Steve Crow | 15/07/2023 18:04:20 |
429 forum posts 268 photos | I wish to paint the aluminium castings of a very small pillar drill I'm rehabilitating and I really want to keep the outlay to a minimum. I realise that i will have to splash out on an etch primer (U-Pol Acid 8) but I'm hoping I can use that for other projects as well. Ideally, I would like to use Paragon paint in machine colour of my choice but a 500ml tin is enough for dozens of castings this size. It's not so much the cost as the waste that I don't like. Can anyone suggest an alternative? I can't find any sample size tins that would suit me. Is Humbrol and the like suitable for a job like this? I will be applying it by brush. Also, the castings are a bit rough and pitted and I think maybe a high bulid primer over the etch primer might help. Any thoughts on this or any alternative. Cheers, Steve
bernard towers | 15/07/2023 19:18:40 |
1221 forum posts 161 photos | what about the larger size Humbrol tins? |
duncan webster | 15/07/2023 22:38:04 |
5307 forum posts 83 photos | Craftmaster sell 250ml tins for ~£11 plus postage. If you have a stockist ( canal boat chandler is a good bet) near you they might be able to order it in and save postage |
Mark Rand | 15/07/2023 23:12:35 |
1505 forum posts 56 photos | Humbrol used to be an oil based enamel, the current water based acrylic version isn't all that brilliant. The paragon machine enamels really are pretty bulletproof. Turn the tin upside down after using it (with the lid on |
Trevor Drabble | 15/07/2023 23:54:45 |
![]() 339 forum posts 7 photos | Blackgates sell Phoenix paints and one pack etch primer in tin sizes from 50ml upwards. |
Martin Kyte | 16/07/2023 09:39:12 |
![]() 3445 forum posts 62 photos | Be advised that acid etch primer has a shelf life. regards Martin |
Roderick Jenkins | 16/07/2023 10:01:16 |
![]() 2376 forum posts 800 photos | Hammerite smooth works for me. Organic solvent based and readily available in 250ml tins from local DIY sheds. Rod |
noel shelley | 16/07/2023 11:32:29 |
2308 forum posts 33 photos | Aerosol can of spray putty will help to fill the holes up - get it from an auto factor. Noel. |
Andy_H | 27/07/2023 08:41:15 |
56 forum posts 4 photos | Posted by Roderick Jenkins on 16/07/2023 10:01:16:
Hammerite smooth works for me. Organic solvent based and readily available in 250ml tins from local DIY sheds. Rod That's what I have used in the past and been happy with the result. I'm now starting on a project where I will need some suitable paint but I find (annoyingly) in the past few year since I last bought some Hammerite seem to have completely changed their colour range Andy |
Andy_H | 27/07/2023 10:28:37 |
56 forum posts 4 photos | After a bit more Googling I see that in addition to the original "Direct Product" (which is now offered in the new colour range) there's another product "Hammerite No.1 Rustbeater" (which is available in Grey). I can't really work out the difference between the products but wonder if anyone has experience of this No.1 Rustbeater option? Andy |
Andy_H | 04/08/2023 16:09:44 |
56 forum posts 4 photos | In case this helps anyone else.... After spending at least 6 hours last weekend (bit sad I know!) researching on the internet for a suitable product, available in small volume (250ml is more than enough) and at a sensible price I decided to opt for Rust-Oleum Universal Paint (All Surface Paint) in Slate Grey gloss finish. Must say I'm pretty happy with it - really nice to apply and levels out nicely to a flat finish. |
