Sonic Escape | 20/04/2023 17:48:01 |
![]() 194 forum posts 5 photos | I'm thinking on building a table saw for metals. I would like to be able make precise straight cuts in steel pipes/bars up to 30mm, plates up to 5mm or other small objects. I know I'm going to end up more expensive that buying a new one but I consider that I'm paying for the fun of building it. It would be also a good reason to do something useful with my new lathe. For the table saw I want to use a carbide disc, maybe something like this. The smallest one from there can make only 1.5mm wide cuts. I don't want to adjust the disc height and angle. Only to have a precise slide and to be able to hold the piece and exact angles. I plan to use a 3-phase motor to have speed control. I already have the inverter of the lathe. What is the risk for a carbide disc to loose one tooth? For this type of saw you are standing right in the path of a flying piece of metal if this happens. I used a lot carbide discs but only to cut wood with an angle grinder. There was no such danger.
Clive Brown 1 | 20/04/2023 17:59:42 |
1050 forum posts 56 photos | The blade needs to be protected by a guard. I have an Evolution circular saw, primarily designed for cutting wood but will also cut metal. This useage results in lots of hot metal chips flying around the work area. Quite unpleasan and needs careful use. The blades are quite pricey as well. I avoid using it to cut metal. A bandsaw or, for heavy stuff, my old Rapidor are much more civilised. |
Jelly | 20/04/2023 18:33:22 |
![]() 474 forum posts 103 photos | The feed pressure required is going to be really very substantial, and I would expect it to kick back viciously if you let the pressure up for a second, with a metal workpiece that's likely to be much more dangerous than a woodworking table saw. If you go this route I would strongly advise you have a chain or hydraulic feed which moves a very rigid work clamp, although I would still consider it a lot riskier than an equivalent bandsaw. That's the reason why (excepting some truly gargantuan slab-saws in steel mills) every cold-saw with a rotating blade moves the saw head through thecwork in a very rigidly fixed path, and bandsaws are the defacto standard for metal cutting if the workpiece is the moving element. . You can buy bandsaw "Bandwheels" as spares for an existing design, or purchase the tyres for a given dimension and fit them to wooden or fabricated wheels. If I was fabricating one I would get a disk of steel cut (or cut it on the plasma cutter) and use a ring-roller to make the OD out of steel strip (doesn't need to be hugely thick, (1mm would do if it's not too wide) you could probably tack weld and hammer form it round the disk too. The bigger the wheels the greater the cutting capacity you can have, and the wider the blade you can tension (which improves straight line accuracy), as the minimum wheel size increases proportional to how wide and thick the blade is. |
Mike Poole | 20/04/2023 19:39:41 |
![]() 3676 forum posts 82 photos | Myford used to make a saw table to mount on the cross slide. The blade was basically a 5” diameter slitting saw mounted between centres. The table could be adjusted for height and the work clamped to it. The metal cutoff saw in our workshop was a very substantial machine with a fine toothed HSS blade. The chop saw type machine by Evolution Rage seem to control the depth of cut with the design of the blade, the control of chips and any broken tips should be contained by the guards but I can imagine the hot chips will scatter widely as the cutting speed is still quite high although slower than the wood only machines. I know a very competent woodworker who lost two fingers to a circular saw, they don’t even blink if you offer your fingers to them. Mike |
Mike Poole | 20/04/2023 19:43:46 |
this thread has some pictures of the Myford saw table. Mike |
Ady1 | 20/04/2023 19:51:44 |
![]() 6137 forum posts 893 photos | A decent band saw is good The best choppy-uppy system is a grinder with 1mm discs To achieve a straight cut put the job in a vice and cut along the vice jaw line You can cut a 300mm x 100mm x 12mm steel plate in half in 2 minutes flat Have a corner of the workshop set aside for dirty work only Edited By Ady1 on 20/04/2023 19:52:37 |
Frances IoM | 20/04/2023 19:55:36 |
1395 forum posts 30 photos | I certainly wouldn't want to use one of the Evolution Rage type saws with hand fed metal, wouldn't even fancy using it in the workshop - it throws red hot bits of metal around at high speed - personally a bandsaw is much more workshop friendly - an angle grinder in a fixed stand and metal held in a vice with a 1mm metal cutting blade is just about tolerable with a metal splash guard to catch the molten metal 'sparks' - it cuts stainless steel rod better than the bandsaw. Edited By Frances IoM on 20/04/2023 19:55:54 |
Sonic Escape | 20/04/2023 21:06:24 |
![]() 194 forum posts 5 photos | Jelly, but why would you need to apply a lot o pressure? I searched for some videos with table saws cutting metal and it seems to be no difference from cutting wood. Except it takes much longer. Here somebody is cutting a >20mm plate: **LINK** I'm starting to consider again also the band saw option. How about using 4 wheels instead of 2? In this case I could have large cutting capacity with smaller diameter wheels. If wheel diameter of 10-13cm is enough I could make them on the lathe. Maybe up to 20cm with some chuck creativity. Somebody seems to have this idea already. Thank you for all suggestions.
ega | 20/04/2023 23:06:09 |
2805 forum posts 219 photos | If you make your own bandsaw wheels it may be important to balance them. I use the Evolution Rage saw blade for thin metals in both my portable circular and radial arm saws; in either case, the saw is mechanically guided but advanced, with great care, by hand; this is made possible by the chip-limiting form of the teeth. |
Paul Lousick | 21/04/2023 06:16:41 |
2276 forum posts 801 photos | A bandsaw is a very handy tool in the workshop but an option is to use a sliding angle grinder guide. Lots of DIY builds on the Internet, Youtube, etc.
