone suggest the best size of grit for lapping in ic engine valves I'm thinking of getting some of the finer diamond grades Any advice Thanks Dougie
Thread: Glow plug/1/4 x 32 spark plugs washers |
14/02/2023 18:59:57 |
Thanks for the replies Once again Jason you have come up trumps Thankyou Dougie |
14/02/2023 18:27:30 |
Hi I have searched everywhere but can't find a source for copper washers to fit a standard glow plug or 1/4 x 32 spark plugs Can anyone help Thanks Dougie |
Thread: Paint Stripping a Locomotive |
01/02/2023 17:05:16 |
Try to get some professional paramose paint stripper It contains methylene chloride so needs to be used carefully but will remove almost anything and is water based |
Thread: Single cam working both inlet and exhaust |
24/01/2023 16:54:08 |
Thanks guys Tim, you have explained it so that it makes sense, the cardboard and drawing pin idea is great I don't have the luxury or the knowledge how to work a cad package Jason but I liked your cardboard and drawing pin take on it I will just have to sit at my drawing board and pull out what little hair I have left Dougie |
24/01/2023 16:01:48 |
What do you mean Jason Dougie |
24/01/2023 12:38:43 |
Thanks for all the replies Some interesting reading there The motorcycle style shown in the post is what I was thinking of I'm thinking of building a jap or blackburne v twin and I'm just trying to understand the single cam setup Any ideas on how to work out the angles Dougie |
24/01/2023 07:32:21 |
Hi I have been trying to find information on the cam setup where 1cam operates both valves vi a cam follower I have seen it on old blackburne and jap engines but can't find any info on this Can anyone tell me what this system is called so I can try to model it Thanks Dougie |
Thread: Petrol resistant adhesive /sealant |
14/01/2023 17:15:21 |
Thanks again for the replies It is a dummy in the sense that it won't be used to clean the fuel, but it will serve to pass the fuel from the tank to the carb so it does have to be sealed Regards Dougie Edited By Dougie Swan on 14/01/2023 17:15:39 |
14/01/2023 15:18:00 |
Hi Jeff and thanks for the reply I intend to make the pivoting hoop to press the glass bowl onto the brass I have some pretty thick ptfe strip that might work as a gasket Dougie |
14/01/2023 14:42:29 |
Can anyone suggest an adhesive or sealant that is petrol proof that I can use to seal this dummy fuel filter to my latest engine Thanks Dougie |
Thread: Two stroke v 4 stroke piston |
24/11/2022 15:58:13 |
Ok So the rings are pinned, what does that do? This is an engine from a home made set of castings so the rods and cylinders were made to suit I've built lots of engines and never had this dilemma before Bottom line is will they work or not Dougie Edited By Dougie Swan on 24/11/2022 15:58:33 |
24/11/2022 14:46:48 |
But will it make a great deal of difference |
24/11/2022 14:37:59 |
I'm documenting an engine build on tiktok It's a 4 cylinder holt I found some pistons on ebay, the correct size with 2 rings and pin I posted them on tiktok and I have had lots of questions asking why I'm using 2 stroke piston Like you I thought a piston is a piston Dougie Edited By Dougie Swan on 24/11/2022 14:39:02 |
24/11/2022 14:04:23 |
Hi Can anyone tell me the difference of 2 stroke and 4 stroke pistons Can 2 stroke piston be used in a 4 stroke engine Thanks Dougie |
Thread: Centre finder |
23/11/2022 17:35:44 |
Hi Can anyone recommend a good centre finder for round bar in my mill Thanks Dougie |
Thread: Subscription |
12/10/2022 18:15:52 |
Thanks Jason Dougie |
