Here is a list of all the postings Dennis R has made in our forums. Click on a thread name to jump to the thread.
Thread: MyFord Boy Traction Engine |
09/04/2023 22:01:34 |
See this thread by Ron Laden https://www.model-engineer.co.uk/forums/postings.asp?th=138699&p=1
Thread: Does anyone know what this is |
21/03/2023 20:33:05 |
Looks like a simple indexing device pipped at the post Edited By Dennis R on 21/03/2023 20:35:45 |
Thread: Will they honour these prices, I wonder |
21/11/2022 22:12:30 |
Selected all three sets of M2,M3 and M4, clicked on basket and total charge came to £21.30 which included £9.95 handling charge and £3.55 Vat. Didn't buy. |
Thread: Caprotti Valve Gear |
03/07/2022 23:10:31 |
Chris Download this Pdf https://www.theduke.uk.com/wp-content/uploads/woocommerce_uploads/2014/09/The-British-Caprotti-Valve-Gear-v02.pdf |
Thread: Powering a Suds pump? |
06/06/2022 20:45:30 |
What horse power is the motor, there is a list of values in the Workshop Practice Series No. 24, Electric Motors in the Home Workshop by Jim Cox. For .25 hp it's 10 micro farad loaded or 7.5 lightly loaded. Dennis |
Thread: Ml7 paint job |
05/06/2022 20:36:28 |
Normally the belt cover spring clip goes inside the headstock to stop any rattles. Dennis |
Thread: Locomotive threading |
05/05/2022 23:35:51 |
UNF 12 x 28 which is only 0.007" bigger and 0.2 pitch difference |
Thread: Myford Lever Action Tailstock Design and Build |
13/03/2022 18:45:28 |
Just for interest there is a design for an ML7 lever feed tailstock in MEW 16 page 30 . Dennis |
Thread: Calculator App |
16/01/2022 16:26:49 |
Fraction plus app works OK Dennis |
Thread: Meddings pillar drill value |
12/01/2022 00:48:40 |
Drill going cheap on Gumtree, no connection with seller, https://www.gumtree.com/p/lathes/pillar-drill/1423380284 |
Thread: ML7 'Stop Peg'? |
09/11/2021 16:20:08 |
John Stop peg is 0.834" long with a 0.25" long 0.25" BSF thread, screwdriver slot is 0.0625" deep. Dennis |
Thread: Blackgates Stent T&C Grinder |
24/10/2021 22:08:19 |
In my downloaded catalogue from 2019, the drawings are £20 and set of 12 castings £468. I dare say the prices have increased since. Dennis |
Thread: Myford clutch design - ME 4322 |
28/09/2021 20:12:10 |
There are free plans on this site for a clutch https://www.model-engineer.co.uk/news/article/a-clutch-for-the-ml7-lathe/18982 It works very well Dennis |
Thread: Type 2 precision vice from Arc euro |
25/08/2021 23:24:47 |
In the Arc advert if you click on the ' More ' tab at the top right, there is a description of how the vice works. Dennis |
Thread: Alfred Herbert high speed bench drill |
06/03/2021 22:58:08 |
Andrew, On my Flott high speed bench top drill, the pulleys are easily swapped over, a pin spanner releases the pulley from a slotted taper. Dennis |
Thread: Engineering / Modelling Books for Winter Evenings? |
13/02/2021 22:14:47 |
Hi Dr_GMJN, Try " Intoducing model traction engine construction by John Haining " Available for around £7 from various sources. Dennis |
Thread: Insert tool cutting angles |
11/01/2021 21:07:58 |
Just Googled VCGT carbide insert angles and it came up with 35* Dennis |
Thread: How to apply grease to old machine |
31/12/2020 17:24:41 |
Check out stauffer grease cup on the internet. |
Thread: Which adhesive to use |
29/11/2020 21:32:59 |
When I made mine probably 18 months ago, used Gorilla Glue Clear, no problems so far. Left the dressed belt side out gluing on the rougher side. Best lathe update I've ever done. Dennis |
Thread: Electronic Lead Screw Project |
29/11/2020 20:02:20 |
Further update. Somewhere along the line of building and installing the ELS I missed or skipped the Part 7 Video by Clough42 see ( https://www.youtube.com/watch?v=10Ketpqq-eM ) on metric and hybrid threading. In this video he cuts imperial threads on an imperial lathe using a thread dial indicator ( ie opening and closing the half nuts ) and metric threads leaving the half nuts closed and reversing with the forward/reverse switch on the lathe itself. So problem solved I think. Dennis |
