Irbailey | 19/03/2023 09:38:31 |
11 forum posts | I'm looking for some advice on knurling. I've done plenty of normal knurling on steel, brass and aluminium, but this project is a little different. I'm making a Fairbairn-Sykes style Commando Knife which requires knurling on a curved surface. I made a test piece from aluminium and tried it by placing the knurling tool on the work, then removing it, moving along and repeating as required. Whilst it sort of worked, I wasn't happy with the result as it was a bit of a mess. I've included a couple of pictures of the brass handle I wish to knurl. The two blue lines are the area I wish to knurl (the end line is where it will be parted off) Any help/suggestions would be very much appreciated. Many thanks, Ian. |
Bo'sun | 19/03/2023 09:48:18 |
754 forum posts 2 photos | Hi Ian, You could try individual tangential knurls separated by a grooving/parting/vee tool. Good luck. |
Bizibilder | 19/03/2023 09:55:14 |
![]() 173 forum posts 8 photos | You used to be able to buy a hand held knurling tool that you gripped like a pair of pliers. it had three knurling wheels . Not sure if they are still available. this thread HERE has a picture about 8 or 9 posts down. This one has a screw for closing the knurls but I've seen very similar ones where a good strong hand grip will work. Obviously with the hand grip you can vary the distance between the knurls. Edited By Bizibilder on 19/03/2023 09:55:56 Edited By Bizibilder on 19/03/2023 09:57:34 |
JohnF | 19/03/2023 09:56:17 |
![]() 1243 forum posts 202 photos | Well there are two problems, you need to follow the contour of the work and the knurls also need to be square on to the profile as well, [ assuming standard knurls] Just an idea ! make a straight feed two wheel knurling tool that has the head articulated so it can follow the profile, thus the head and wheels swing left & right. As for the in feed to follow the contour then it's either by hand, eye & feel or make a profile follower similar to the ones where the taper turning attachment used. Possibly an overkill for a one off ? Whether it will work I know not but my first thoughts - lets see what the team come up with John |
Irbailey | 19/03/2023 10:02:53 |
11 forum posts | That would definitely make things easier. The originals were knurled in one and after studying pictures, some of them do look as if they were done in sections, some better than others! This was the 1940's, so CNC wasn't involved. I'm guessing how well they came out depended on the lathe operator. I can see why they changed from knurling to grooves in the latter production and current handles, as it must have simplified production tremendously. I wondered whether slowly moving the pressure on the work and edging it along with the carriage would work? Ruining it after getting this far would be a bit depressing to say the least! Ian.
Irbailey | 19/03/2023 10:14:09 |
11 forum posts | Thanks for the advice. I was still replying to the first comment before I realised there were more! This will most likely be a one off, maybe not, but certainly not something I'll be making batches of or repeating on a regular basis. These are some original handles for an idea of what I'm trying to achieve. Obviously making the grooved version would be easier, but I do enjoy a challenge! Edited By Irbailey on 19/03/2023 10:15:48 |
Hollowpoint | 19/03/2023 10:29:43 |
550 forum posts 77 photos | You might be able to do it freehand with enough leverage, maybe try a thin knurl on the end of a very long handle in a similar way to how metal spinning is done. |
ega | 19/03/2023 10:39:38 |
2805 forum posts 219 photos | FWIW, to my eye the grooved version looks better! |
John Haine | 19/03/2023 10:55:32 |
5563 forum posts 322 photos | This may not be too helpful but I would engrave them on the CNC with a rotary axis. |
Mick B1 | 19/03/2023 11:26:18 |
2444 forum posts 139 photos | The 'proper' way might be to mount the knurling tool on a long-radius turning fixture or a copying attachment so as to follow the curve. In all probability you'd have to make the gadget plus a template, so you've got the decision to make as to whether the knurled finish is worth that, the grooves being so hugely easier and functionally similar. Edited By Mick B1 on 19/03/2023 11:27:57 |
Baz | 19/03/2023 11:40:53 |
1033 forum posts 2 photos | Looks to me as though the original knurls have been done in bands as they don’t match up exactly so just set tool square to work and stab it in, wind it out,move along setting square to work again and repeat process. For what it’s worth I far prefer the bottom, grooved version. |
noel shelley | 19/03/2023 11:56:59 |
2308 forum posts 33 photos | Possibly done by pressing ? Noel |
Irbailey | 19/03/2023 15:18:57 |
11 forum posts | Thank you all for your suggestions. Much appreciated.
I'm still not sure which direction to go, but the groove/knurl combo is looking like a possible option.
