Tony Hoggo | 07/08/2023 09:38:05 |
9 forum posts 1 photos | I made these ball turners a few years ago, just a project, had no real use for them, but they have come in handy a few times. I wanted one I could mount in the tool post and be used either in front of or behind the chuck. The first welded up one was a trial to see how well it worked, it worked extremely well, so, I made a few design changes and machined up the final. These were made on the lathe as I didn't have a mill at the time.
bernard towers | 07/08/2023 20:25:54 |
1221 forum posts 161 photos | If simple balls are to be turned they are ok but if accurate balls Arte needed say for trackrod ends etc a tool slide needs to be added |
vic newey | 07/08/2023 20:46:25 |
![]() 347 forum posts 173 photos | My 1895 vintage lathe has a powered ball turner, it can be set to turn ovals, spheres and even a ball in the middle of a length of metal bar. Here is a 90 second video powered ball turner |
Michael Gilligan | 07/08/2023 20:59:20 |
![]() 23121 forum posts 1360 photos | I do like that, Vic ! MichaelG. |
Chris Crew | 07/08/2023 21:08:35 |
![]() 418 forum posts 15 photos | I made the Radford ball turner, this design was later improved by GHT, I believe. It must rotate at exactly the centre-height of the lathe otherwise you just produce eggs and acorns so the body is best bored in the lathe upon which it is to be used. The device works well enough for 'cosmetic' balls for handles etc. but when I produced the balls for the universal joints on the Radford worm-hobbing attachment as recommended by the designer, I found I had to 'ease' the balls slightly because of a couple of tight spots. Obviously, the balls were not perfectly spherical although to the naked-eye they looked fine. |
Steviegtr | 07/08/2023 21:40:35 |
![]() 2668 forum posts 352 photos | I made this one a few years ago. Specifically for the Myford super 7 . It fits in place of the compound & then locks with the wedges. I also made it so the cutting tip can be rotated. I noticed a lot I had seen would not get right into the root where the mandrel holds it in the chuck. Steve. |
Tony Hoggo | 08/08/2023 09:10:35 |
9 forum posts 1 photos | Posted by bernard towers on 07/08/2023 20:25:54:
If simple balls are to be turned they are ok but if accurate balls Arte needed say for trackrod ends etc a tool slide needs to be added Bully for you. Mine does what I want it to, that's all that matters to me.. |
bernard towers | 08/08/2023 09:54:01 |
1221 forum posts 161 photos | OOps didn’t mean to offend! |
bernard towers | 08/08/2023 09:54:29 |
Tony Hoggo | 08/08/2023 10:28:35 |
9 forum posts 1 photos | Not offended, just surprised someone would make such a silly comment, takes all types I guess. Edited By Tony Hoggo on 08/08/2023 10:31:46 |
Robin | 08/08/2023 11:36:34 |
![]() 678 forum posts | Posted by vic newey on 07/08/2023 20:46:25:
My 1895 vintage lathe has a powered ball turner, it can be set to turn ovals, spheres and even a ball in the middle of a length of metal bar. Here is a 90 second video powered ball turner Exquisite There is a Holtzapffel lathe, with lots of the kit, up on that auction site. Made for a Victorian gentleman hobbyist wood turner, but who would want it now you can't get the ivory? Robin |
Howard Lewis | 08/08/2023 12:01:05 |
7227 forum posts 21 photos | For a lot of ball turning the diameter can be that of the material, (Used or turned to size ) . What is silly about striving for, or needing, accuracy? As ever, the importance is what meets your particular need. "One man's meat..." etc We need tolerances on here as well as on drawings Howard |
Steviegtr | 08/08/2023 12:04:04 |
![]() 2668 forum posts 352 photos | Posted by vic newey on 07/08/2023 20:46:25:
My 1895 vintage lathe has a powered ball turner, it can be set to turn ovals, spheres and even a ball in the middle of a length of metal bar. Here is a 90 second video powered ball turner Just had a watch of some of your video's. A great old lathe you have there. Plus a ingenious ball turner. Steve. |
Tony Hoggo | 08/08/2023 12:04:17 |
9 forum posts 1 photos | Posted by Howard Lewis on 08/08/2023 12:01
As ever, the importance is what meets your particular need. Ring a bell? I can get down to 0.01mm, as fine as my micrometer will measure, I don't have a need to measure finer than that, that';s accurate enough for me, and I don't use a tool slide just a tool post.
Edited By Tony Hoggo on 08/08/2023 12:13:51 |
vic newey | 08/08/2023 12:20:21 |
![]() 347 forum posts 173 photos | Posted by Steviegtr on 08/08/2023 12:04:04:
My 1895 vintage lathe has a powered ball turner, it can be set to turn ovals, spheres and even a ball in the middle of a length of metal bar. Here is a 90 second video powered ball turner Just had a watch of some of your video's. A great old lathe you have there. Plus a ingenious ball turner. Steve. -------------------- It is an interesting machine for sure, the ball turning can be set fast or slow via settings of worms and wheels etc. and a superfine mirror finish is possible. I have experimented turning a ball in the middle of a length of metal with an extreme taper either side for which the headstock was swivelled over 7 degrees for this, it can actually swivel 20 degrees. I must experiment more
Edited By vic newey on 08/08/2023 12:29:33 |
Phil P | 08/08/2023 13:10:35 |
851 forum posts 206 photos | Posted by bernard towers on 07/08/2023 20:25:54:
If simple balls are to be turned they are ok but if accurate balls Arte needed say for trackrod ends etc a tool slide needs to be added Bernard |
bernard towers | 08/08/2023 13:15:43 |
1221 forum posts 161 photos | Thanks for that Phil was just trying to get across the point of looks against accuracy , ones good for one job the other is needed for the other |
Dave Wootton | 08/08/2023 16:09:53 |
505 forum posts 99 photos | That's a lovely old lathe Vic, even sounds wonderful when running, Theraputic like my shaper. I've seen Pittler lathes advertised before without realising how versatile and clever they were. Never stop learning. Very interesting video's thanks for posting the link. Dave |
vic newey | 08/08/2023 18:01:35 |
![]() 347 forum posts 173 photos | Posted by Dave Wootton on 08/08/2023 16:09:53:
That's a lovely old lathe Vic, even sounds wonderful when running, Theraputic like my shaper. I've seen Pittler lathes advertised before without realising how versatile and clever they were. Never stop learning. Very interesting video's thanks for posting the link. Dave ---------------------- I like the noise old machines make as well Dave, the belt clicks because I haven't scarfed the joint but I like it, also noise comes from the big heavy countershaft fitted up above as well as the various gears and spur wheels! Vic |
Tony Hoggo | 08/08/2023 23:51:31 |
9 forum posts 1 photos | A lesson on how to hijack a post , well done. You're a legend - in your own mind at least. |
This thread is closed.
