A thingy
martin cross 1 | 28/07/2023 20:07:26 |
![]() 43 forum posts 59 photos | I have acquired a box of stuff for the Myford and within the box was this rather nice looking device. Well made and seems to do its stuff, but what is it for and what does it do? |
Dave S | 28/07/2023 20:09:06 |
433 forum posts 95 photos | Looks like a filing rest. Dave |
Michael Gilligan | 28/07/2023 20:11:27 |
![]() 23121 forum posts 1360 photos | Definitely Oft-used in smaller sizes by watchmakers MichaelG. . Edit: __ scroll down this page: http://www.lathes.co.uk/watchmaker/page2.html Edited By Michael Gilligan on 28/07/2023 20:14:04 |
Nigel Graham 2 | 28/07/2023 20:23:27 |
3293 forum posts 112 photos | It is indeed a Filing-rest, used for forming flat and hexagons on the turned end of the work-piece. The flanges guide the safe-edge of the file to maintain correct and consistent length; the column with screw-adjustment and clamp give the depth-limit.. It is fitted to the top-slide having lifted the tool-post or tool-clamp off its stud, and for more than a single flat you need some form of dividing-arrangement on the spindle - typically a simple detent engaging the bull-wheel or the change-wheel pinion. Does anyone have one to photograph fitted? |
MichaelR | 28/07/2023 20:36:38 |
![]() 528 forum posts 79 photos | See here LINK not the one you have but it gives the idea of use. MichaelR Edited By MichaelR on 28/07/2023 20:38:24 |
martin cross 1 | 28/07/2023 20:50:24 |
![]() 43 forum posts 59 photos | I like that, I like that a lot. It's so nicely made that I intend to keep it for the odd occasion which it will be put to use. Saves taking the piece out of the lathe and setting up the mill. My thanks to everyone for the quick response. Everyday is a learning day. I was thinking along the lines of something to center work in a 4 jaw or something to do with loco wheels. How far out I was. |
Michael Gilligan | 28/07/2023 21:12:48 |
![]() 23121 forum posts 1360 photos | Good decision, Martin MichaelG. |
martin cross 1 | 28/07/2023 21:58:18 |
![]() 43 forum posts 59 photos | I got some more stuff which I'm not sure about. Just need to get a pic, will be in touch.
Nigel Graham 2 | 28/07/2023 22:04:24 |
3293 forum posts 112 photos | Bring 'em on! |
Howard Lewis | 28/07/2023 23:55:52 |
7227 forum posts 21 photos | Martin, The Forum is her so that we can help each other, and learn. Howard |
Kiwi Bloke | 29/07/2023 05:08:02 |
912 forum posts 3 photos | Quite by chance, I came across what I think is this design. 'A Filing Rest' by L C Mason, Model Engineer 5 March 1971 (Vol 137, No 3412, pp 251-253). |
martin cross 1 | 29/07/2023 09:54:14 |
![]() 43 forum posts 59 photos | Another thingy, the base of each one is magnetic.
Edited By martin cross 1 on 29/07/2023 09:56:50 Edited By martin cross 1 on 29/07/2023 09:57:48 |
Journeyman | 29/07/2023 09:57:27 |
![]() 1257 forum posts 264 photos | Jaws from a sheet metal bender (press brake), might be usable in a bench vice. From something like this possibly. John *** See below for a more accurate answer, Well found Nick *** Edit: Add Image Edited By Journeyman on 29/07/2023 10:02:26 Edited By Journeyman on 29/07/2023 10:08:42 |
Nick Hughes | 29/07/2023 10:02:58 |
![]() 307 forum posts 150 photos | |
martin cross 1 | 29/07/2023 10:09:25 |
![]() 43 forum posts 59 photos | And this one, think it fits to a face plate.
noel shelley | 29/07/2023 10:21:48 |
2308 forum posts 33 photos | Next one please ! Noel. |
martin cross 1 | 29/07/2023 10:25:58 |
![]() 43 forum posts 59 photos | Is that one a Keats chuck? Trying to find how best to use it on Youtube, but seems no one uses it these days? |
Paul Lousick | 29/07/2023 10:45:35 |
2276 forum posts 801 photos | A Keats chuck is used with a faceplate for holding round bar instead of a chuck. |
Nigel Graham 2 | 29/07/2023 10:57:16 |
3293 forum posts 112 photos | First new "thingy" Metal-bender dies useable in a vice or with a fly-press. The magnets are to assist setting-up and help prevent them falling to the floor, which won't do their edges any good. . Second - Yes, it is a Keats Angle-block. Although its primary purpose is for holding work on a face-plate or Te-slotted saddle / cross-slide, it is quite a versatile "thingy" that can also hold for example, a work-piece vertically on a mill or drill table. A book on turning would be a better bet for information than the vagaries of You-tube. The "it seems" may just boil down to whatever single-project videos you saw, and their makers' available equipment - and opinions. I do have one, and bought it new only a few years ago. I don't use it very often but that's not the same as no-one using them "these days".
It use is fairly intuitive. The slots are for the bolts clamping it to the machine, the U-bolted Vee-block clamps the work between itself and the fixed block. For some purposes on the lathe it is better to wangle the U-bolt off its block and use instead two flat bars with bolts and nuts; or bolts tapped into one of the bars rather as on a tool-maker's clamp. This will reduce the amount of projections twirling round. (Mine takes a bit of wangling as the loosened U-bolt legs splay slightly!) . Noel - Shouldn't that be "Next slide please" ? |
martin cross 1 | 29/07/2023 11:12:52 |
![]() 43 forum posts 59 photos | The square piece with the circles cut into it? The forked jobby I believe is for the change wheels, but as I have the QC gear box it's not needed unless it's for the metric conversion (don't think so). I believe I have another bit that goes with the forked jobby somewhere.