Thanks for taking the time to reply. I'll post the results (good or bad!) once I've decided which direction to go in.
Cheers,
Ian. |
Clive Foster | 19/03/2023 15:51:09 |
3630 forum posts 128 photos | Thinking about my experience of using the hand held squeeze knurler device mentioned by Bizibilder it might be possible to keep sufficiently even pressure on the tool to create a good looking knurl by twisting the tool slightly so it runs from side to side. The technique works fine on a long(ish) parallel shaft. Can't see any reason why it shouldn't follow moderate slopes and curves. Obviously if the slope is too steep or the curve too great it's going to dig in. Given an adequately shallow curve or slope it obvious issue is keeping the right level of pressure on the tool as it runs up and down the the cuve. I imagine it will take several strokes to form the knurl squeezing harder with successive runs. For ordinary small knurling you just squeeze until the knurl looks deep enough. Here is a picture of the tool Bizibilder refers tor :- Certainly hasn't been made for years and rare then. Found mine maybe 40 years ago in the "going to throw away" box at an experienced machine tool and tooling dealer who didn't realise what it was and how effective it could be. Having used one I knew better and gladly handed over an extra £1 for it on top of the price of the big Pollard drill I went to buy. Minor correction to what Bizibilder said. The screw sets the squeeze depth not the clamping load. I'd think screw clamping could be dangerous if the tool gets away from you. Although the adjustments imply it can be set to handle work over 2 inches - 50 mm in diameter I find it starts getting cumbersome over an inch - 25 mm or so. But what it does do it does really well. Had to knurl some 6 mm pins to fill some no longer needed holes in a part being modified yesterday. Longest party of the job was finding some stock and mounting in the lathe. Squeeze and repeat 8 times gave me 8 pins 10 mm long ready to tap in. Links to drawings and build instructions for that and couple of similar ones in the thread linked to by Bizibilder. Clive
Edited By Clive Foster on 19/03/2023 15:52:05 |
Irbailey | 19/03/2023 16:50:32 |
11 forum posts | That looks like a very useful tool.
Daft question, but I'm assuming it pulls itself along the work?
Even dafter question - does a normal tool post mounted two wheel knurl also pull itself along the work if the carriage is free?
I'm 100% 'self taught' on lathe work and I've always knurled by running the chuck on the lowest RPM and the same with the feed rate (it's a Myford ML7-R)
I ruined a lot of material before I was able to get a nice diamond pattern, but I'm now wondering if I've been doing it correctly and possibly making life hard for myself.
Ian.
Clive Foster | 19/03/2023 17:28:58 |
3630 forum posts 128 photos | Irbailey Need to lean it a touch and push slightly sideways to make it move along. It's a feel thing really. Given the right mix of squeeze force with a modest push and gentle lean it walks sideways very controllably. If you hold it dead square when you squeeze it stays in place. Just the ticket for doing knurled head screws. Toolpost mount types you feed side to side using saddle feed. On lighter machines its probably better not to try and make a full knurl in one go. Clive
Irbailey | 19/03/2023 18:11:41 |
11 forum posts | Thanks Clive.
That makes sense.
Using a tool post mounted knurling tool in the past I've made one pass with fairly light pressure, then added pressure and reversed the feed to go back over the work and so on until I'm happy with the depth and cut pattern.
To be honest, I'm still not 100% sure how to go about my handle, but I've learned a fair bit today and everyone's help has given me food for thought and some different ideas on how to approach it.
Thank you all for taking time to reply to my question, it's very much appreciated.
Ian.
daveb | 19/03/2023 18:38:52 |
631 forum posts 14 photos | I bought one of these knives from Brick Lane street market in London about 60 years ago. Ex military tools and hardware was sold at most markets and many specialist shops in those days, seldom see the stuff now! The handle on mine was ribbed, I've seen many more over the years but never one with a knurled handle. Interesting thread, knurling is tricky enough on straight sections, I'm intrigued to see how it turns out. Daveb
Irbailey | 19/03/2023 19:01:13 |
11 forum posts | Posted by daveb on 19/03/2023 18:38:52:
There were three patterns. First and second were knurled, the third - which is still in production today - was ribbed. The first two patterns are fairly rare these days and usually a second pattern will fetch £600-£700 and a first pattern double that or more depending on condition.
I'm also intrigued to see how this turns out.
There's a high possibility of wasting some brass here...still, won't be the first time!
Ian.
pgk pgk | 19/03/2023 19:33:23 |
2661 forum posts 294 photos | Is the following a stupid idea? pgk |
