Speedy Builder5 | 24/02/2023 11:00:00 |
2878 forum posts 248 photos | What on earth have they sold me. A year or so back, I bought some CZ 121 bronze bar as stock. Today I made a couple of 1/4 BSP bushes and went to solder them onto a brass plate with COMSOL. The solder flowed on the brass plate, but the bushes just turned black and would not 'wet' to the solder. I thought it a bit strange, so on a piece of scrap brass, turned up another scrap of the CZ 121 - same problem and the solder would not adhere to it. Moving on, I tried a bit of silver solder - same problem. What have I got hold of ? Not CZ121 for sure. It looks like bronze - turns like bronze Bob |
JasonB | 24/02/2023 11:09:42 |
![]() 25215 forum posts 3105 photos 1 articles | CZ 121 is a brass not a bronze so who knows what you have |
Ady1 | 24/02/2023 11:12:07 |
![]() 6137 forum posts 893 photos | On the plus side you got a bargain if it is bronze |
Trevor Drabble | 24/02/2023 11:41:57 |
![]() 339 forum posts 7 photos | I think it's a flux problem and that it may be a leaded bronze , in which case suggest you talk with CuP Alloys regarding a suitable flux . I've always found them most helpful . No connection other than a satisfied customer . Trevor. |
Phil P | 24/02/2023 12:13:09 |
851 forum posts 206 photos | Sounds like "Aluminium Bronze" ?? That can be very difficult to solder, dont ask how I know. Phil |
Martin Johnson 1 | 24/02/2023 12:50:20 |
320 forum posts 1 photos | I had a similar problem with a bar stamped "Holfos" a while back. I think I just avoided the problem in the end. Martin |
Trevor Drabble | 24/02/2023 12:52:09 |
![]() 339 forum posts 7 photos | If , as Phil suggests it is aluminium bronze , then you may find adding 20% - 25% household salt to your existing flux will help inhibit the aluminium oxides from forming . Trevor. |
Speedy Builder5 | 24/02/2023 15:22:13 |
2878 forum posts 248 photos | Tried mixing a bit of salt with the silver solder flux, no joy there. Abandoned the solder idea, chucked the bushes in the bin, removed the marking off the remains of the bar, then used a different piece of stock material. Job done and the COMSOL flowed lovely with BAKERS fluid as flux. Ps: this isn't boiler related ! |
gerry madden | 24/02/2023 15:44:44 |
331 forum posts 156 photos | Just wondering if it was sintered (porous) bronze loaded up with oil ? Usually this would make a lot of smoke when cooked and you didn't mention this so probably not. Gerry |
Bill Phinn | 24/02/2023 17:31:28 |
1076 forum posts 129 photos | Posted by Speedy Builder5 on 24/02/2023 11:00:00:
Moving on, I tried a bit of silver solder - same problem. Obviously we don't know what your bar stock is/was, but could you just clarify what you mean by "silver solder"? Comsol has some silver content. |
noel shelley | 24/02/2023 17:59:20 |
2308 forum posts 33 photos | As others have said, CZ121 is a brass. What you have may be aluminium bronze. Or even a monkey metal, I have come across a brass with more zinc than is good, but its cheap. Sounds a bit odd. Noel. |
Speedy Builder5 | 24/02/2023 20:57:49 |
2878 forum posts 248 photos | Hi Bill, I started with COMSOL ( higher temp lead solder from Cup Alloys). No Go! Then with some scrap bits, tried a joint between brass sheet and a disc of the mystery metal. Used Cup Alloys 455 silver solder rods(55% silver) with their EF flux. The mystery metal turned black and wouldn't "wet" . By comparison, the scrap sheet of brass "wetted" nicely and the silver solder flowed nicely. Adequate heat, joint prep was from fresh turned material and no coolant. I do stress that I do not lay the problem at Cup Alloy material or even my soldering and silver soldering skills. I think my mystery metal must be some sort of bearing bronze (not sintered). It came from a metal supplier to the marine industry. Unfortunately that was some time ago and I don't have the invoice any longer. Tried again with a mix of table salt and EF flux - No Go. The material turned nicely, but was tough to drill and very tough to put a 1/4" BSP tap through the bush. I just thought my ancient tap was blunt, but by comparison, when I re-made the bushes in some stock brass, they passed through quite easily. |
not done it yet | 25/02/2023 08:35:32 |
7517 forum posts 20 photos | The material turned nicely, but was tough to drill and very tough to put a 1/4" BSP tap through the bush. I just thought my ancient tap was blunt, but by comparison, when I re-made the bushes in some stock brass, they passed through quite easily. That smacks as a description of typical aluminium bronze. I have a project with a large(ish) chunk on the lathe. Turns nicely, but is b****r to tap. |
Circlip | 25/02/2023 10:30:58 |
1723 forum posts | Try a magnet, if it's slightly magnetic, it's alumininium bronze. Regards Ian. |
Speedy Builder5 | 25/02/2023 11:02:56 |
2878 forum posts 248 photos | NDY and CirClip, thanks Ian, you are on the money. just tested it with a magnet, as you say, slightly magnetic. Now what do I use 2 feet of 5/8" Al Bronze for ? Bob Edited By Speedy Builder5 on 25/02/2023 11:03:44 |
Norman Billingham | 25/02/2023 11:10:51 |
56 forum posts | Another way to check is to measure length and diameter to get volume, then weigh it and calculate density - Al bronzes are less dense than brass |
not done it yet | 25/02/2023 12:47:06 |
7517 forum posts 20 photos | Now what do I use 2 feet of 5/8" Al Bronze for ? A couple of hefty yellow metal drifts? |
noel shelley | 25/02/2023 13:20:02 |
2308 forum posts 33 photos | I can go back to bed now ! Objective achieved, I;ve learn something new today ! Ali bronze is slightly magnetic. Thank you circlip. Noel. |
duncan webster | 25/02/2023 13:25:05 |
5307 forum posts 83 photos | Posted by not done it yet on 25/02/2023 12:47:06:
Now what do I use 2 feet of 5/8" Al Bronze for ? A couple of hefty yellow metal drifts? Corrosion resistant, high strength, used a lot in marine environment. I've seen ali bronze nuts on stainless bolts, no galling. |
