Here is a list of all the postings Tony Hoggo has made in our forums. Click on a thread name to jump to the thread.
Thread: Small benchtop belt grinder. |
09/08/2023 13:37:14 |
Posted by Andrew Johnston on 09/08/2023 12:44:05:
Fortunately there is one less now. Andrew Yes, but you've outed yourself as a coward, cowards speak only when they think their target is absent. Welcome coward. I'll leave you with that knowledge. But be comforted, Admin will certainly delete my account now, and you can continue your cowardly character assassination in my absence.. Edited By Tony Hoggo on 09/08/2023 13:41:02 |
09/08/2023 12:28:58 |
You'll be happy to know I have left the forum. Too many hypocrites, fools and lunchbox legends for me. |
Thread: Ball turners. |
09/08/2023 07:36:30 |
Posted by Kiwi Bloke on 09/08/2023 06:59:16:
I don't think a lesson in bad manners is an appropriate use of this forum.
So behave yourself, don't show your bad manners, didn't your folks teach you anything? Mine taught me manners, they also taught me that manners go out the window when suffering fools and hypocrites!
09/08/2023 06:43:14 |
Originally it took two belts, but the motor didn't have enough power, so, I downgraded it to a single belt. If I ever come across a bigger, freebie motor, I'll add another belt. The table is adjustable, it has tracking, wheels are Delrin and it has a diamond wheel on the end of the driven wheel for sharpening cutting bits for the lathe. Doesn't get a lot of use, mostly the diamond wheel, but it comes in handy sometimes. Edited By Tony Hoggo on 09/08/2023 06:44:14 |
08/08/2023 23:51:31 |
A lesson on how to hijack a post , well done. You're a legend - in your own mind at least. |
08/08/2023 12:04:17 |
Posted by Howard Lewis on 08/08/2023 12:01
As ever, the importance is what meets your particular need. Ring a bell? I can get down to 0.01mm, as fine as my micrometer will measure, I don't have a need to measure finer than that, that';s accurate enough for me, and I don't use a tool slide just a tool post.
Edited By Tony Hoggo on 08/08/2023 12:13:51 |
08/08/2023 10:28:35 |
Not offended, just surprised someone would make such a silly comment, takes all types I guess. Edited By Tony Hoggo on 08/08/2023 10:31:46 |
08/08/2023 09:10:35 |
Posted by bernard towers on 07/08/2023 20:25:54:
If simple balls are to be turned they are ok but if accurate balls Arte needed say for trackrod ends etc a tool slide needs to be added Bully for you. Mine does what I want it to, that's all that matters to me.. |
07/08/2023 09:38:05 |
I made these ball turners a few years ago, just a project, had no real use for them, but they have come in handy a few times. I wanted one I could mount in the tool post and be used either in front of or behind the chuck. The first welded up one was a trial to see how well it worked, it worked extremely well, so, I made a few design changes and machined up the final. These were made on the lathe as I didn't have a mill at the time.