Paul Lousick | 21/04/2023 13:00:25 |
2276 forum posts 801 photos | Video of a DIY bandsaw on Youttube using wooden wheels and a simple sliding angle grinder guide. . **LINK** |
Sonic Escape | 25/04/2023 19:39:11 |
![]() 194 forum posts 5 photos | After seeing some Youtube videos I changed my mind, no more table saw. It is too dangerous comparing with the band saw. Some of the causes of accidents are not even that obvious. I did some research and I found that for a 1mm thick blade you need a wheel at least 18" in diameter. That might be difficult to turn in my lathe. And I don't know from where to buy a bar with that diameter. I'm looking for some thick delrin plate, or another strong plastic. The only progress so far is that I found a local company that sells carbide band saw blades at any length you want. So I'm not constraint to some predetermined diameter. |
JasonB | 25/04/2023 20:06:29 |
![]() 25215 forum posts 3105 photos 1 articles | That sounds a bit of a thick blade, the ones I use on my Femi bandsaw are 0.65mm and the wheelsabout 200-225mm. Do you really need carbide, M42 last well. |
Dalboy | 25/04/2023 21:06:22 |
![]() 1009 forum posts 305 photos | I find that a saw like THIS does the jobs I need to cut and on the odd occasion when I need to cut something bigger a mini grinder or larger depending on what it is |
Sonic Escape | 25/04/2023 21:33:35 |
![]() 194 forum posts 5 photos | I'm wasn't sure about blade thickness. Now I saw that 0.65mm is the most common value. The same for carbide blade. I measured precisely the space between the center and the tip of the cutting tool and it seems that I can turn something up to 210mm in diameter. So for a 0.65mm blade maybe I'm close. |
Sonic Escape | 25/04/2023 21:36:01 |
![]() 194 forum posts 5 photos | Posted by Dalboy on 25/04/2023 21:06:22:
I find that a saw like THIS does the jobs I need to cut and on the odd occasion when I need to cut something bigger a mini grinder or larger depending on what it is I want to build a vertical bandsaw to be able to cut also metal plates. It will have 3 or 4 wheels. Edited By Sonic Escape on 25/04/2023 21:36:39 |
DiogenesII | 26/04/2023 06:34:40 |
859 forum posts 268 photos | Posted by Sonic Escape on 25/04/2023 21:33:35:
I'm wasn't sure about blade thickness. Now I saw that 0.65mm is the most common value. The same for carbide blade. I measured precisely the space between the center and the tip of the cutting tool and it seems that I can turn something up to 210mm in diameter. So for a 0.65mm blade maybe I'm close. If you put a holder with a L/H tool onto the position nearest the operator you will easily gain another ?50mm+ on radius..
Edited By DiogenesII on 26/04/2023 06:35:24 |
Sonic Escape | 26/04/2023 06:48:14 |
![]() 194 forum posts 5 photos | Posted by DiogenesII on 26/04/2023 06:34:40:
Edited By DiogenesII on 26/04/2023 06:35:24 Yes, I didn't think of that! It is a very good idea |
JasonB | 26/04/2023 07:06:15 |
![]() 25215 forum posts 3105 photos 1 articles | The thing to watch with 3 and even more so with 4 wheel saws is that you don't get as much wrap around of the belt on the driven wheel and will end up with it slipping unless the wheels are excessively large Most of the small bandsaws that have a single pivot can also be set vertically for cutting sheet metal, though the throat depth is generally a bit less than a true vertical, The down side of only a vertical is you cant cut say a 4fy length of bar in half as the left hand end will hit the frame. How wide/long a piece of metal do you expect to be cutting? Edited By JasonB on 26/04/2023 07:10:40 |
Sonic Escape | 26/04/2023 18:46:07 |
![]() 194 forum posts 5 photos | Posted by JasonB on 26/04/2023 07:06:15:
The thing to watch with 3 and even more so with 4 wheel saws is that you don't get as much wrap around of the belt on the driven wheel and will end up with it slipping unless the wheels are excessively large Most of the small bandsaws that have a single pivot can also be set vertically for cutting sheet metal, though the throat depth is generally a bit less than a true vertical, The down side of only a vertical is you cant cut say a 4fy length of bar in half as the left hand end will hit the frame. How wide/long a piece of metal do you expect to be cutting? Edited By JasonB on 26/04/2023 07:10:40 Hmm ... that could be an issue. Today I read more about 3 or 4 wheels bandsaws and there are a number of reasons why almost no manufacturer builds them. I was rethinking what requirements I want. What I fell is missing is the ability to precisely cut small parts. Plates up to 250mm, tubes up to the same length or any other things more or less in the same dimension interval. If I want to cut long pieces I'll just use the angle grinder like I do now. I just finished a large metal workbench and there was no problem in cutting everything with abrasive tools. And to cut a larger plate will be quite a rare event. I can order it to a laser cutting shop. |
