Thread Size
Justin Thyme24/02/2023 20:07:48
72 forum posts
I was hoping someone could help identify the following thread sizes. I have just been given a box with several hundred machine screws in three different threads. But there are no nuts, I would like to buy some but these are not standard M3 M4 M5 and I don't think they are Imperial
Major Dia - 4.6 mm ... Pitch 0.81
Major Dia - 3.48 mm ... pitch 0.69
Major Dia - 2.71 mm ... Pitch 0.52
(the 3.5 mm one is not an electric socket size, it don't fit! and I measure them at Major Dia 3.36 & pitch 0.61)
Pete Rimmer24/02/2023 20:17:19
1486 forum posts
105 photos
First one is 2BA
Second is probably 6-36
Last one is 6BA
JasonB24/02/2023 20:18:39
Most likely 2BA, 4BA and 6BA
bernard towers24/02/2023 20:20:25
1221 forum posts
161 photos
Looks like they could be specials, I converted them to 3/16 x 32, 9/64 x 26 and 7/64 x 20.
Bill Phinn24/02/2023 20:23:04
1076 forum posts
129 photos
Not sure how you're measuring the pitch, and why you've given two different readings for the major diameter and pitch of the "3.5mm one", but, as others have said, these are most likely to be 2,4, and 6 BA screws.
4BA was used instead of M3.5 on older electrical sockets.
Justin Thyme24/02/2023 21:09:10
72 forum posts
I didn't give 2 different dia for the 3.5 mm one, I made a comparison with an electrical screw which is smaller.
I basically measure the pitch by counting the threads (for the smallest I counted 37.5 over 20mm - giving a pich of 0.53 or 48 tpi - which would fit in very well with the 6BA
So Yes, and thank you all, they must be a collection of BA machine screws, they just looked very metric, normally I can tell just looking if they are imperial. And the one measuring just a bit below 3.5 confused me even more.
Any suppliers of BA nuts - not quite sure if it is worth bothering? just seems a shame not to use them
Harry Wilkes24/02/2023 21:30:41
1613 forum posts
72 photos
I get mine from EKP Supplies
https://www.ekpsupplies.com
Bill Phinn24/02/2023 21:36:50
1076 forum posts
129 photos
Here.
Nicholas Farr24/02/2023 21:43:05
3988 forum posts
1799 photos
Hi, they are also available from Poly Model Engineering and Reeves 2000
Regards Nick.
Frances IoM24/02/2023 21:46:21
1395 forum posts
30 photos
having acquired at rummage sales a large assortment of taps + dies; one afternoon I made my "swiss cheese" block from a spare bit of ali bar and drilled + tapped all common threads 6.3mm and smaller - now sorting odd screws is a trivial task - they can then be sorted into those multi-compartment boxes that Maplin used to sell along with any matching nuts.
Martin Kyte24/02/2023 22:28:13
3445 forum posts
62 photos
Posted by Justin Thyme on 24/02/2023 21:09:10:
BA fasteners are metric, 0BA is 1mm pitch
regards Martin
Start with 1mm and successively multiply by 0.9 to get all the higher number pitches.
Edited By Martin Kyte on 24/02/2023 22:33:51
Justin Thyme24/02/2023 23:47:35
72 forum posts
Posted by Martin Kyte on 24/02/2023 22:28:13:
regards Martin
Thanks again for that, metric thread first proposed in Britain in 1884 !
DC31k25/02/2023 07:50:16
1186 forum posts
11 photos
Chronos sell a BA thread ptich gauge for not too much money which might help firm up the identification.
Michael Gilligan25/02/2023 08:19:16
23121 forum posts
1360 photos
If you hone your ‘looking’ skills a little [with the help of some magnifying optics] you should be able to tell that the thread-form is sharper on BA than either imperial or metric.
47.5°
Howard Lewis25/02/2023 16:59:33
7227 forum posts
21 photos
As Michael says, BA thread form is 47.5 degrees.
Whitworth form is 55 degrees
Unified and Metric are 60 degrees.
Might be worth getting hread gauges for BA, Whitworth, Unified and Metric.
These will allow you to find thread form and pitch (or tpi for Imperial sized fasteners ).
