Dead-Blow Hammer Recommendations Please
Dr_GMJN01/03/2023 11:20:08
1602 forum posts
All, I'm looking for a small dead-blow hammer for tapping work down into my milling vice. It's an SX2P with a small vice, so I want something small enough to tap down pieces up to a couple of inches wide.
Any recommendations? Thanks.
Nick Wheeler01/03/2023 11:47:40
1227 forum posts
101 photos
Why is a dead blow hammer needed for that job?
It's not a big mill, so the parts are going to be pretty small too. I've been known to use the hammer end of a large screwdriver....
noel shelley01/03/2023 11:52:09
2308 forum posts
33 photos
Make one ? Pour lead into a vessel to cast a head. Machine from copper or nylon bar. Just a thought. Small THOR hammers are available with hide/copper faces for about £10. Noel.
Edited By noel shelley on 01/03/2023 11:54:01
Brian Wood01/03/2023 11:54:10
2742 forum posts
39 photos
Block of wood?
DMB01/03/2023 12:12:18
1585 forum posts
I have a small Thor copper hammer, works well for that purpose. As Brian just said, block of wood. When I was using machines in a factory many years ago, I had a large block of copper for that use. Think it was about 2 ins. sq. x about 4 ins. long with a mass of burrs on each end.
Tony Pratt 101/03/2023 12:34:01
2319 forum posts
13 photos
During my Toolmaking career I mainly used a piece of roughly 11/4" diameter x 6" long copper for knocking down aided by a block of Tufnol to protect the work as required. Both now still in use in my garage workshop.
Tony
Speedy Builder501/03/2023 12:41:27
2878 forum posts
248 photos
lookup Nylon Hammer on any of the internet sites.
duncan webster01/03/2023 12:52:31
5307 forum posts
83 photos
I use a lead fishing weight. When it gets too distorted I'll melt and tecast
Dr_GMJN01/03/2023 13:45:32
1602 forum posts
I've got a small copper/hide hammer, but assumed that for tapping parts into the vice, a dead-blow hammer might be better. Just from what I've seen recently on YouTube videos on model engineering (especially squaring / seating blocks for further machining).
Dave Halford01/03/2023 14:28:52
2536 forum posts
24 photos
A hide hammer is pretty dead, as in no bounce nor dents. That said look-at-me-tube would know best.
ega01/03/2023 14:44:11
2805 forum posts
219 photos
I can see why a no-bounce hammer might be better. If the work is on parallels, however, it should be possible to check that they are trapped - QED.
Dr_GMJN01/03/2023 15:45:27
1602 forum posts
Posted by ega on 01/03/2023 14:44:11:
I sometimes find that even a tap to seat on parallels results in one or the other being loose. It's often the case where I'm going back and forth with ever lighter taps to get things seated firmly. I'd assumed that some bounce caused by the rebound of the part from the parallel might be eliminated with a dead-blow hammer.
Georgineer01/03/2023 15:49:44
652 forum posts
33 photos
How many of the posters who have suggested nylon hammers, screwdrivers, lumps of lead, politicians' noddles and so on have actually twigged that none of these is actually a dead-blow device?
How many know but have chosen to ignore the difference and thereby the OP's question?
How many of the readers who come here to learn will go away thinking that there is no difference?
I think we should be told.
George
Michael Gilligan01/03/2023 16:40:43
23121 forum posts
1360 photos
Posted by Georgineer on 01/03/2023 15:49:44:
Quite so, George yes
I had not contributed, but:
I use a cast-Aluminium, Lead-shot filled, Nylon-faced hammer.
JasonB01/03/2023 16:41:57
For small work you can get dead blow drifts, basically a dead blow hammer without a handle and in smaller weights.
Not tried one as a Thor copper/hide jobbie has always worked for me on the odd occasions that I bother to knock the work down. Most of the time I don't bother but the engines all seem to run OK.
The lump of lead or other softer metal and the copper/hide hammers have been used for years and obviously work, the plastic lead shot dead blow hammers are just something new.
Michael Gilligan01/03/2023 16:56:33
23121 forum posts
1360 photos
Posted by JasonB on 01/03/2023 16:41:57:
dont know
I’ve had mine for at least forty years … and it’s a cheap clone of the original
Refhttps://www.thorhammer.com/thor-history/
Edited By Michael Gilligan on 01/03/2023 16:59:22
JasonB01/03/2023 16:57:55
But you just said yours was aluminium
Michael Gilligan01/03/2023 17:00:45
23121 forum posts
1360 photos
Posted by JasonB on 01/03/2023 16:57:55:
Aluminium with Nylon faces
Dr_GMJN01/03/2023 17:05:53
1602 forum posts
It’s the lead shot type that I assume is a dead-blow hammer, with reduced rebound. That’s what I want advice on. Thanks.
Michael Gilligan01/03/2023 17:19:26
23121 forum posts
1360 photos
Posted by Dr_GMJN on 01/03/2023 17:05:53:
https://www.thorhammer.com/product/20-1010/
… or if you need something smaller, make your own
Refhttps://worldwide.espacenet.com/patent/search?q=pn%3DGB1238652A
ERRATUM : I have just discovered that Thor uses Steel Shot
Edited By Michael Gilligan on 01/03/2023 17:39:09
