Lever Feed Tailstock
as shown in "Practical Engineer Part 5"
Articles
Norm. Williams19/07/2009 10:42:44
2 forum posts
As an ex Capstan Operator I am used to using the above type of item.
Does anyone know of a similar item to fit my Sieg C3 Lathe ?
I am not up to making Rack and Pinions, but if I could buy something suitable, I may then be able to make something work.
Any suggestions will be most helpful.
Norm. Williams.
David Clark 119/07/2009 11:43:38
3357 forum posts
112 photos
10 articles
Hi There
I will talk to Dave Fenner.
He will probably produce a design although it will probably be a lever feed version.
regards David
David Clark 119/07/2009 12:03:47
3357 forum posts
112 photos
10 articles
Hi There
We published a lever feed tailstock for the C3 in Model Engineers' Workshop issue 143.
regards David
Norm. Williams19/07/2009 12:47:25
2 forum posts
Thanks for reply Dave Clark 1, it would be interesting to see what Dave Fenner thinks, although the one in Issue 143 seems Ok. dependent on the amount of travel available.
Thanks again,  Norm.
John Burridge12/05/2012 13:33:02
54 forum posts
I wonder has anyone wrote up an tatical on a making a capstan feed tailstock for the Raglan range of lathes and what you would need to do to convert a standard tailstock
Cornish Jack12/05/2012 18:46:36
1228 forum posts
172 photos
Sort of coincidence! - I have just finished writing up and photographing a lever feed tailstock for an ML7 which I was thinking of submitting to MEW. It was made from scrap box bits and has served me for a number of years.
a) Would it be of interest?
b) How does one submit such items?
c) I can't draw, so would Crap-o-Cad scribblings suffice?
Rgds
Bill
David Clark 112/05/2012 19:12:47
3357 forum posts
112 photos
10 articles
Hi CJ
Yes, all articles are of interest.
Email me direct for more inforpmation.
regards David
[email protected]
Stub Mandrel12/05/2012 20:59:35
4318 forum posts
291 photos
I've often thought there is enough meat in a mini-lathe tailstock for a rack and pinion feed.
Peter E12/05/2012 22:32:55
48 forum posts
22 photos
I can only agree with what has been said above.
Also I have been thinking of a solution for a rack and pinion feed tailstock but as a bolt-on accessory and reusing the original parts. It will be most useful for drilling deeper holes amongst other things.
/Peter
Dennis R12/05/2012 22:50:41
76 forum posts
16 photos
There are drawings and a write up of an ML7 lever feed tailstock in MEW 16 page 30.
Several years ago I made one similar but with a depth stop on.
I would not go back to a normal tailstock through choice.
Dennis
blowlamp12/05/2012 23:36:45
1885 forum posts
111 photos
I can't find my camera at the mo' to show the real thing, but here's a quick video of the model I drew before construction of the lever-feed barrel for the tailstock
http://screencast.com/t/faMlJ1qtxz
My lathe is a Clarke CL300 and if you notice, I also made a longer barrel, which in conjunction with this modification gives a whopping 72mm of travel for drilling and reaming etc. I'd never go back.
Martin.
Edited By blowlamp on 12/05/2012 23:37:37
Springbok13/05/2012 04:47:22
879 forum posts
34 photos
Hi Martin
Made a similar gadget to that but modified it to make cotter slots in wheels.
Bob
blowlamp13/05/2012 12:20:35
1885 forum posts
111 photos
Just for the sake of clarity, the yellow coloured part of the model in my screencast represents the top section of the tailstock. It served no purpose for me to model it all.
Martin.
